TephraMOD V5.10
Old Aug 22, 2008 | 10:03 AM
  #196
evo8kid-VIP's Avatar
i have turbo xs utec but want to reflash have everything to do it i just need to download a map for my car
Old Aug 22, 2008 | 10:23 AM
  #197
steadly2004's Avatar
Read up here bro. https://www.evolutionm.net/forums/sh...d.php?t=302895
Old Aug 22, 2008 | 10:30 AM
  #198
i have a utec hooked in woundering if i should reflash having trouble getting utec set right ......anyone help.
Old Aug 22, 2008 | 11:23 AM
  #199
cossie1's Avatar
Originally Posted by grayw
96260009 all working, but unable to test NTLS due to clutch switch.
You got valet mode sorted then
Old Aug 22, 2008 | 11:49 AM
  #200
grayw's Avatar
Yes mate all sorted The only thing is the CEL light is really dim, so you can only see it at night.
Old Aug 22, 2008 | 01:10 PM
  #201
cossie1's Avatar
Go to halfrauds and get a brighter bulb then
Or just sell up and buy a real evo
Old Aug 22, 2008 | 05:14 PM
  #202
tephra's Avatar
u need to get rid of the UTEC, then get a email-tune from one of guys on here, many to choose from.
Old Aug 22, 2008 | 11:53 PM
  #203
derekste's Avatar
JDM MAP, tephra 5.10, and 1000cc PTEs went down on the car tonight. ROM 96530006.... fuel trims are poopy, but I'll get them dialed in over the next couple of days
Old Aug 23, 2008 | 10:00 PM
  #204
tephra's Avatar
I will be getting 88840017 out this week, and then 8998000 done as well.
Old Aug 24, 2008 | 06:57 PM
  #205
chmodlf's Avatar
AutoXed the snot out of 94170015 today with no issues!
Old Aug 25, 2008 | 01:41 AM
  #206
XBS's Avatar
XBS
Installed 8850015, Fixed the NLTS "..." error with cossies' xml that he posted.
But for some reason I cannot get the NLTS to work, car just jumps to redline.
Tried setting the TPS to 1% speed to 1Km, and Load to 1%, nothing doesn't work, any suggestions?
Car is a IX, using ECU Flash 1.34
Also, installed the MUT 2byte mod, but only the 2byte load works, not the 2byte rpm, any suggestions?
Lastly, what is this 1byte load, is it a more accurate measure of load for evo scan?
Thanks guys, really appreciate the help.
Old Aug 25, 2008 | 05:17 AM
  #207
Darwinn's Avatar
May be faulty clutch sensor?
Old Aug 25, 2008 | 09:10 AM
  #208
PessimiStick's Avatar
Also make sure that the master NLTS enable switch is set to 1.
Old Aug 25, 2008 | 10:32 AM
  #209
XBS's Avatar
XBS
You know what, I did not check that! Will check tonight, just assumed it would be automatically enabled.
Any suggestions on the other questions?
Thanks guys!
Old Aug 25, 2008 | 10:35 AM
  #210
1-byte load is just a faster way to get load. Tephra's patch scales the value down so it fits in 1 byte, then queries for that and rescales it back up. That way the ECU only has to output one byte of data for logging instead of two. The values you see should be the same as 2-byte.
