New Maps for Evo 7 and 9
Old Oct 15, 2008 | 05:35 AM
  #181
Evo8uk's Avatar
Unfortunately i cant see what my previous roms values are as theres currently no addresses posted for thermo fan duty on 93660005 (EVO 8 JDM)
Old Oct 16, 2008 | 08:55 AM
  #182
honki24's Avatar
HA HA! I understand a *little* of this stuff!! huzzah!
Thanks Matt!
Old Oct 16, 2008 | 03:00 PM
  #183
Mattjin's Avatar
To verify the control map is working, try dropping the 100% values for 50 and 62 degrees down to zero. What you should notice is by 50 degrees the car should feel alot more alive as the warmup retard is dialled out, as it normally would have felt with the motor at operating temp.
You can zero the whole map, but the point here is to prove that the map is actually functioning correctly as a control map. You can see what we go through when finding new maps. Find the code and what you are pretty sure it does, then go to the car and make changes that will give proof that it is correct. It is very time consuming work.
Old Oct 16, 2008 | 11:04 PM
  #184
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Originally Posted by Mattjin
Ahhh, I just read more carefully. Baro could be the trim. That can be tested, I will just go for a drive up the mountain nearby with a large trim on the map and see the effect. Thanks.
Thermo Fan map for 88590015:
<table name="Thermo Fan Duty" category="Misc" address="4012" type="3D" level="2" swapxy="true" scaling="Percent">
<table name="Conditions" type="Static X Axis" elements="9">
<data>On1</data>
<data>On2</data>
<data>On3</data>
<data>Off1</data>
<data>Off2</data>
<data>Off3</data>
<data>A/C1</data>
<data>A/C2</data>
<data>A/C3</data>
</table>
<table name="Engine Temp" address="7034" type="Y Axis" elements="12" scaling="Temp"/>
</table>
Don't forget to add the Percentage Scale posted elsewhere on this thread.
For the 88580015
X axis is Speed @ 16F0 with scaling x*2 [km/h] = Vehicle speed
But I cannot confirm if this is sequencial as pointers to columns have indexes
therefore it is not ascending linear.
Old Oct 17, 2008 | 03:35 AM
  #185
acamus's Avatar
Originally Posted by mrfred
For the Evo 9 - 88580015
<table name="Ignition Trim vs Engine Temp" category="Timing" address="3c80" type="2D" level="2" scaling="Enrich">
<table name="Engine Temp" address="71ca" type="X Axis" elements="8" scaling="Temp"/>
</table>
Table is never called, so it is unused.
<table name="Ignition Trim vs Air Temp" category="Timing" address="3c8e" type="2D" level="2" scaling="Enrich">
<table name="Air Temp" address="71ca" type="X Axis" elements="8" scaling="Temp"/>
</table>
Table is called. Will check it out.
Still looking over other tables...
I have been looking around in my ROM and found this interesting part in which
all of these MAPS are guarded by either immo/init code. So I think they are of importance, some are for obvious reason (AFR, IGN) but it seems there are still some white spaces in major maps
For the 88580015 looks like
Code:
ROM:00008270 off_8270:       .data.l unk_3D1E        ; DATA XREF: sub_1D302:off_1D374o
ROM:00008270                                         ; sub_1D496:off_1D4ECo
ROM:00008274                 .data.l unk_3D1E
ROM:00008278                 .data.l unk_3D1E
ROM:0000827C                 .data.l unk_3D1E
ROM:00008280                 .data.l unk_3D1E
ROM:00008284                 .data.l unk_3D1E
ROM:00008288                 .data.l unk_3D1E
ROM:0000828C                 .data.l unk_3D1E
ROM:00008290 off_8290:       .data.l unk_3D2C        ; DATA XREF: sub_1D302:off_1D380o
ROM:00008294                 .data.l unk_3D2C
ROM:00008298                 .data.l unk_3D2C
ROM:0000829C                 .data.l unk_3D2C
ROM:000082A0                 .data.l unk_3D2C
ROM:000082A4                 .data.l unk_3D2C
ROM:000082A8                 .data.l unk_3D2C
ROM:000082AC                 .data.l unk_3D2C
ROM:000082B0 off_82B0:       .data.l unk_3D32        ; DATA XREF: sub_1EBE6:off_1EC24o
ROM:000082B0                                         ; sub_1F2C6:off_1F354o ...
ROM:000082B4                 .data.l unk_3D32
ROM:000082B8                 .data.l unk_3D32
ROM:000082BC                 .data.l unk_3D32
ROM:000082C0                 .data.l unk_3D32
ROM:000082C4                 .data.l unk_3D32
ROM:000082C8                 .data.l unk_3D32
ROM:000082CC                 .data.l unk_3D32
ROM:000082D0 off_82D0:       .data.l unk_3D40        ; DATA XREF: sub_1F2C6:off_1F358o
ROM:000082D4                 .data.l unk_3D40
ROM:000082D8                 .data.l unk_3D40
ROM:000082DC                 .data.l unk_3D40
ROM:000082E0                 .data.l unk_3D40
ROM:000082E4                 .data.l unk_3D40
ROM:000082E8                 .data.l unk_3D40
ROM:000082EC                 .data.l unk_3D40
ROM:000082F0 off_82F0:       .data.l unk_2DB2        ; DATA XREF: sub_17D14:off_17E04o
ROM:000082F0                                         ; sub_17D14:off_17E18o
ROM:000082F0                                         ; high octane AFR
ROM:000082F4                 .data.l unk_2DB2        ; high octane AFR
ROM:00008310 off_8310:       .data.l unk_2EEA        ; DATA XREF: sub_17D14:off_17DF4o
ROM:00008310                                         ; sub_17D14:off_17DF8o
ROM:00008310                                         ; low octane AFR
ROM:00008314                 .data.l unk_2EEA        ; low octane AFR
ROM:00008318                 .data.l unk_2EEA        ; low octane AFR
ROM:0000831C                 .data.l unk_2EEA        ; low octane AFR
ROM:00008320                 .data.l unk_2EEA        ; low octane AFR
ROM:00008324                 .data.l unk_2EEA        ; low octane AFR
ROM:00008328                 .data.l unk_2EEA        ; low octane AFR
ROM:0000832C                 .data.l unk_2EEA        ; low octane AFR
ROM:00008330 off_8330:       .data.l unk_3A9E        ; DATA XREF: ROM:off_1BD1Co
ROM:00008330                                         ; ROM:off_1BD24o ...
ROM:00008330                                         ; some ign map
ROM:00008334                 .data.l unk_3A9E        ; some ign map
ROM:00008338                 .data.l unk_3A9E        ; some ign map
ROM:0000833C                 .data.l unk_3A9E        ; some ign map
ROM:00008340                 .data.l unk_3A9E        ; some ign map
ROM:00008344                 .data.l unk_3A9E        ; some ign map
ROM:00008348                 .data.l unk_3A9E        ; some ign map
ROM:0000834C                 .data.l unk_3A9E        ; some ign map
ROM:00008350 off_8350:       .data.l unk_3C6A        ; DATA XREF: ROM:off_1AD38o
ROM:00008350                                         ; ROM:off_1BD74o
ROM:00008354                 .data.l unk_3C6A
ROM:00008358                 .data.l unk_3C6A
ROM:0000835C                 .data.l unk_3C6A
ROM:00008360                 .data.l unk_3C6A
ROM:00008364                 .data.l unk_3C6A
ROM:00008368                 .data.l unk_3C6A
ROM:0000836C                 .data.l unk_3C6A
ROM:00008370 off_8370:       .data.l unk_304A        ; DATA XREF: ROM:off_15DA4o
ROM:00008374                 .data.l unk_304A
ROM:00008378                 .data.l unk_304A
ROM:0000837C                 .data.l unk_304A
ROM:00008380                 .data.l unk_304A
ROM:00008384                 .data.l unk_304A
ROM:00008388                 .data.l unk_304A
ROM:0000838C                 .data.l unk_304A
ROM:00008390 off_8390:       .data.l unk_2D76        ; DATA XREF: ROM:off_121BCo
ROM:00008390                                         ; ROM:off_121C0o ...
ROM:00008394                 .data.l unk_2D76
ROM:00008398                 .data.l unk_2D76
ROM:0000839C                 .data.l unk_2D76
ROM:000083A0                 .data.l unk_2D76
ROM:000083A4                 .data.l unk_2D76
ROM:000083A8                 .data.l unk_2D76
ROM:000083AC                 .data.l unk_2D76
ROM:000083B0 off_83B0:       .data.l unk_30EC        ; DATA XREF: ROM:off_18A90o
ROM:000083B4                 .data.l unk_30EC
ROM:000083B8                 .data.l unk_30EC
ROM:000083BC                 .data.l unk_30EC
ROM:000083C0                 .data.l unk_30EC
ROM:000083C4                 .data.l unk_30EC
ROM:000083C8                 .data.l unk_30EC
ROM:000083CC                 .data.l unk_30EC
ROM:000083D0 off_83D0:       .data.l unk_30F2        ; DATA XREF: ROM:off_18A8Co
ROM:000083D4                 .data.l unk_30F2
ROM:000083D8                 .data.l unk_30F2
ROM:000083DC                 .data.l unk_30F2
ROM:000083E0                 .data.l unk_30F2
ROM:000083E4                 .data.l unk_30F2
ROM:000083E8                 .data.l unk_30F2
ROM:000083EC                 .data.l unk_30F2
ROM:000083F0 off_83F0:       .data.l unk_30E2        ; DATA XREF: ROM:off_19390o
ROM:000083F4                 .data.l unk_30E2
ROM:000083F8                 .data.l unk_30E2
ROM:000083FC                 .data.l unk_30E2
ROM:00008400                 .data.l unk_30E2
ROM:00008404                 .data.l unk_30E2
ROM:00008408                 .data.l unk_30E2
ROM:0000840C                 .data.l unk_30E2
ROM:00008410 off_8410:       .data.l unk_30E4        ; DATA XREF: ROM:off_19394o
ROM:00008414                 .data.l unk_30E4
ROM:00008418                 .data.l unk_30E4
ROM:0000841C                 .data.l unk_30E4
ROM:00008420                 .data.l unk_30E4
ROM:00008424                 .data.l unk_30E4
ROM:00008428                 .data.l unk_30E4
ROM:0000842C                 .data.l unk_30E4
ROM:00008430                 .data.l unk_3F7A        ; BDEL table y-axis #1
ROM:00008434                 .data.l unk_3F7A        ; BDEL table y-axis #1
ROM:00008438                 .data.l unk_3F7A        ; BDEL table y-axis #1
ROM:0000843C                 .data.l unk_3F7A        ; BDEL table y-axis #1
ROM:00008440                 .data.l unk_3F7A        ; BDEL table y-axis #1
ROM:00008444                 .data.l unk_3F7A        ; BDEL table y-axis #1
ROM:00008448                 .data.l unk_3F7A        ; BDEL table y-axis #1
ROM:0000844C                 .data.l unk_3F7A        ; BDEL table y-axis #1
ROM:00008450                 .data.l unk_3F32        ; BWGDC y-axis #1
ROM:00008454                 .data.l unk_3F32        ; BWGDC y-axis #1
ROM:00008458                 .data.l unk_3F32        ; BWGDC y-axis #1
ROM:0000845C                 .data.l unk_3F32        ; BWGDC y-axis #1
ROM:00008460                 .data.l unk_3F32        ; BWGDC y-axis #1
ROM:00008464                 .data.l unk_3F32        ; BWGDC y-axis #1
ROM:00008468                 .data.l unk_3F32        ; BWGDC y-axis #1
ROM:0000846C                 .data.l unk_3F32        ; BWGDC y-axis #1
ROM:00008470 off_8470:       .data.l unk_33DE        ; DATA XREF: ROM:off_1BD38o
ROM:00008470                                         ; ROM:off_1BD3Co ...
ROM:00008470                                         ; high oct ign map #1
ROM:00008474                 .data.l unk_33DE        ; high oct ign map #1
ROM:00008478                 .data.l unk_33DE        ; high oct ign map #1
ROM:0000847C                 .data.l unk_33DE        ; high oct ign map #1
ROM:00008480                 .data.l unk_33DE        ; high oct ign map #1
ROM:00008484                 .data.l unk_33DE        ; high oct ign map #1
ROM:00008488                 .data.l unk_33DE        ; high oct ign map #1
ROM:0000848C                 .data.l unk_33DE        ; high oct ign map #1
ROM:00008490 off_8490:       .data.l unk_358E        ; DATA XREF: ROM:off_1BD20o
ROM:00008490                                         ; ROM:off_1BD28o ...
ROM:00008490                                         ; low octane ign map #1
ROM:00008494                 .data.l unk_358E        ; low octane ign map #1
ROM:00008498                 .data.l unk_358E        ; low octane ign map #1
ROM:0000849C                 .data.l unk_358E        ; low octane ign map #1
ROM:000084A0                 .data.l unk_358E        ; low octane ign map #1
ROM:000084A4                 .data.l unk_358E        ; low octane ign map #1
ROM:000084A8                 .data.l unk_358E        ; low octane ign map #1
ROM:000084AC                 .data.l unk_358E        ; low octane ign map #1
ROM:000084B0 off_84B0:       .data.l unk_4DD0        ; DATA XREF: ROM:off_193A0o
ROM:000084B4                 .data.l unk_4DD0
ROM:000084B8                 .data.l unk_4DD0
ROM:000084BC                 .data.l unk_4DD0
ROM:000084C0                 .data.l unk_4DD0
ROM:000084C4                 .data.l unk_4DD0
ROM:000084C8                 .data.l unk_4DD0
ROM:000084CC                 .data.l unk_4DD0
ROM:000084D0 off_84D0:       .data.l unk_4DDC        ; DATA XREF: ROM:off_19398o
ROM:000084D4                 .data.l unk_4DDC
ROM:000084D8                 .data.l unk_4DDC
ROM:000084DC                 .data.l unk_4DDC
ROM:000084E0                 .data.l unk_4DDC
ROM:000084E4                 .data.l unk_4DDC
ROM:000084E8                 .data.l unk_4DDC
ROM:000084EC                 .data.l unk_4DDC
ROM:000084F0 off_84F0:       .data.l unk_5234        ; DATA XREF: ROM:off_18A9Co
ROM:000084F4                 .data.l unk_5234
ROM:000084F8                 .data.l unk_5234
ROM:000084FC                 .data.l unk_5234
ROM:00008500                 .data.l unk_5234
ROM:00008504                 .data.l unk_5234
ROM:00008508                 .data.l unk_5234
ROM:0000850C                 .data.l unk_5234
ROM:00008510 off_8510:       .data.l unk_5240        ; DATA XREF: ROM:off_18A94o
ROM:00008514                 .data.l unk_5240
ROM:00008518                 .data.l unk_5240
ROM:0000851C                 .data.l unk_5240
ROM:00008520                 .data.l unk_5240
ROM:00008524                 .data.l unk_5240
ROM:00008528                 .data.l unk_5240
ROM:0000852C                 .data.l unk_5240
ROM:00008530                 .data.l unk_2DB2        ; high octane AFR
ROM:00008534                 .data.l unk_2DB2        ; high octane AFR
ROM:00008538                 .data.l unk_2DB2        ; high octane AFR
ROM:0000853C                 .data.l unk_2DB2        ; high octane AFR
ROM:00008540                 .data.l unk_2DB2        ; high octane AFR
ROM:00008544                 .data.l unk_2DB2        ; high octane AFR
ROM:00008548                 .data.l unk_2DB2        ; high octane AFR
ROM:0000854C                 .data.l unk_2DB2        ; high octane AFR
ROM:00008550                 .data.l unk_2EEA        ; low octane AFR
ROM:00008554                 .data.l unk_2EEA        ; low octane AFR
ROM:00008558                 .data.l unk_2EEA        ; low octane AFR
ROM:0000855C                 .data.l unk_2EEA        ; low octane AFR
ROM:00008560                 .data.l unk_2EEA        ; low octane AFR
ROM:00008564                 .data.l unk_2EEA        ; low octane AFR
ROM:00008568                 .data.l unk_2EEA        ; low octane AFR
ROM:0000856C                 .data.l unk_2EEA        ; low octane AFR
ROM:00008570                 .data.l unk_3A9E        ; some ign map
ROM:00008574                 .data.l unk_3A9E        ; some ign map
ROM:00008578                 .data.l unk_3A9E        ; some ign map
ROM:0000857C                 .data.l unk_3A9E        ; some ign map
ROM:00008580                 .data.l unk_3A9E        ; some ign map
ROM:00008584                 .data.l unk_3A9E        ; some ign map
ROM:00008588                 .data.l unk_3A9E        ; some ign map
ROM:0000858C                 .data.l unk_3A9E        ; some ign map
ROM:00008590                 .data.l unk_3C6A
ROM:00008594                 .data.l unk_3C6A
ROM:00008598                 .data.l unk_3C6A
ROM:0000859C                 .data.l unk_3C6A
ROM:000085A0                 .data.l unk_3C6A
ROM:000085A4                 .data.l unk_3C6A
ROM:000085A8                 .data.l unk_3C6A
ROM:000085AC                 .data.l unk_3C6A
ROM:000085B0                 .data.l unk_304A
ROM:000085B4                 .data.l unk_304A
ROM:000085B8                 .data.l unk_304A
ROM:000085BC                 .data.l unk_304A
ROM:000085C0                 .data.l unk_304A
ROM:000085C4                 .data.l unk_304A
ROM:000085C8                 .data.l unk_304A
ROM:000085CC                 .data.l unk_304A
ROM:000085D0                 .data.l unk_33DE        ; high oct ign map #1
ROM:000085D4                 .data.l unk_33DE
ROM:000085D8                 .data.l unk_33DE
ROM:000085DC                 .data.l unk_33DE
ROM:000085E0                 .data.l unk_33DE
ROM:000085E4                 .data.l unk_33DE
ROM:000085E8                 .data.l unk_33DE
ROM:000085EC                 .data.l unk_33DE
ROM:000085F0                 .data.l unk_358E        ; low octane ign map #1
ROM:000085F4                 .data.l unk_358E
ROM:000085F8                 .data.l unk_358E
ROM:000085FC                 .data.l unk_358E
ROM:00008600                 .data.l unk_358E
ROM:00008604                 .data.l unk_358E
ROM:00008608                 .data.l unk_358E
ROM:0000860C                 .data.l unk_358E
ROM:00008610                 .data.l unk_2DB2        ; high octane AFR
ROM:00008614                 .data.l unk_2DB2
ROM:00008618                 .data.l unk_2DB2
ROM:0000861C                 .data.l unk_2DB2
ROM:00008620                 .data.l unk_2DB2
ROM:00008624                 .data.l unk_2DB2
ROM:00008628                 .data.l unk_2DB2
ROM:0000862C                 .data.l unk_2DB2
ROM:00008630                 .data.l unk_2EEA        ; low octane AFR
ROM:00008634                 .data.l unk_2EEA
ROM:00008638                 .data.l unk_2EEA
ROM:0000863C                 .data.l unk_2EEA
ROM:00008640                 .data.l unk_2EEA
ROM:00008644                 .data.l unk_2EEA
ROM:00008648                 .data.l unk_2EEA
ROM:0000864C                 .data.l unk_2EEA
ROM:00008650 off_8650:       .data.l unk_5D88        ; DATA XREF: ROM:off_1CB34o
ROM:00008654                 .data.l unk_5D88
ROM:00008658                 .data.l unk_5D88
ROM:0000865C                 .data.l unk_5D88
ROM:00008660                 .data.l unk_5D88
ROM:00008664                 .data.l unk_5D88
ROM:00008668                 .data.l unk_5D88
ROM:0000866C                 .data.l unk_5D88
ROM:00008670 off_8670:       .data.l unk_5878        ; DATA XREF: ROM:off_1CB5Co
ROM:00008670                                         ; some ign map
ROM:00008674                 .data.l unk_5878
ROM:00008678                 .data.l unk_5878
ROM:0000867C                 .data.l unk_5878
ROM:00008680                 .data.l unk_5878
ROM:00008684                 .data.l unk_5878
ROM:00008688                 .data.l unk_5878
ROM:0000868C                 .data.l unk_5878
ROM:00008690 off_8690:       .data.l unk_5A28        ; DATA XREF: ROM:off_1CB70o
ROM:00008690                                         ; high oct ign map #3
ROM:00008694                 .data.l unk_5A28
ROM:00008698                 .data.l unk_5A28
ROM:0000869C                 .data.l unk_5A28
ROM:000086A0                 .data.l unk_5A28
ROM:000086A4                 .data.l unk_5A28
ROM:000086A8                 .data.l unk_5A28
ROM:000086AC                 .data.l unk_5A28
ROM:000086B0 off_86B0:       .data.l unk_5518        ; DATA XREF: ROM:off_1CB88o
ROM:000086B0                                         ; high oct ign map #2
ROM:000086B4                 .data.l unk_5518
ROM:000086B8                 .data.l unk_5518
ROM:000086BC                 .data.l unk_5518
ROM:000086C0                 .data.l unk_5518
ROM:000086C4                 .data.l unk_5518
ROM:000086C8                 .data.l unk_5518
ROM:000086CC                 .data.l unk_5518
ROM:000086D0                 .data.l unk_358E        ; low octane ign map #1
ROM:000086D4                 .data.l unk_358E
ROM:000086D8                 .data.l unk_358E
ROM:000086DC                 .data.l unk_358E
ROM:000086E0                 .data.l unk_358E
ROM:000086E4                 .data.l unk_358E
ROM:000086E8                 .data.l unk_358E
ROM:000086EC                 .data.l unk_358E
ROM:000086F0 off_86F0:       .data.l unk_5BD8        ; DATA XREF: ROM:off_1CB38o
ROM:000086F0                                         ; low octane ign map #3
ROM:000086F4                 .data.l unk_5BD8
ROM:000086F8                 .data.l unk_5BD8
ROM:000086FC                 .data.l unk_5BD8
ROM:00008700                 .data.l unk_5BD8
ROM:00008704                 .data.l unk_5BD8
ROM:00008708                 .data.l unk_5BD8
ROM:0000870C                 .data.l unk_5BD8
ROM:00008710 off_8710:       .data.l unk_56C8        ; DATA XREF: ROM:off_1CB60o
ROM:00008710                                         ; low octane ign map #2
ROM:00008714                 .data.l unk_56C8
ROM:00008718                 .data.l unk_56C8
ROM:0000871C                 .data.l unk_56C8
ROM:00008720                 .data.l unk_56C8
ROM:00008724                 .data.l unk_56C8
ROM:00008728                 .data.l unk_56C8
ROM:0000872C                 .data.l unk_56C8
Old Oct 17, 2008 | 03:58 AM
  #186
acamus's Avatar
Ah, one more thing, this makes the map switching an easy job,
but beware that also periphery bits are queried with same index so other locations are used.
Code:
00000FAA                 .data.w h'56DA
00000FAC                 .data.w h'56DA
00000FAE                 .data.w h'56DA
00000FB0                 .data.w h'56DA
00000FB2                 .data.w h'56DA
00000FB4                 .data.w h'56DA
00000FB6                 .data.w h'56D2
00000FB8                 .data.w h'56D2
Old Oct 17, 2008 | 04:05 AM
  #187
Mattjin's Avatar
The speeds have already been found. You just need to log it and slowly increase your speed to see the values.
Old Oct 17, 2008 | 04:11 AM
  #188
acamus's Avatar
There is a slight difference between logging and ability of setting when the column shall be used right?
Old Oct 17, 2008 | 08:10 PM
  #189
ace33joe's Avatar
Fan duty logging rocks! I logged Fan duty and Coolant temp, and found that the fan turns on at 95 degree celcius, instead of 88 at the control map.
Also it turns off below 93 degree celcius.
Is any scaling might be off by 7 degree celcius? (Either I am reading higher coolant temp than Fan control unit does, or temp scaling of Fan control is off by 7?)
Old Oct 17, 2008 | 08:51 PM
  #190
Mattjin's Avatar
I looked through the code to find the actual road speeds but it was taking too much time. Much quicker to test in the field and the results have been repeatable.
If the temps dont line up you should check you are logging the correct data. For Engine Temp I believe the default Request number was 07, but the correct one to log is 10. The formula should be x-40. Just create a new Item and use these values.
Old Oct 17, 2008 | 09:06 PM
  #191
tephra's Avatar
yeah Evoscan uses funny MUT's to log air/coolant temps.
New evoscan has "scaled" verison which are more accurate and what the ECU actually uses...
  #192
mfr122887's Avatar
nvm
Old Oct 18, 2008 | 06:24 PM
  #193
ace33joe's Avatar
Thank you for the good info, Mattjin and tephra. I will try the scaled coolant temp next time. Thank you!
Old Oct 19, 2008 | 04:01 AM
  #194
Mattjin's Avatar
Yes, the scaled version is what the ecu uses. It also lines up perfectly with what I see on my Blitz RVIT.
Old Oct 27, 2008 | 07:30 PM
  #195
mplspilot's Avatar
Ok so since there are no running priming maps for 94170008, i figured it's finally time to switch to 94170015.. So i transferred everything into a fresh 0015 ROM just to find out there are no definitions for "Warmup Ignition Retard Temp Control" for that ROM...
So i have 2 questions:
1. Can someone post that definition pls?
2. If instead (or until someone posts it) I zero out the values in so called Boost Enhancement Enrich/Enlean table, would that have any effect on anything else besides warm-up operation?
Here's the table i'm talking about:
