Patch how-to: manifold air temperature logging
Old Dec 29, 2008 | 12:51 AM
  #181
evo8dad's Avatar
I was able to get everything working and logging correctly. Oddly though I continued to get a P0443 (Evaporative Emission Control System Purge Control). I disabled it though through the Periphery tables but, was curious as to why the DLC would be activated after the patch but, not before. Any thoughts?
Edit: By the way thanks for the help on this
Old Dec 29, 2008 | 08:14 AM
  #182
03whitegsr's Avatar
Last Autronic IAT sensor I installed was an 1/8" NPT plug. MUCH smaller then the GM sensor. Also used a much smaller element, giving it a lower thermal mass allowing it to react quicker to temperature changes. It is a better sensor IMO then the GM open element sensor.
Originally Posted by mrfred
I hate to say it, but making this sensor compatible would be at the very bottom of my list, probably forever. What are the thread dimensions of the Autronic sensor?
Old Dec 29, 2008 | 08:54 AM
  #183
mrfred's Avatar
I was thinking about SD yesterday and was wondering how fast the GM IAT sensor would react. Good info on the Autronic. I may have to order one to check it out.
Old Dec 29, 2008 | 09:40 AM
  #184
MR Turco's Avatar
can someone post a link on where to get the autronic one?
Old Dec 29, 2008 | 09:53 AM
  #185
mrfred's Avatar
Is the customer's car from last night?
Old Dec 29, 2008 | 10:02 AM
  #186
evo8dad's Avatar
Yes it is. I sent him on his way after disabling the code via Peripheries, which has worked but, I was curious to know if there is something I may have carried over wrong like I did with the temp scaling or if this is something new you haven't encountered yet.
He is coming back this Saturday to finish the tune as well as to get some good IC data via the IAT.
Old Dec 29, 2008 | 10:15 AM
  #187
evo8dad's Avatar
I'll double check al the data entry in the .xml file for the patch to make sure I didn't screw anything up.
Old Dec 29, 2008 | 10:20 AM
  #188
03whitegsr's Avatar
I'm not sure if you can order one from Autronic or an Autronic dealer. They are kind of weird about product support and don't like people without an Autronic unit using their pieces.
I should clarify though. The Autronic sensor I installed looked like something they are building in house. It looks to be an element that they potted into an 1/8" NPT plug. It's got a cheap connector (non-weather-tite) on the end of two wires that have been heat shrinked onto the fitting. Pretty ghetto really compared to the GM sensor. This was a few years back and they could be using something different now though.
I just think it's a better sensor becuase it uses a smaller, faster reacting element and is a smaller fitting that's easier to tuck out of view for a cleaner install.
The GM sensor has been proven to work just fine for most of the EVO guys using the AEM and I would bet is a more reliable sensor then the Autronic sensor.
Old Dec 29, 2008 | 11:24 AM
  #189
mrfred's Avatar
I did a little looking and both SDEFI and Megasquirt use the GM IAT sensor as their standard IAT sensor. The Megasquire FAQ mentions that in a few instances, they have seen the bulb on the GM IAT sensor break off when mounted in an intake manifold due to high vibration. Kinda scary.
There are a few other sensors that I came across:
Bosch "039" air temp sensor:
http://www.bosch-motorsport.com/pdf/.../NTC_M12-L.pdf
Magneti Marelli "ATS04" air temp sensor
http://motorsport.magnetimarelli.com...S04_rev5.0.pdf
Both are NTC just like the GM IAT sensor. MM claims the ATS04 sensor is fast, but the bulb on the ATS04 sensor does not appear to be substantially than the bulb on the GM IAT sensor.
Old Dec 29, 2008 | 11:41 AM
  #190
MR Turco's Avatar
Mrfred, what is the sensor that the JDM evos use in the OEM bung? I assume there is a PN for it if it is an OEM part.
Old Dec 29, 2008 | 12:14 PM
  #191
mrfred's Avatar
Good point. I forgot about that MAT sensor. I could find out the PN, but it would be more interesting if someone could first post a picture of the sensor tip.
Old Dec 29, 2008 | 12:27 PM
  #192
MR Turco's Avatar
I cant find a pic anywhere. Does anyone know if the Evo X has an MAT sensor? I have yet to get a good look at the X intake manifold in general. I am hoping someone can get their hands on a JDM MAT sensor or at least a pic of it.
Old Dec 29, 2008 | 01:45 PM
  #193
cpoku's Avatar
Keep up the good work.
Old Dec 29, 2008 | 02:25 PM
  #194
03whitegsr's Avatar
FWIW, the FSM for the X has 2 IAT sensors. 1 intergrated into the MAF and a second that looks like it is in the intake manifold, but it's difficult to tell in the drawing.
Old Dec 29, 2008 | 03:06 PM
  #195
mrfred's Avatar
The JDM Evo IX has the same.w2
