PATCH: CEL Flash on Loaded Knock
Old Aug 21, 2007 | 08:02 AM
  #136
mchuang's Avatar
I would love to test this on the 94170014 rom but it looks like it is not modded yet
Old Aug 21, 2007 | 08:20 AM
  #137
Charlie_B's Avatar
Originally Posted by tkklemann
96940011 Tested and works great, bbbbbuuuutttttttt.......
EvoScan has a fit when I try to log now, and when started it makes the car wig out.
Double checked everything, and it's all right. Seems like the ROM when loaded into the ECU makes EvoScan no longer work...
Hmmm.... Any ideas?
Im getting sort of the same issue with Mitsulogger. Im wondering if we are experiencing the same thing. For now, I can do the same as you and use two different maps (one with knock light, and one without for tuning)
Old Aug 21, 2007 | 08:24 AM
  #138
fasterthanurwrx's Avatar
Now you guys are starting to make me wonder.
I was having a hard time using Evoscan 1.0
But version .99 was working just fine.
Old Aug 21, 2007 | 08:33 AM
  #139
Charlie_B's Avatar
Are there any problems with having everything set up in the XML files, and just switching out the modified rom, and not replacing all of the xml files with unmodded ones? I am assuming that I can just turn the on/off value to 0 on my unmodded rom, correct?
Old Aug 21, 2007 | 09:44 AM
  #140
mplspilot's Avatar
Is reading through the thread really that hard?
Modifying xml files only adds tables to the ECUflash program. When you change those values in added tables it will only affect anything if you have a flash file/rom (.hex) that supports those changes. (So long as you added the xml script into the right definition file)
(which means you can put 0 or 1 or 9999 in there, it is not gonna change anything unless you have a modified(patched) rom)
Old Aug 21, 2007 | 09:49 AM
  #141
Charlie_B's Avatar
Thank you.
Old Aug 21, 2007 | 10:05 AM
  #142
justchil's Avatar
Sweet! Can't wait to try this out
Old Aug 21, 2007 | 10:11 AM
  #143
Adam@MMS's Avatar
Thank you so much for this mod. Incredible.
Old Aug 21, 2007 | 04:58 PM
  #144
tephra's Avatar
to the guys having problems with evoscan please post up a detailed description of the problem
Old Aug 21, 2007 | 05:01 PM
  #145
OK...
So I was having a issue with EvoScan 1.0..
But I thought it was a install related issue.
Tonight I will test, confirm and post the details here.
Old Aug 21, 2007 | 05:06 PM
  #146
joedr's Avatar
EvoM Moderator
Tested on IX with 15 rev! Worked like charm.
Congrats on this mod!
Old Aug 22, 2007 | 11:06 AM
  #147
Evoryder's Avatar
94170008 works like a charm on my 2003 Evo. Like someone mentioned before, later today I am going to tap the line for "Service engine Light" from the Ecu and link it to a light.
Old Aug 22, 2007 | 12:20 PM
  #148
travman's Avatar
I use evoscan version .99 and I log fine with the patched rom (IX-15)........I didnt know 1.0 was out yet?
Old Aug 22, 2007 | 12:52 PM
  #149
Charlie_B's Avatar
I think my logging problem is driver related, not ROM related.
Thanks again for the mod guys! It works great (96940011). Unfortunately, mine is flashing all over the place. (Gotta get my logger sorted out so I can tune it..)
Old Aug 22, 2007 | 05:01 PM
  #150
tephra's Avatar
change the default load=100,knock=1 to load=150, knock=4 that should reduce your flashing
