2 byte versus Load calc
Old Sep 3, 2007 | 12:32 PM
  #31
ThEHiTMaN's Avatar
Those are 3rd gear logs?
Old Sep 3, 2007 | 08:55 PM
  #32
mrfred's Avatar
Originally Posted by Whoop_ass
here is the log mr fred
and i have attached the EVOSCAN xml
i did notice even when i logged with my other laptop it was the same.
Your 2-byte load def in EvoScan looks fine. I still think that your measured 2-byte loads is not correct though. I think that its your aftermarket airbox causing erroneous load values.
Old Sep 3, 2007 | 10:51 PM
  #33
Whoop_ass's Avatar
I would agree there but the i have looked at other logs with the stock airbox and load calc is the same.
so how can load calc remain the same and 2 byte be so different?
ye this is 3rd gear up a hill
Old Sep 4, 2007 | 07:56 AM
  #34
Tuner@Swift's Avatar
Loadcalc will be the same between airboxes because it DOES NOT take into consideration MAF frequency. Since you only changed the intake and not injector scaling or latency or voltage, then loadcalc will not change.
2byte load DOES include MAF frequency. So if you change the intake, which WILL effect MAF frequency, then ECU calculated load(2byte) will change.
Old Sep 4, 2007 | 08:29 AM
  #35
mrfred's Avatar
Did you estimate load from your timing table?
Old Sep 4, 2007 | 10:25 AM
  #36
Whoop_ass's Avatar
Hmm so you reckon i got to rescale the maf then!!!
OMG that is a ball acke and not something i want to do.
Old Sep 4, 2007 | 10:26 AM
  #37
Whoop_ass's Avatar
I don't understand what you mean mrfred??
Old Sep 4, 2007 | 11:00 AM
  #38
DanInPA's Avatar
Based on your logs it shows "Timing" of 4, 5, or 6 for 3500 RPM or above before 4000 @ over 300 load. It is very inconsistent while there were no knock sum count. That is very strange.....
If you look at timing table, what do you see for "Load=300" & "RPM=3500"?
I bet you that "LoadCalc" is close to the actual timing ran in your car (based on your timeing table - High Octane Ignition Table. I suspect that EDM ECU does not like 2byte-Load Mod...
Old Sep 4, 2007 | 11:41 AM
  #39
al\lupo's Avatar
No, I'm running 2-bytes load on EDM IX with no problems. It seems to really be a MAF issue (my car has stock intake - only filter is non stock).
Old Sep 4, 2007 | 12:22 PM
  #40
DanInPA's Avatar
Oh, I see.... That would make sense... Perhaps, MAF reading is fluxuating with aftermarket intake..... But... then, ECU must have interpreted around 300 Load (if 2byte load was accurate)...
Why would there be flexuation of timing when there were no "knock sum" registered? I really don't understand how it can have 4, 5, & 6 for "Timing Advance" unless there were knock sum registered prior to these RPM (3500) to cause timing to be reduced.........
Old Sep 4, 2007 | 02:23 PM
  #41
mrfred's Avatar
Post your timing table, and I'll show you what I mean.
Old Sep 4, 2007 | 10:36 PM
  #42
Whoop_ass's Avatar
i understand what you mean!!
and yes it does seem as if my load and timing lines up but i will post up the timing table
thanks
Old Sep 5, 2007 | 08:59 AM
  #43
Mellon Racing's Avatar
please don't post the timing map if it's mine
Old Sep 5, 2007 | 02:25 PM
  #44
Whoop_ass's Avatar
then lets try rescale the MAF mellon
No_Skillz
May 8, 2015 10:34 PM
Anubis18
Jun 23, 2013 11:43 AM
JorgeYaHeard
Aug 2, 2011 10:42 AM
sponners
Jun 10, 2008 04:50 PM
mexevo
Dec 19, 2007 11:38 AM
