PATCH: CEL Flash on Loaded Knock
Old Sep 4, 2007 | 06:05 PM
  #196
tephra's Avatar
strange - i guess just retry the flash...
ECUFlash *probably* wouldn't have updated your ROM with the immobilizer code as that segment shouldn't have changed...
Old Sep 4, 2007 | 07:23 PM
  #197
mchuang's Avatar
I guess I should try it with version 1.29a and see what happens. That was with 1.30. Ill report back.
Old Sep 4, 2007 | 09:37 PM
  #198
mchuang's Avatar
Ok I tested it again using 1.29a and same thing, it started and idled for a sec then died. I downloaded the modded rom you posted tephra added my settings including my immobilizer code by and it matches my backup rom that does work. Good news is I am logging boost successfully thru a motorola 3bar map sensor bad news lol the i cannot test knock patch yet. my settings are 1 for on, then 4 counts to trigger and 20% load and 5000ms
Old Sep 4, 2007 | 09:46 PM
  #199
tephra's Avatar
can you email me both your STOCK rom and your MODDED rom... ill need to do a binary comparison!
cheers
Old Sep 4, 2007 | 09:53 PM
  #200
mplspilot's Avatar
Originally Posted by HmanEVO
I'm having an issue with the "CEL on knock flash time". I have tried a couple different ranges from 1500-3000ms and whenever the required knock sum is met, the CEL will flash but will continue to do so for several minutes before it stops. I read the ecu after every flash to confirm the settings change and they do.
My ROM ID is 94170008. I'm also running ecuflash version 1.31. At first from my reading I thought some of the issues with version 1.31 were limited to the IX definition files. Could it be a problem with ver 1.31 or is there anything else I should be looking at?
Thanks,
Chris
Just happened to me. I initially used 1.31 EcuFlash.
Just installed 1.29a, gonna go for a drive and see if reflashing with 1.29a will cure the problem.
EDIT: Well i'm not sure why the version would matter...I think rom is what matters, i dunno.... In any case i reflashed the rom using 1.29a and the problem stayed. Every time i encounter knock, it'll start flashing and not stop for longer than 5 min...
(rom 94170008)
Old Sep 5, 2007 | 12:12 PM
  #201
HmanEVO's Avatar
(rom 94170008)
I should have tried reinstalling Tephra's patch and continued using 1.31 instead of going to 1.29a. Just to see if it was an error on my part.
Instead I chose to do a complete uninstall of 1.31 and then installed 1.29a. I had accidentally deleted the modified 94170008 xml file and pre-patched rom so I had to start over from scratch. So there's no way of knowing if 1.29a fixed it or if I had made an error patching in Tephra's additional xml the first time. I'm still getting used to ecuflash as a whole, e.g., modifying xml's etc. I was running DSMLink prior.
However it does work properly with 1.29a so I'm leaving it as is for now.
Old Sep 5, 2007 | 12:31 PM
  #202
l2r99gst's Avatar
Nice to see you got it working. I think you will like it. This was one of the features I loved about DSMLink and Tephra made it even better, making it flash and having it configurable with a few parameters.
Now all we need is the NLTS and we will be set.
Eric
Old Sep 6, 2007 | 04:51 AM
  #203
MR Turco's Avatar
I got this flashed last night, definitely very cool mod.
Old Sep 6, 2007 | 01:15 PM
  #204
Vigman's Avatar
It's definitively hard to find the V1.29a!
Mencioned URL is overload...
Please someone send it to me by mail (vigmanevo@gmail.com) and I will publish it without restriction!
Thanx for all of us who are desesparated!
Old Sep 6, 2007 | 04:21 PM
  #205
HmanEVO's Avatar
Here's where I got 1.29a from. Click me
Old Sep 6, 2007 | 05:07 PM
  #206
Vigman's Avatar
Thank you Hman!
I got them all if someone need in the future!
Old Sep 8, 2007 | 08:57 PM
  #207
bnice01's Avatar
just tune a buddies of mine car yesterday rom id 94170014 works like a champ and he is loving it.
just looking for rom id 94170015 now with the patch, thanks tephra you rock
Old Sep 8, 2007 | 09:05 PM
  #208
bnice01's Avatar
tephra I emailed ya a stock 94170015 rom
edit : sorry
Old Sep 8, 2007 | 09:30 PM
  #209
tephra's Avatar
thanks Brandon, ill get around to 15 soonish..
Can you just edit your post to remove my address
cheers
D.
Old Sep 8, 2007 | 09:42 PM
  #210
EvoBroMA's Avatar
can i just do a diff between your pre-patched 88590015, to make a new patch, and then use that diff to patch an already tweaked rom (based on 88590015)?
