Patch: Force OBD Inspection Pass (acamus, mrfred)
Old Dec 10, 2009 | 09:04 AM
  #136
travman's Avatar
Originally Posted by sk8terdude929
I tried loading this patch and followed the instructions, watched the video but i am having problems wiith it. here is what it looks like. i can fill in any data (0,1) in the sections
oh and Rom is 94170008
your missing the blobbits scaling - add it to the xml and your good to go...
Old Dec 10, 2009 | 10:04 AM
  #137
sk8terdude929's Avatar
Originally Posted by CMB
Dont expect any help. These guys just help if they know you
Originally Posted by FresnoEVO
well i found out i needed to add the blobbits scaling definition to the evo7base.xml file
<scaling name="blobbits" storagetype="bloblist" storagebits="1">
<data name="0" value="00"/>
<data name="1" value="01"/>
</scaling>
added that and it displays just fine
wasn't able to get scantech to work with my 1.3u and 2.0 openport cables though so i still don't know what the stock obdII tests are; have to get my car smogged in ca soon
That worked great, thanks for your help. I’m always in these threads but don’t have much to give back otherwise I would post a lot more. I am happy to help the community that has helped me so much. And keep up the good work to all those involved
Old Jan 13, 2010 | 07:10 PM
  #138
bosco121's Avatar
is there one for rom 88590013
Old Feb 1, 2010 | 03:01 AM
  #139
mlocatel's Avatar
any instruction for 88580014 ?
Thanks
mlocatel
Old Feb 1, 2010 | 07:34 AM
  #140
fostytou's Avatar
EvoM Community Team
Should be the same as 88590015 (like all things for the roms in series.)
Old Feb 13, 2010 | 07:37 AM
  #141
xmaciek82x's Avatar
Hey everyone, friend of mine asked me to help him with this because of well.... emissions.
I'm curious, does he need it? He does not have a CEL, because he is using the spark plug fouler. So the o2 sensor is still plugged in.
Should he be able to pass emissions without this patch?
Old Feb 13, 2010 | 08:03 AM
  #142
psphinx81's Avatar
he shouldnt have a problem with the fouler, i did it for a year or two with my rear o2 still enabled
Old Feb 13, 2010 | 08:19 AM
  #143
xmaciek82x's Avatar
Will it pass emissions with a fouler on?
Old Feb 13, 2010 | 09:17 AM
  #144
nothere's Avatar
if there are no codes and the actual afr is correct it should be fine.
Some states don't even do afr checks if there are no codes but I wouldn't know about that in your state.
I can tell you I passed with an anti flower on my car several years ago. this last year I had the "pass code" and again it passed, but that's here.
Old Feb 13, 2010 | 11:33 AM
  #145
logic's Avatar
Here in Illinois, there's no AFR check, just a "gas cap test" (ie. "does it seal?") and codes pulled.
Old Feb 13, 2010 | 12:21 PM
  #146
psphinx81's Avatar
yes it will
Old Feb 13, 2010 | 03:11 PM
  #147
xmaciek82x's Avatar
Thanks everyone for the help!
Old Feb 25, 2010 | 06:37 PM
  #148
LGshow19's Avatar
Thanks you...
Old Apr 5, 2010 | 06:58 PM
  #149
Dirty25RS's Avatar
Ok, my turn.
Question:
My car is throwing P0420 - catalytic converter efficiency below threshold
Ohio...
If I do this, will it still throw that code?
If I do this, do I still have to wait for that "readiness" period to expire (50 miles or whatever)?
Because if it still throws that code they wont even hook it up with a CEL active.
If there is a way to just disable the P0420 code like you can on subarus please let me know.
Thanks.
Old Apr 6, 2010 | 12:50 AM
  #150
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
1. Yes you will throw the code
2. No the result is immediate
3. Yes there is a way to disable P0420
