The DTC Disable thread (P1235, P1241, P1238, etc)
Old Jan 25, 2010 | 10:24 AM
  #271
xPRimNT's Avatar
Sometimes you need to close the ROM and open it again to reload the XML. If you feel comfortable, you can just add the line to the XML.
I've been testing this, and so far so good! I need a fuel relay before I test WOT to confirm that AFRs aren crazy, but 3/4 throttle seems ok.
A CEL free dash... That's something I haven't seen in a while!
Old Jan 25, 2010 | 10:38 AM
  #272
Clipse3GT's Avatar
Old Jan 25, 2010 | 10:51 AM
  #273
Guru's Avatar
Yep got it right the second time not really sure what I did the first time but I suspect I did something incorrectly so want to delete whatever I did the first time. Anyone? Should I just deinstall and reinstall 1.42 and then scan ECU and do it again?
Old Jan 25, 2010 | 04:21 PM
  #274
tephra's Avatar
I added the XML to post #1 for this DTC disable..
Just copy/paste that one...
Old Jan 25, 2010 | 05:58 PM
  #275
Guru's Avatar
Tephra should I delete that extra line of code in my 52680018 xml file before downloading to the car? I don't want to brick the ECU.
Old Jan 25, 2010 | 06:02 PM
  #276
tephra's Avatar
what line?
Old Jan 25, 2010 | 06:03 PM
  #277
xPRimNT's Avatar
If you can find it, feel free to delete it and add it how you want it.
It won't actually change anything with your ROM unless you make the change in ECUFlash, so you don't really have to worry about that.
Old Jan 25, 2010 | 06:36 PM
  #278
criptballer's Avatar
wow! i cannot wait to try this out! i thought i'd never see a code free dash. i was getting used to clearing my dtc with pcmscan every 30 miles, but this rocks though!
Old Jan 25, 2010 | 07:42 PM
  #279
Guru's Avatar
Hmm wait I see an extra line in the 52680018 xml file. Should I delete? This is what it says.
<table name="O2code" address="503b2" scaling="uint8"/>
I actually named it O2sensorcode the second time I did it successfully
Oh and now both things are showing under misc.
As posted on last page.
Old Jan 25, 2010 | 10:12 PM
  #280
xPRimNT's Avatar
You can delete it Guru. Just replace that line with the line tephra posted:
<table name="DTC P0139/P0140 Disable 0x1 -> 0x0" category="Misc" address="503b2" type="1D" scaling="Hex8"/>
Old Jan 26, 2010 | 01:07 AM
  #281
tephra's Avatar
yeh i dont know where that line came from??!?
Old Jan 26, 2010 | 03:19 AM
  #282
EVOXTIMES's Avatar
Hey Chris,
Did these disable codes get rid of the rear 02 cel as well. Or is that one still there?
Old Jan 26, 2010 | 07:05 AM
  #283
xPRimNT's Avatar
Yep, that's what this one finally solved!
PM me about it later if you like.
Old Jan 26, 2010 | 08:31 AM
  #284
i was going to test it out today but it snowed again, damn it!
Old Jan 26, 2010 | 05:09 PM
  #285
tephra's Avatar
looks liek 526900XX uses the same address as 526800XX.
Give it a go - but ensure your AFR is what you expect
