Patch: Force OBD Inspection Pass (acamus, mrfred)
Old Aug 29, 2012 | 03:22 PM
  #271
VegasVIII's Avatar
has anyone attempted to try on rom 92290022? have a 2004 oz thats a pain in the butt
Old Oct 27, 2012 | 12:28 PM
  #272
McLaren F1 2003's Avatar
Does anyone know why this is going on? Attached are my Ecuflash settings and the way my car reads in Scantech. It only shows 3 sensors as ready. Is that right? Even when I set everything to pass, it only shows those 3 sensors.
Thanks in advance!
Old Oct 31, 2012 | 06:04 PM
  #273
Anyone?
Old Jan 10, 2013 | 11:21 PM
  #274
MrSquirr3l's Avatar
have these been done for rom 96530706?
Old Jan 11, 2013 | 05:15 AM
  #275
Broke4speed's Avatar
Have you looked? They're standard on the Tephra V7 rom you're referring to...
Old Sep 3, 2013 | 05:02 PM
  #276
KrakHed's Avatar
Failing emissions inspection with v7 settings (no egr monitor)
I've tried the existing settings of:
part 1 : E000
part 2 : EAFF
Comp : EAFF and 6AA7
But when I take it to get inspected, the following monitors show up as unsupported:
O2 sensor
Catalytic
egr flow
EVAP
I've tried several other settings and the closest I've gotten is:
part 2: 6AE5
comp: DAE5 and 6AA1
These get the other monitors working again, except EGR. Anyone know how to get the EGR flow monitor working again? All of my emissions equipment is currently installed.
Thanks in advance.
EDIT:
I believe I found where it's turned on. In the FCA #9 from the ECU periphery. Setting this to 1 brought the EGR test back up. Thought I'd post it here in case anyone else had the same issue.
Old Oct 14, 2013 | 09:01 AM
  #277
StreakGSX's Avatar
Has anyone had any issues passing inspection with setting everything to pass? Also how many miles do I need to drive after I do this or does this eliminate the need to drive the car x amount of miles?
Old Oct 14, 2013 | 09:37 AM
  #278
l2r99gst's Avatar
Best thing to do is set the monitors as how they are stock. Don't set everything to available and everything to pass.
As far as driving, you don't have to, it will show as passed immediately (the one downside to this patch).
Old Oct 14, 2013 | 12:30 PM
  #279
StreakGSX's Avatar
What should I change then? I need to get inspected tomorrow Hopefully it works. I'll read more and see what I should do.
Thanks!
Old Oct 14, 2013 | 03:06 PM
  #280
StreakGSX's Avatar
Also, To get rid of the CEL light can I just change the periphery0(FAA) rear02 (bit1) to 0 and periphery(FCA) p0421(Bit1) to 0 to eliminate the CEL light so I can pass inspection tomorrow!! Please help !
Old Oct 14, 2013 | 07:55 PM
  #281
3gturbo's Avatar
If you take the time to read this thread you can do it yourself.
Old Nov 28, 2013 | 06:47 PM
  #282
Werdna06's Avatar
so i copied and pasted this patch on 88590015 and when i click on Non-continuous monitor completion patch check box ecu flash just closes. it doesn't allow me to change values. is this an issue with ecu flash software version?
Old Dec 9, 2013 | 04:13 PM
  #283
lynex's Avatar
anyone know how to get to the tutorial video in the first post? the link is not working for me
Old Jan 1, 2014 | 08:51 PM
  #284
rome831's Avatar
Does any body know which monitors are suppose to say not supported from the factory? I bought my car already tuned and all the monitors say pass. My car does not pass emissions because of this.
Old Jan 1, 2014 | 09:08 PM
  #285
killerpenguin21's Avatar
try this
https://www.evolutionm.net/forums/9605729-post226.html
