Patch: Force OBD Inspection Pass (acamus, mrfred)
Old Sep 19, 2009 | 05:41 AM
  #91
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Originally Posted by donour
+1
...I'm finally back to working with my stock ecu, after several years of not being able to touch it...
d
I may try to create patch for your rom today as a donation for libmut
Old Sep 19, 2009 | 08:45 AM
  #92
donour's Avatar
That's alright. I'm going to try to switch to 96530006 anyway for more support. Standardization is a good thing.
d
Old Sep 19, 2009 | 03:27 PM
  #93
Dorikun's Avatar
Bwuaahahahaha!!! Sticky Bump!
Old Sep 19, 2009 | 05:43 PM
  #94
binky's Avatar
I'm still down if you feel like making it!!
Thanks
-Bink
Old Sep 19, 2009 | 06:38 PM
  #95
donour's Avatar
Are you sure you don't want to come over to 9653006? I'm having great luck after only 2 days of fiddling with it.
d
Old Sep 19, 2009 | 09:36 PM
  #96
logic's Avatar
I think I've got this worked out for 99860002 (a JDM Evo VII ROM); I'd be very grateful if someone (acamus? ) could confirm if this looks right to them.
Old Sep 20, 2009 | 06:09 AM
  #97
acamus's Avatar
Yes I will have a look, I can even do this patch for Evo5-6, if Ceddy have not done it yet.
EDIT:
99860002 seems to be correct.
Ceddy's ROM 2055011
1F1D5 1D F6 68 92 mov:g.w r2, @word_F668:16
to
mov:g.w #FF:16, @word_F668:16
and
1F1D9 1D F6 6A 06+ mov:g.w #0x10:8, @word_F66A:16
to
mov:g.w #0x0:8, @word_F66A:16
Old Sep 21, 2009 | 05:59 AM
  #98
binky's Avatar
d
Yeah, your right - so I started to I moved everything over to the newer ROM. The only thing I wasn't quite sure of was what logic said about the immobilizer - 'you need to copy both your normal immobilizer value, as well as an additional periphery-esque value'. I added the lines from that wiki to the correct xml file - but I'm not sure what to change now?
Thanks
-Bink
Old Sep 21, 2009 | 06:04 AM
  #99
logic's Avatar
If you added the "Immobilizer Hex" entry from the wiki, then you just have to copy over your Immobilizer value, as well as that "Immobilizer Hex" entry. Just follow the instructions at the top of the page and you should be all set.
Old Sep 21, 2009 | 08:18 AM
  #100
rdtech's Avatar
Originally Posted by l2r99gst
I've been using this for quite a while now on 96530006 and can verify that it passes OBD-II emmissions testing.
Actually, it was pretty funny to see the OBD readiness monitors as passed for items not even on my car.
Good to know!
Old Sep 21, 2009 | 08:32 AM
  #101
David Buschur's Avatar
recompile, I realize I am a little late but just wanted to say GREAT job on the video.
acamus and mrfred, thank you very much for the xml information, you guys are all great.
Old Sep 22, 2009 | 08:52 AM
  #102
acamus's Avatar
Glad to be of some help.
Actually the patch was written with intentions to help tephra with donations smoothly overcome his hard times.
So please all of you using this patch donate whatever it is worth to you.
If he will have too much money out of it I am sure he will stand up and say enough
Recompile maybe you can add this information to the first post of the this thread.
Old Sep 22, 2009 | 08:08 PM
  #103
3gturbo's Avatar
EDIT:
Ceddy's ROM 2055011
seg001:1F1D5 1D F6 68 92 mov:g.w r2, @word_F668:16
to
and
seg001:1F1D9 1D F6 6A 06+ mov:g.w #0x10:8, @word_F66A:16
to
Could you guys please do this patch for the 2g rom since its available now for flashing heres the latest stock gsx rom. 2g_eclipse_rom_xml.zip
Old Sep 22, 2009 | 08:45 PM
  #104
Ceddy's Avatar
Originally Posted by 3gturbo
Could you guys please do this patch for the 2g rom since its available now for flashing heres the latest stock gsx rom. Attachment 140932
The only difference between the 2056(98 GSX) and the 2055(98 GST) is the Speed Limiter in the Periphery Bits and a slightly different Limp Home TPS Table because of different gearing.
You'll be fine using the 20550011.
Old Sep 23, 2009 | 06:53 AM
  #105
3gturbo's Avatar
Could you post the code or the xml I don't see it in this thread. F66A and F668 ?
