Let's see your fully tuned timing maps
Old Dec 1, 2007 | 06:56 AM
  #121
honki24's Avatar
Originally Posted by aznj
Honki24's pic......
why would you want to run it so lean in that low load- high rpm block?
sorry if this is a newb question..... atmospheric bov maybe?
I do have lean spool disabled. I have the APS dual vent BOV and leaning out when I snap off throttle helps recovery speed (when not using NLTS)
(easy answer: yeah basically it's to compensate for the VTA aspect of the APS BOV) <APS diverts and vents>
Old Dec 1, 2007 | 12:04 PM
  #122
9sec9's Avatar
Originally Posted by razorlab
You can basically add as much timing as you want with VP Import. It just refuses to knock. However, at the same time, you need to know when to stop. If you aren't seeing 5+ or so gains per 1 degree you need to stop. I think I remember reading that 9sec9 added a couple degrees even after he only saw 1-2hp gains. I think that's crossing over into dangerous territory but his car is making some power.
16* at peak torque and 30* up top is nuts, I've heard some horror stories of VP import in the wrong hands. Hopefully 9sec9 doesn't become one of them because he seems like a really good guy.
That's close, but if you read it closely, it says that I added 1 degree and picked up 1-2whp, then later added another 1 degree and picked up another 1-2. It actually gained 5 whp from 440 to 445 with the 2 degrees added in some places and 1 of the 2 added backed out in a few places. When I get to get back to the tuning, I'll probably change the 30 to 29 at very top rpm. Basically, only 1-2 degrees added in a few places with overall gain of 5 whp. Thanks for the comments concerning the 'good guy'. I need all the help I can get.
Old Dec 1, 2007 | 08:43 PM
  #123
Jeff_Jeske's Avatar
I wonder what the power difference would be if you ran the standard EVO/DSM C16 timing map of 8*- 20*.
Seems strange to say all that the majority of your above average power is really a result of VP IMPORT.
Old Dec 1, 2007 | 09:03 PM
  #124
subrwho's Avatar
My map:
Xs fmic, injen licp, walbro fp, hks turbo back, 10.5 hotside, hks intake,Forge dv, megan o2 housing and manifold, boost at 22.5 with hallman pro
mymap.jpg?t=1196571673
Old Dec 3, 2007 | 03:49 PM
  #125
9sec9's Avatar
Jeff_Jeske, I don't say that. I think that many posters have LOOKED for a reason that we make more power, and settled on the Import. If I'm asked, I say that it's a combination of GOOD parts and a GOOD tune on EXCELLENT fuel. Then mix in about 25% luck. I do feel that the Import was an enabler, but the fuel alone won't make the power.
edit: I forgot to say that power would drop off dramatically with 8*/20*. I see sizeable power losses when using 24-25 uptop. I also gained 25 Mustang whp in the tune, with a lot of it being in the timing/h20-meth areas.
Old Dec 3, 2007 | 06:04 PM
  #126
Jeff_Jeske's Avatar
LOL.... I know what you mean... that probably was a little rough.
What does the car make on 101 octane?
Old Dec 3, 2007 | 10:06 PM
  #127
Duh Panda's Avatar
how the hell do you get a pic of your maps...? im tryin but theres no way
Old Dec 3, 2007 | 10:10 PM
  #128
recompile's Avatar
1) Open the map
2) Hold ALT and hit PRTSCN
3) Open Paint from Start > Programs > Accessories
4) Go to Edit > Paste
5) Crop & Save the pic as PNG
Old Dec 3, 2007 | 10:14 PM
  #129
Owens Racing's Avatar
Originally Posted by tephra
guys save as PNG - jpg artifacts too much
Originally Posted by ShamelessCookie
Bring up your map and hold ALT and hit PRTSCN
Now Start > Run > mspaint
Hit CTRL + V to paste it in. Save it as a JPEG. Upload and you're done!
Read the thread man! lol
Old Dec 3, 2007 | 10:58 PM
  #130
Duh Panda's Avatar
mods are 3" tbe, walbro hpf255, Jdm Bov, Ams frontmount with lower piping, k&n drop in, greddy profec b, Act hdss with prolite flywheel,
what do you guys think?
91 octane and 21 psi
Old Dec 4, 2007 | 12:58 AM
  #131
codgi's Avatar
^^ thats a huge block of 7s...this your own map from scratch? Or one you had done and are now fixing up?
Relatively conservative for 92 Octane and 23psi, here's mine:
Old Dec 4, 2007 | 02:42 AM
  #132
Wicked E's Avatar
I agree...
There's some more power to be made in that timing map for sure... I'm scratching my head trying to figure out why the apparent love for the number 7 shows up in that map...
Old Dec 4, 2007 | 07:15 AM
  #133
Jeff_Jeske's Avatar
^ If he were to trace a full throttle pull I doubt the 7s would be used much. It just looks overly blocked. In action I'm sure its just fine.
Old Dec 4, 2007 | 08:18 AM
  #134
Duh Panda's Avatar
im learning hahah!!! anyone have any suggesttions on improving?
Old Dec 4, 2007 | 12:19 PM
  #135
Panda, I am new to the ECU tuning. I would suggest doing some pulls and logging the info. Set out you load cell and rpm and see where your at on the AFR's. Also as for timing see where it loads at and if no knock add a degree in the area of load.
Anyone that is a guru chime in and tell me if this is wrong. Pretty sure this is the right way to approach tuning though.
