MR560648 defenition??? help
Old Apr 28, 2008 | 04:10 AM
joyce1bro's Avatar
ok so tried to read my rom with ecuflash and suprise, suprise it's telling me something about "could not recognise this ROM image using any of the current definitions"
can anyone tell me what i need to do to get this sorted.. all i want to do is flash a ralliart map to my ecu and tune from there.
i read somewhere that the "MR560648" number is really no use to find the defenition and you need the ROM number.. if so how do i find out what the ROM number is?
can anyone help me step by step to get this thing up and running?
ps im running this ecu in my 98evo 5
thanks
Old Apr 28, 2008 | 05:51 AM
sub7's Avatar
It's identical to my ecu, give e7 jdm definition a try. 98640014
Old Apr 28, 2008 | 01:42 PM
joyce1bro's Avatar
ok will give it a go! also have you had any problems with this defenition as i heard there might be some?
https://www.evolutionm.net/forums/sh...light=evo7+ecu
thanks
Old Apr 28, 2008 | 05:10 PM
joyce1bro's Avatar
bump
Old Apr 28, 2008 | 06:08 PM
tephra's Avatar
You need to work out the ROMID, typically this is found at 0xF52.
In ecuflash do this:
1) Open ROM
2) Select "use Wizard"
3) Select defined from scratch
4) Keep clicking next until you can enter 2 fields (Address and Length)
5) enter F52 for the address and 4 for the length
6) Report back here with the "Identifier", should be something like 88580014 or 96940011 or 88570008 etc etc etc...
Cheers
D.
Old Apr 29, 2008 | 02:14 AM
joyce1bro's Avatar
1) Open ROM
Cheers
D.
i used the 96940011 ROM before i read this message but havent started to flash yet... how can i go back and check to see if this was correct?
i tried deleting the ROM that i saved hoping that it would reset everything and revert back to not identifing the ROM and take me thru the wizard again. but it didnt work
Old Apr 29, 2008 | 04:27 AM
sub7's Avatar
Mate, usually when you'd inherit/create new romid (aka xml), the new romid will store in your Ecuflash\rommedata folder. There should be only 1 xml file. Go ahead and delete that xml and re-open Ecuflash. Open that ROM, you'll get the wizard again.
Old Apr 29, 2008 | 01:34 PM
joyce1bro's Avatar
thanks will give that a go!!
Old Apr 29, 2008 | 06:53 PM
joyce1bro's Avatar
yup my ID ROM is 98640014. can someone tell me if i can flash the evo7 ralliart ROM into this? the ralliart ROM i have has an ID of 92460000.
can i just change my ROM def to the Ralliart one and just flash the HEX file?
Old Apr 29, 2008 | 07:02 PM
tephra's Avatar
no you shouldn't just change the ROMID in the rom!
It's probably not wise to use other ROMID's on your car!
Best bet is to copy the timing and fuel maps from the RA one over your stock one.
Just keep a backup of your stock rom in a couple of different places
Cheers
D.
Old Apr 29, 2008 | 07:28 PM
joyce1bro's Avatar
Cheers
D.
mmmmmm that sucks maaan this is beginning to be alot harder than i first thought
how easy is it to copy the maps? can i use ecuflash or evoscan to do this?
Old Apr 29, 2008 | 08:25 PM
tephra's Avatar
its easy, just use ecuflash.. select the whole map and copy/paste it over the current maps.
really sounds like you need to read the "How to Tune an Evo" Thread thou
Old Apr 29, 2008 | 08:54 PM
joyce1bro's Avatar
hahahaha yeah i spose so... give me an engine thats needs stripping down and i'll be sweet but as soon as you start with the ECU.... man im flying blind
but forums like these help big time.... i'll try copy and paste to see how i go...
thanks again
Old Apr 30, 2008 | 04:28 PM
joyce1bro's Avatar
this is my stock rom hex file... can anyone read it? im getting no fuel, timing or misc maps in ecu flash. where as the other ralliart roms i have do have the maps.
stock_rom.zip
is anyone able to help me with this as i am wanting to flash with a ralliart rom but dont want to change anything until i know my stock rom is safe.
thanks
Old May 1, 2008 | 12:14 AM
sub7's Avatar
https://www.evolutionm.net/forums/sh...light=98640014
mines5
Oct 8, 2016 11:28 PM
bronto11588
20
Jun 15, 2015 12:00 AM
Israel
Jun 26, 2011 04:45 AM
ausratty
Jan 8, 2009 05:13 PM
kryptonitex
Jan 28, 2008 05:45 PM
