Patch: Force OBD Inspection Pass (acamus, mrfred)
Old Oct 13, 2009 | 02:35 AM
  #121
3gturbo's Avatar
Originally Posted by Ronnie Size
You guys that are leaving them all set to ready are asking for trouble. Can't you even take the time to make it the same as stock?
Old Oct 13, 2009 | 08:09 AM
  #122
Ronnie Size's Avatar
FCOTM Winner
I suppose I could have. The inspector is my friend so that wasn't a worry.
Old Nov 4, 2009 | 04:39 PM
  #123
adam5743's Avatar
Originally Posted by psphinx81
just so everybody knows, i passed the NYS inspection this morning with this patch loaded into my car and i have no emission stuff left in my car on the stock ecu!
thank you to everyone involved to make this happen! its greatly appreciated!
Man, I just sent you a PM. I just moved to Corning from OK (which doesn't have this kind of inpsection issue), and I was afraid I was about to have to spend either a lot of time or money to put my car back to stock just so I can get it inspected and registered in NY. This is exactly what I have been looking for!
Old Nov 7, 2009 | 09:40 AM
  #124
4kinboost's Avatar
Originally Posted by Jacoby
My feedback.. This worked though so thank you!
"Secondary Air system - should be not supported
A/C refrigerant - should be not supported
Heated catalyst - should be not supported"
What blobits did you adjust?
Old Nov 23, 2009 | 02:46 PM
  #125
Kracka's Avatar
Thanks, I'm going to give this a try!
Old Nov 27, 2009 | 07:07 AM
  #126
warp9's Avatar
Originally Posted by FresnoEVO
well i found out i needed to add the blobbits scaling definition to the evo7base.xml file
<scaling name="blobbits" storagetype="bloblist" storagebits="1">
<data name="0" value="00"/>
<data name="1" value="01"/>
</scaling>
added that and it displays just fine
wasn't able to get scantech to work with my 1.3u and 2.0 openport cables though so i still don't know what the stock obdII tests are; have to get my car smogged in ca soon
I had this problem too and this helped. After I did everything to the T my blobbits table shows this:
No match? What could be the cause?
Old Nov 27, 2009 | 09:25 PM
  #127
Jp7's Avatar
Jp7
EDIT: deleted - I'm an idiot!
Old Nov 29, 2009 | 06:43 PM
  #128
MR Turco's Avatar
i have a local on 94170015 with this patch. I am still getting a CEL for p0140 - Rear O2 heater. Owner has the o2 sensor in, i figure it is broken or dead. Do i still need to do the heater patch for this? Is one available for this rom?
Old Nov 29, 2009 | 07:03 PM
  #129
logic's Avatar
The readiness/completion patch is purely for the OBD-II side of it (emissions testing); you'll still throw CELs for failing tests.
So, short version: yes, you need the heater patch.
Old Nov 30, 2009 | 11:02 AM
  #130
MR Turco's Avatar
Thanks for the reply. Since i can't find the heater patch for 9417 do you, or anyone, know the periphery bit for the rear heater or rear o2 in general? I have the OBD patch so i don't care if the ecu is looking for rear o2 anymore.
Old Nov 30, 2009 | 02:05 PM
  #131
logic's Avatar
MR Turco, for shame. You even posted in that thread. It's not a periphery bit, it's a patch:
https://www.evolutionm.net/forums/7302505-post266.html
Old Nov 30, 2009 | 03:18 PM
  #132
MR Turco's Avatar
oh srsly?! hahaha, i looked through that thread but must have missed post 266
lol, this gets back to my discussion the other day on organization in this section. We need to start updating the first post with information discovered in latter posts (like post #266)
Old Dec 9, 2009 | 03:31 PM
  #133
sk8terdude929's Avatar
problem/help
I tried loading this patch and followed the instructions, watched the video but i am having problems wiith it. here is what it looks like. i can fill in any data (0,1) in the sections
oh and Rom is 94170008
Attached Thumbnails Patch: Force OBD Inspection Pass (acamus, mrfred)-forceobd2.jpg
Old Dec 10, 2009 | 08:15 AM
  #134
CMB's Avatar
CMB
Dont expect any help. These guys just help if they know you
</scaling>
Old Dec 10, 2009 | 09:03 AM
  #135
travman's Avatar
</scaling>
did you go into scantech and change the settings required to make the tactrix cable work? I know it works for the 1.3 - not sure on the 2.0. But you have to go into the settings and set it up to get it to connect properly....(not sure if you've done this?)
Supported Tests:
EGR
Oxygen Heater Sensor
Oxygen Sensor
EVAP
Catalyst
