PATCH: CEL Flash on Loaded Knock
Old Aug 28, 2007 | 08:57 AM
  #166
laakness's Avatar
I know some one mentioned this earlier in the thread...but hooking up a LED or warning bell to pin 36(Evo 8 - http://www.evomoto.com/tech_info.php..._5&tech_id=19).
Anyone happen to know the voltage from that wire or am I going to have to bust out the multimeter and read a tapped wire while going down the road
Old Aug 28, 2007 | 11:14 AM
  #167
HmanEVO's Avatar
I'm having an issue with the "CEL on knock flash time". I have tried a couple different ranges from 1500-3000ms and whenever the required knock sum is met, the CEL will flash but will continue to do so for several minutes before it stops. I read the ecu after every flash to confirm the settings change and they do.
My ROM ID is 94170008. I'm also running ecuflash version 1.31. At first from my reading I thought some of the issues with version 1.31 were limited to the IX definition files. Could it be a problem with ver 1.31 or is there anything else I should be looking at?
Thanks,
Chris
Old Aug 28, 2007 | 08:39 PM
  #168
tephra's Avatar
send me your ROM+XML and I will check out the timing - its probably a definition problem..
tephra at gmail
Old Aug 28, 2007 | 09:47 PM
  #169
oldevodude's Avatar
+1 on the 15 rom . A big thanks to Tephra for making this a reality
Old Aug 28, 2007 | 11:05 PM
  #170
HmanEVO's Avatar
tephra at gmail
I got it working now. I ended up getting ahold of ver 1.29a. Reinstalled your patch and it works just like it should.
Thanks a bunch for taking the time to put this together. I was running DSMLink previously in the Evo and this was one feature I was quite fond of.
Old Aug 30, 2007 | 10:13 AM
  #171
Evo_Pma's Avatar
this work with a evo 7? ID 99860002 ... if work anybody have the xml and the rom?
Old Aug 30, 2007 | 01:03 PM
  #172
dawnduran's Avatar
where I could find the FAQ to patch my rom?
Old Aug 30, 2007 | 08:20 PM
  #173
tephra's Avatar
There is no FAQ, self patching is a minefield which I would NOT advise people to get into..
its not as simple as changing a few numbers in maps - this is altering the flow of the ECU code... which if you get wrong could be rather fatal!!!
time constraints on my end are stopping me from doing much more with this particular project... i will probably finish off 94170014 and 88580014 and call it a day onto other mods..
UPDATE:
Please ensure your definitions are using big endian rather than little - this may cause a problem for the flash time.
94170014 is up - UNTESTED thou!
Old Aug 30, 2007 | 09:28 PM
  #174
mchuang's Avatar
UPDATE:
Got your IM thx, may not be able to test til this weekend. Work owns me.
Old Aug 30, 2007 | 09:51 PM
  #175
fixem2's Avatar
Moving to "BIG" endian changes the flash time to 235931ms. Sound right?
Old Aug 30, 2007 | 10:06 PM
  #176
tephra's Avatar
no - it should still stay at what you put in - what version of ecuflash you got?
Old Aug 30, 2007 | 11:09 PM
  #177
Evo_Pma's Avatar
this work with an evo 7? ID 99860002 ... if work does anybody have the xml and the rom?
Old Aug 30, 2007 | 11:12 PM
  #178
tephra's Avatar
if its not listed on the first page then its not done yet..
Old Aug 31, 2007 | 05:37 AM
  #179
fixem2's Avatar
Tephra, I am running version 1.30. If I change it back to "little" I get the 3431ms number.
Old Aug 31, 2007 | 06:08 AM
  #180
tephra's Avatar
hrmm thats weird... maybe the endian was swapped around 3431 is correct
ok so 1.31 needs to be big, otherwise little...
