economy tuning
Old Jul 29, 2008 | 08:22 PM
  #256
mrfred's Avatar
Originally Posted by nj1266
How did you calculate your mpg? What I do is fill up the tank and top it off by 0.5 gallon after the first cut-off of the nozzle. Then I drive until the light comes on and re-fill from the SAME gas station and the SAME pump using the same proceedure.
So far I have averaged 26 mpg in two tanks with 70/30 freeway/street driving. I drive the speed limit or slightly less. Here in SoCal the speedlimit is 65 mph. I do not go into boost and keep the car in max amount of vaccum on the gauge.
What rpm range do you tend to hold?
Old Jul 30, 2008 | 03:11 AM
  #257
pltek's Avatar
so i have 03 with rom 94170008. my Open Loop Throttle Low and High Load tables are not set in percentages, they go between 3.01 and 1.70 (which i belive is volteage?)
how do i interpret that in percentage of open throttle to adjust table to an equivalent 30%?
Thanks
Originally Posted by JohnBradley
This is approximate as WB and mods will affect where you need to be of course
Old Jul 30, 2008 | 06:30 AM
  #258
Chabada15's Avatar
dont use the open loop throttle tables, use the open loop load tables
Old Jul 30, 2008 | 07:44 AM
  #259
nj1266's Avatar
I stay at 2800-3000 rpm when cruising @65 mph on the freeway.
Old Jul 30, 2008 | 08:09 AM
  #260
pltek's Avatar
why not use both and have it go into open loop based on certain load and/ or certain tps% or voltage?
Old Jul 30, 2008 | 08:38 AM
  #261
inco9nito99's Avatar
Fill tank full, drive till light comes on and note mileage. Fill tank full again, and take that noted mileage and divide by the amount of gallons the car JUST took to fill up again.
Old Jul 30, 2008 | 08:59 AM
  #262
Chabada15's Avatar
i havnt messed with my throttle tables and no matter how i hit the throttle so long as load doesnt go over my settings it stays open loop...so i figure dont fix what aint broke lol
Old Jul 30, 2008 | 10:45 AM
  #263
pltek's Avatar
gotcha, i just took it as a NO, NO and i did that in my 9 and worked like a charm.
Old Jul 30, 2008 | 11:58 AM
  #264
Chabada15's Avatar
nah man lol do whatever u wanna do, just stating how i managed to get the results i got
Old Jul 30, 2008 | 12:18 PM
  #265
RazorLab's Avatar
that 13.5 at 90-120 load is going to make you run rich as hell on tip in.
Old Jul 30, 2008 | 07:52 PM
  #266
mrfred's Avatar
I'm now messing the MIVEC maps a bit. I tried three different maps today with different values in the lower load cells (load of 100 and below). The first map was essentially the stock map, the 2nd, which has slightly more aggressive advance, was essentially the JDM RS map, and the third, which has yet more advance, was something very close to what nj1266 posted in his "how to tune an Evo" thread. It was very hard to tell the difference between the "moderate" map and the stock map. The most aggressive map gave mild improvements in torque over stock in the 2000 - 2500 rpm range, but it was very mild. I had to do back-to-back runs on the same piece of road to be sure. The two maps are posted below.
That will very likely be it for my MIVEC adjustments for economy tuning. I'm switching over to messing with timing one last time to see if there are any more improvements to be made with yet more timing.
First map: Essentially stock for loads of less than 90
Third map: Similar to nj1266's map for loads of less than 100
Attached Thumbnails economy tuning-mivec-m64v9.gif   economy tuning-mivec-m64v11.gif
Old Jul 30, 2008 | 08:12 PM
  #267
Turbo Kyle's Avatar
Good Info
Old Jul 30, 2008 | 08:50 PM
  #268
tephra's Avatar
I find advancing MIVEC at idle gives better drive-ability off the line.
ie I dont need to rev the car so much to take of in normal traffic.
Old Jul 30, 2008 | 09:04 PM
  #269
nj1266's Avatar
^^^ What are your mivec numbers at idle?
Old Jul 31, 2008 | 07:30 AM
  #270
Chabada15's Avatar
hey guys i just wanted to ask you guys what you were seeing for EGTs during cruise, i have advanced my ignition to about 38* in some areas and im running an average AFR of about 15.6 and when cruise at about 80mph im seeing around 1300* which im not sure if it is high or not, whats an average WOT EGT anyway?
