PATCH: NLTS + Valet + KnockCEL
Old Dec 4, 2007 | 08:40 PM
  #901
TTP Engineering's Avatar
Originally Posted by High_PSI
OK the settings are INDEED self explanitory but I still wanted other peoples settings to see what's up so I'll just post mine in order.
Above is a Simple screan shot of my settings. There are 9 boxes that I checked off and 9 boxes with settings in each. I listed the boxes starting from left going to right in columns from top to bottom. Well do this by the Numbers.
  1. The 1st box is the Tephra mod options, all set to 65535 which seems to be some sort of default number. I was led to believe that any number above 0 activates these mods so leaving them at 65535 will obviously activate them.
  2. Knock Sum. Simple enough set to 3.
  3. Load required? No idea I just left it alone as it came, "2..." whatever that is.
  4. CEL on Knock Flash Time. Set in Mili-seconds so I set 10000 or 10 seconds
  5. Valet Rev Limit. 3000, simple enough to keep junior outa the boost.
  6. Valet Rev Limit Time to Activate. Again 10000 Mili-seconds or 10 seconds. This mod is activated by setting the ignition key to "ACC" or Accessories and then flooring it for 10 seconds. After this RPMS will refuse to go past 3000 rpms. I bet this would really help out MPG.
  7. NLTS RPM DROP. I set mine to 1200, seems like a proper setting to me.
  8. NLTS TPS Threshold. I set mine to 95%, seems good enough and will probably take a couple 10th's off if done right.
  9. NLTS Speed Threshold. Set it to the reccomended 30KMH, or what 18MPH?
You are not using the correct map. You have to select the correct tephra map and then cut and paste your settings into it.
65535 means the feature does NOT exist in the map
Old Dec 4, 2007 | 08:44 PM
  #902
phenem's Avatar
OK the settings are INDEED self explanatory but I still wanted other people’s settings to see what's up so I'll just post mine in order.
Above is a Simple screen shot of my settings. There are 9 boxes that I checked off and 9 boxes with settings in each. I listed the boxes starting from left going to right in columns from top to bottom. Well do this by the Numbers.
6. Valet Rev Limit Time to Activate. Again 10000 Mili-seconds or 10 seconds. This mod is activated by setting the ignition key to "ACC" or Accessories and then flooring it for 10 seconds. After this RPMS will refuse to go past 3000 RPMS. I bet this would really help out MPG.
9. NLTS Speed Threshold. Set it to the recommended 30KMH, or what 18MPH?
Check out my how-to: https://www.evolutionm.net/forums/sh...d.php?t=300454
That should help you out...
~Z
Old Dec 4, 2007 | 09:14 PM
  #903
High_PSI's Avatar
WHAT? Now I am confused once again. What MAP? I thought this was just a patch that edited my current map? I followed every step, downloaded the patch to my map, edited the tables so that the Tephra mods came up, and now they won't work? It said "Download your ROM patch as shown below". That's what I did.
I'm really lost now.
Old Dec 4, 2007 | 09:19 PM
  #904
tephra's Avatar
/play family feud sound affect - 'bwom bwooom':
see 65535? notice how it wasnt 1 or 0? I suspect the other values for KnockSum and Timouts were also "weird"??
this means you arn't actually loading a modified .bin/hex into ecuflash
Old Dec 4, 2007 | 09:24 PM
  #905
whitersevo's Avatar
^^^^ this looks great... cant wait for my rom to come out.. Thanks Tephra
Old Dec 4, 2007 | 09:27 PM
  #906
High_PSI's Avatar
Great, so how do I fix that? This also explains my confusion earlier. God damnit
DISCLAIMER:
If you don't understand ANY of this DON'T FLASH, please ask questions in this thread! Also if you get ANY WEIRD/UNEXPECTED results then flash back to stock! If your car explodes don't blame me
Help???
Old Dec 4, 2007 | 09:30 PM
  #907
tephra's Avatar
in the zip file there was a .bin file as well...
just open that .bin file right up and you should see some sensible values for my mods...
then just copy all your current settings/maps from YOUR rom to the new rom (including immob codes) and then flash the new rom...
Old Dec 4, 2007 | 09:44 PM
  #908
High_PSI's Avatar
It won't let me open the BIN file. That's for sure.
Old Dec 4, 2007 | 09:46 PM
  #909
tephra's Avatar
dude :P
did you follow the Guide in the other thread?
Old Dec 4, 2007 | 09:57 PM
  #910
High_PSI's Avatar
I Just did it again to my stock map. Followed the steps 1 by one, and I got exactly the 100% same result. I have no idea why this is happening?
HELP?
Old Dec 4, 2007 | 10:04 PM
  #911
High_PSI's Avatar
Wait, I almost got it, HOLD ON HOLD ON!!!!!!!!!!
Turns out my ZIP program wasn't "Unzipping". I had to delete it and redown load it, it now works so lets see what happens. This is why my bin file would not open, and now it does
Stupid..........
Old Dec 4, 2007 | 10:34 PM
  #912
High_PSI's Avatar
OK I think I got it. Only thing that MAY be an issue now is my injector scaling. Some have no values, some have 513, does it matter or is it irrelevant?
Old Dec 4, 2007 | 10:39 PM
  #913
kayman's Avatar
dude you dont open your stock rom.. u open Tephra's rom and move your maps / scalings etc into it and then adjust his mod section, you also have to adjust the xml file.
Old Dec 4, 2007 | 10:41 PM
  #914
High_PSI's Avatar
I got that, passed that part. It was an issue with my ZIP. I wasn't even able to open the file, now I can.
Thanks for the tip.
Old Dec 5, 2007 | 09:40 AM
  #915
There is only one box to adjust scaling. The one with the number in it. Honestly you are probably better off having a vendor fix your issues and help you along the way.
