TephraMOD V5.10
Old Oct 14, 2008 | 06:05 AM
  #451
MR Turco's Avatar
Originally Posted by tephra
Yeah I have to do two ROM's 88840017 and 96420011
I will hopefully have the done next week
Tephra, just wondering if you had an idea of release of 96420011
Thanks man!
Old Oct 14, 2008 | 01:22 PM
  #452
cossie1's Avatar
I can confirm that 88570008 fix is working great.
I have just got back from testing all features except for NLTS (UK IX FQ models have no 2nd clutch switch) and Rear 02 Sensor Simulation (as UK IX FQ models don't have a 2nd 02 sensor).
Everything works as it should, another great job Dave
Old Oct 14, 2008 | 01:46 PM
  #453
Mellon Racing's Avatar
donation sent, keep up the good work
Old Oct 14, 2008 | 02:37 PM
  #454
Oracle1's Avatar
I missed this one...
Whats the difference between this version and the original version 5?
Old Oct 14, 2008 | 02:43 PM
  #455
cossie1's Avatar
The orignal had a small bug in it, which ment the alt map timing maps were not scaled correctly, and if you adjusted the boost and wastegate settings it corrupted the low octane timing map.
So he has now corrected it and it's working perfectly.
Old Oct 14, 2008 | 03:11 PM
  #456
Oracle1's Avatar
Oh, more work!!!!
Here we go again...hehe
Old Oct 14, 2008 | 03:28 PM
  #457
tephra's Avatar
96420011 will be out today...
Old Oct 14, 2008 | 03:29 PM
  #458
Oracle1's Avatar
is this correct?
<scaling name="ThrottlePercentage" units="%" toexpr="x/255*100" frexpr="x*255/100" format="%.0f" min="0" max="100" inc="1" storagetype="uint16"/>
Old Oct 14, 2008 | 03:30 PM
  #459
Oracle1's Avatar
do I need a little or big at the end?
Old Oct 14, 2008 | 04:23 PM
  #460
cossie1's Avatar
Originally Posted by Oracle1
is this correct?
Yes
ecuflash 1.29 and earlier use little endian.
1.30 and later use big endian.
But the above line is complete as it is, no need to add anything to the end of it.
Old Oct 14, 2008 | 04:42 PM
  #461
tephra's Avatar
wasn't it:
1.30 and below = little
1.31 and above = big
Old Oct 14, 2008 | 04:58 PM
  #462
AlwaysinBoost's Avatar
[homer simpson voice] WOO HOO!!! [/homer simpson voice]
Old Oct 14, 2008 | 05:03 PM
  #463
cossie1's Avatar
wasn't it:
You could be right, I don't think I ever used anything before 1.30, and when I started to get into ecuflash, it was just as it changed over, so most of the xml's out there were all mixed up anyway
Old Oct 14, 2008 | 05:06 PM
  #464
Lancerguy'03's Avatar
amen to that....just hope it works with the 96420008 ROM ID aswell...
Old Oct 14, 2008 | 06:40 PM
  #465
tephra's Avatar
96420011 UP
Please test it fully guys, I have had a few minor bugs pop up with other ROM's (from the fixes you can see above)
It is important that you report anything that looks funny (like maps) or any behavior that you don't expect. And don't go WOT until you verify cruise/idle is working
