Let's see your fully tuned timing maps
Old Apr 9, 2014 | 06:21 PM
  #2521
jeffbeagley's Avatar
Originally Posted by foxbat
Looks very smooth, I'd like to see a wot log, I'm wondering, is 2* too low at peak TQ/load for E85?
I have changed the map slightly. I'm having a bit of a fuel issue past 7500 rpms I haven't been able to figure out yet, will have to figure that out soon.
I appreciate everyone taking a look at it.
Old Apr 9, 2014 | 07:49 PM
  #2522
detroit pistins's Avatar
Jeff, What is ur fuel setup consisting of?
Old Apr 9, 2014 | 08:45 PM
  #2523
Just installed a buschur double pumper. I've tested the hobbs switch and the pump kicks on, it's making me wonder if maybe the pumps are failing. I'm seeing some awkwardly high IDC for ID2000s
Old Apr 9, 2014 | 09:22 PM
  #2524
mavraolan's Avatar
Originally Posted by Raptord
I just mean what peak load you are reaching and at what rpm, and what it tappers to at 7k rpm.
Not sure that I understand I am new as far as concerning those things!
I guess there will be some way to log peak load at any given rpm from evoscan!?? From that report I can then make the necessary changes for some low end torque!??
Old Apr 10, 2014 | 05:19 AM
  #2525
Raptord's Avatar
You need to log 1byte Load in evoscan
Old Apr 10, 2014 | 07:06 AM
  #2526
mavraolan's Avatar
ok i understand! I logged 1byte Load in evoscan last time I made some logs but I didn't know what was that You mean 1byte Load in curve style....what I did was normal 1byte Load like the log I have attached
Old Apr 10, 2014 | 10:13 AM
  #2527
mavraolan's Avatar
Raptord if I change the alt base wastegate duty the alt lo octane ignition map will automatically makes some changes (and vise reversal) ! Is that normal?
Old Apr 10, 2014 | 10:57 AM
  #2528
Raptord's Avatar
Sorry but I don't understand what you're saying.
Old Apr 10, 2014 | 11:21 AM
  #2529
mavraolan's Avatar
Yesterday as you saw I fixed/smoothed my alternate hi/lo octane ignition maps. When I compared it with the previous one (that is before I smoothed the maps) I found out that
alternate base wastegate duty 1,2 also change. I didn't touch those maps. So every time I corrected wastegate maps, timing maps automatically were changed at some points. When I was fixing the timings maps back again, wastegate maps were change again. So I did timing maps as yesterday and I left wastegate maps changed on its own. Why? Does this ecuflash has the ability to correct/adjust between those two maps?
Old Apr 10, 2014 | 12:47 PM
  #2530
Raptord's Avatar
Something's wrong with your definition if changing timing maps also changes your boost tables...
Old Apr 10, 2014 | 11:55 PM
  #2531
mavraolan's Avatar
I tried other 88570008.xml files but is the same. Boost changes as I change the timings maps. Basicaly Lo octane ign timing map is changing.
I have attached the file that I am using. If you could try it would be great! Or if you have a different file that you could send me I would appreciate it!
Thank you
Old Apr 11, 2014 | 07:27 AM
  #2532
mavraolan's Avatar
Seriously! Never happens to anyone ????
Old Apr 11, 2014 | 10:37 AM
  #2533
I don't have any experience besides 9417/9653 but I'd suggest removing everything out of your rommetadata folder, starting over with a fresh ROM AND a new xml. Copy all your old tables over and see if it continues doing it.
To prevent clutter on this thread, I'd recommend starting a new one and we can all help you out there!
Old Apr 11, 2014 | 12:42 PM
  #2534
mavraolan's Avatar
Ok.... Thx buddy
Old Apr 27, 2014 | 01:42 AM
  #2535
mavraolan's Avatar
My new timings
How does this look like? I will try it next weekend so any suggestions are welcome. I will use this combining with JDM RS MIVEC map.
how do u guys post the larger pictures from ecuflash?
