How To Tune an Evo
Old Sep 11, 2008 | 06:38 PM
  #541
Jack_of_Trades's Avatar
Originally Posted by SpeedJunkyz
Are these guys still around....I couldn't find them.
razolab & touring bubble
SJ
uhh yeah...on here like every day.
Old Sep 11, 2008 | 06:39 PM
  #542
panem's Avatar
good info
Old Sep 11, 2008 | 07:04 PM
  #543
SpeedJunkyz's Avatar
When I searched it said they are not in the database...hmm mmaybe I failed at something hahah
Old Sep 11, 2008 | 08:03 PM
  #544
Well, thats not EXACTLY how their screennames are written. Its TouringBubble (one word) and Razorlab. Those are actual links to their profiles.
Old Sep 11, 2008 | 08:08 PM
  #545
Skyline559's Avatar
This is probably the most helpful thing ive read when it comes to tuning and never even considered that someone could do this by themselves, im seriously considering this, at least the logging part.
Old Sep 14, 2008 | 12:37 AM
  #546
PUN1SHER's Avatar
so much info.... brain overload.... nice write up.
Old Sep 18, 2008 | 10:11 PM
  #547
Seriph's Avatar
Tactrix sells the OpenPort 2.0 cables for $189.00. www.limitless.co.nz/cables sells the OpenPort 1.3U or 1.3B cables for $99.00. Is there an advantage of one over the other? What are the differences?
Old Sep 23, 2008 | 05:30 AM
  #548
MR Turco's Avatar
ok i am tired of looking at the 11000 rpm in my timing map. Can i change it or is it a bad address? I am using ecuflash 1.35 so i have a feeling it was set in 1.29 and carried over.
Old Sep 23, 2008 | 08:45 AM
  #549
Smoothgangsta's Avatar
I have the 11000 RPM in my timing map also in ECUFlash 1.38
Old Sep 23, 2008 | 11:04 PM
  #550
codgi's Avatar
^^ post a screen shot. But you should be able to lower that just fine. All it means is that when you go past 7500 it will interpolate between that and the values for 11000 really no purpose to have it any higher than whatever you rev limit is since you'll never be able to hit it.
Old Sep 26, 2008 | 05:52 AM
  #551
MR Turco's Avatar
I wasn't sure if it was a bad definition in ECUflash reading a part of the rom it shouldn't be. If so changing it could cause other issues.
Old Sep 26, 2008 | 07:07 AM
  #552
bigric09's Avatar
you running a big turbo ? i apologize if i missed anything you have posted. too much to go back and read. Just looking at your timing map and guessing that that is the case.
Old Sep 26, 2008 | 07:14 AM
  #553
MR Turco's Avatar
stock turbo 25/26psi. why does it look conservative?
Old Sep 26, 2008 | 07:18 AM
  #554
sharkm87's Avatar
i belive we all ahve that 11000 in our timing map...why is it bothering you
Old Sep 26, 2008 | 07:19 AM
  #555
MR Turco's Avatar
i dunno, it just looks weird. I just find it weird that the stock timing map would account for 11k rpm. and yes i understand that it would interpolate between 11krpm and 7500, i just find it odd.
