Virtual Dyno Room-Dyno Simulator
Old Aug 20, 2009 | 08:46 AM
  #466
Z_Lancer_Man's Avatar
Graphs look good!
Can't wait for the standalone version!
Old Aug 20, 2009 | 08:54 AM
  #467
Mellon Racing's Avatar
also filling in my wheel/tire size doesn't seem to change anything. however, if I fill in the tire diameter it changes...not sure what my value should be right off hand.
I still think the program should default to a fixed vehicle weight so everyone is on the same sheet of music. the left column starts with one weight for an 05 evo 8 5 speed and the right column starts with something else.
Old Aug 20, 2009 | 09:01 AM
  #468
here's what mine looks like right now, I don't know the vehicle weight (no weight reduction done) and I'm not correcting for the 245/40/18 wheels/tires so take it with a grain of salt. I did this log yesterday
Old Aug 20, 2009 | 09:29 AM
  #469
l2r99gst's Avatar
The proper vehicle weight is a very important factor in a road dyno...at least for accurate numbers. For comparison numbers on the same car it doesn't matter, as long as the same weight is used for the comparison pulls.
If everyone used the same weight, then people with light cars would get inflated numbers and people with heavy cars would get low numbers.
Eric
Old Aug 20, 2009 | 09:35 AM
  #470
I said, default, that means, start with the known correct weight from the factory, the user can then change as needed to suit their car. I'm aware of how weight affects the numbers, that's why I'm bringing this up.
Old Aug 20, 2009 | 09:36 AM
  #471
Jack_of_Trades's Avatar
v5.6 has an error with the BASE pull formulas so only the comparison side is reliable. I was going to fix it but now that they are working on a new stand-alone version I won't bother. I really can't get excel to auto-fill in the blanks and still have them editable by the user. I was going to add a list of average stock weights to the revision but I'm sure we can have it auto-fill with the C# application.
The tire calculator was added to just make it easier for the user to figure out their diameter rather than using the online calculator. I kept them seperate because some users have race tires which are ONLY in diameter, not the standard tire sizing (i.e; 235/45R17). So once you calculate your size into diameter, you can enter it into the chart.
Old Aug 20, 2009 | 09:44 AM
  #472
l2r99gst's Avatar
Sorry..I read into your statement that you wanted a default, fixed value (you did say fixed ). I thought you wanted the user not able to adjust it.
Old Aug 20, 2009 | 11:16 AM
  #473
no problem, simple misunderstanding
Old Aug 20, 2009 | 01:20 PM
  #474
scheides's Avatar
EvoM Moderator
Show off...
Old Aug 20, 2009 | 01:55 PM
  #475
Originally Posted by scheides
Show off...
it's slow
Old Aug 20, 2009 | 02:05 PM
  #476
Colt4g63's Avatar
My DLL with the way it was setup was always within 5-10 HP on average from what my car would actually dyno up at AMS on there Dyno Jet. So I messed with the correction factor on the VDR to match my DLL output. Its crazy how accurate and consistant VDR is if used properly on a FLAT smooth road!! Now even with AEM I can still have my portable dyno
Here is what my sheet is looking like ATM. Full weight daily driver.. Car is on 18s as well with 12 inch sub, AMP etc. Weight added actually
Old Aug 20, 2009 | 02:19 PM
  #477
strong! let's see it on the evom comparator settings for shiz n giggles
Old Aug 20, 2009 | 02:29 PM
  #478
Colt4g63's Avatar
Here it is on the EVOM comparator. Wow way lower.. boo!
Old Aug 20, 2009 | 02:30 PM
  #479
Colt4g63's Avatar
Chris what did the VDR run u put up say in DLL? I know I had to go to a 1.1 correction factor to make mine as close to DLL as i could get it....
Old Aug 20, 2009 | 02:48 PM
  #480
Man, how do you daily drive a 700+ HP car!? Very impressive! How much of the stock block/internals are still installed? And the most important daily driver question, what's your fuel economy?
