Let's see your fully tuned timing maps
Old May 16, 2013 | 11:42 AM
  #2251
domyz's Avatar
Originally Posted by aggieEVO
Hey Guys,
Here's my first map. It's FAR from fully tuned. I just spent some time scaling it to suit my car for right now. There were some goofy little sections where timing went up and down. I smoothed things out the best I could. I'm hoping to do some logging this weekend and actually make a few changes. Let me know if I did anything stupid.
Again, this is a stock Tephra V7 Evo 8 map scaled, interpolated, and smoothed out.
-Some jumps are still too harsh.
-Too much negative timing at peak load (2000-3250RPM, 220+ load)
-Also you could maybe reduce timing at 6500+ RPM / 200-250 load
-Cruise timing is quite low.
Old May 16, 2013 | 11:59 AM
  #2252
aggieEVO's Avatar
Thanks for the input.
Where are the harsh jumps? Maybe I'm missing them.
As far as your other suggestions, I haven't actually tried to tune anything out, yet. Just smoothing the stock map. I'm hoping just to take care of some knock this weekend. I don't have my wideband, yet, so I won't be doing any A/F tuning, yet.
Old May 16, 2013 | 07:34 PM
  #2253
211Ratsbud's Avatar
aggie, keep an eye on the 3d shape. this is an example map. you are on teh right track, once you start tuning and seeing where the timing needs to be WOT you will be in good shape.
i did this from a stock map, and its my next flash. the values are +-1 or 2 degrees every where else but the WOT power curve which is identical from my current working maps, Where I am not, has been an evolution of the same map shape for two years, so I started back with a stock map and worked from there.
Attached Thumbnails Let's see your fully tuned timing maps-smoothed-stock-map-v7.png
Old May 16, 2013 | 07:35 PM
  #2254
domyz's Avatar
Yes the harsh jumps I speak of would be easy to see in the 3d graph
rats I absolutely hate your colors (is this actually a joke?)
Old May 16, 2013 | 08:05 PM
  #2255
211Ratsbud's Avatar
Can't seem to find a good color scheme
+ I share the most common form of color deffficient vision. I'd love something very high contrast.
Old May 16, 2013 | 08:42 PM
  #2256
domyz's Avatar
Ok I understand. I love Yellowpurpl at the end of the list. That's our friend Raptord who used that in the first place and I found it really easy to see.
Old May 16, 2013 | 11:06 PM
  #2257
steven121's Avatar
[QUOTE=domyz;10809819]-Some jumps are still too harsh.
-Cruise timing is quite low.[/QUOTE
Hes right i posted my map in here last few pages check out my rom, you want a smooth transition every where no more than 3 degrees timing between when rpm increases. I still have to change mine someone mentioned at peak rpm keep timing 1-2 degrees not so many jumps
Your peak load at whatever rpm should be around 3-4 degrees then work your way from there but as your load decreases and rpm increased add a degree, but your redline rpm and lowest load point yor car goes to should be around at 10-13 degrees not sure where mine is at
Refer to merlins evo tuning i think highst degree of timing is 13-15 at peak rpm and lowest load "7000 rpm load =220 fall off"
Old May 17, 2013 | 03:44 AM
  #2258
211Ratsbud's Avatar
Eek peak load at 3-4 degrees is rough. If anything on 93 start with 1 degree and go from there... 3-4 could be peak torque but even that sounds high to start with.
I do this for my car: 250 rpm increments, 1 peak load 3500 , and 13-14 up top usually 7000. Interpolate vertically and that's an easy timing ramp.
Every car is different and an 8 is gonna be even more so. But that's my merhod and I'm just sharing.
Old May 17, 2013 | 06:00 AM
  #2259
Raptord's Avatar
I did?
I never remember which color scheme I'm using.
Old May 17, 2013 | 07:34 AM
  #2260
211Ratsbud's Avatar
Does the new version of ecu flash have newer colors? I'm on 1.42
Old May 17, 2013 | 08:50 AM
  #2261
domyz's Avatar
Dunno but you still can edit display min/max values of the table scaling to adjust colors.
Old May 18, 2013 | 05:29 PM
  #2262
211Ratsbud's Avatar
Bumped the cruise timing up to 44* and the car feel much smoother, same with mivec at full advance .
Would be nice to have empirical data for reasoning but
Old May 18, 2013 | 10:09 PM
  #2263
vmrevo9's Avatar
Veteran: Air Force
Whats the benefit of running that much timing at cruise? I would imagine response and fuel economy?
Old May 18, 2013 | 10:37 PM
  #2264
MercenaryX2's Avatar
That's about it but that is alot of timing. I wouldn't run that high unless my pistons, comb. chamber and exhaust valves were ceramic coated. Too much heat going on right there...
Old May 19, 2013 | 12:28 AM
  #2265
domyz's Avatar
Stock is 40* with EGR advance if I remember correctly. I don't think 44* is going to create too much heat to burn up something (engine was opened to do headgasket a year ago, and cylinders walls were still mirror looking, pistons and valves were really clean at all)
.... but I don't think it will yield much MPG gain. What is widely known here is that for running high cruise timing and get better MPG you need to run leaner AFR aka open loop.
I run full time open loop (15,7afr) and 42* and I gained about 5% economy. Not too much but still enough to be worth the long tuning process. Also you don't need to mess anymore with the trims which is good for me: I'm in the process of converting to speed density and that open loop mode is really making things simple. Little note about SD, the throttle response is awesome for now, I can't believe my car is smooth like that. Throttle release is completely another world vs MAF, no more major decceleration/bucking when BOV opens.
sorry if my english is bad,
