The DTC Disable thread (P1235, P1241, P1238, etc)
Old Jan 30, 2010 | 05:34 PM
  #301
tephra's Avatar
yeah I had a look, the routine looks like the right one, but its slightly different from GSR...
i'll have to have a proper look this week sometime!
Old Feb 1, 2010 | 02:08 PM
  #302
bandit09's Avatar
Hi,
I've applied these fixes and they worked great for a bit, but now when I get on it hard like maybe 85%+ throttle I get a really violent fuel cut. Upon investigation I have thrown the code p0234 which is wastegate malfunction I believe. I think it might have to do with overboost though. Anyone familiar with this code and how to get it to go away? Oh also I have p0300 but I think that is unrelated.
Thanks!
Old Feb 1, 2010 | 02:29 PM
  #303
GST Motorsports's Avatar
When you hit fuel cut (boost limit) it will throw a P0234
You are over boosting and exceeding the Boost Limit load.
- Bryan
Old Feb 1, 2010 | 04:43 PM
  #304
tephra's Avatar
nice response!
Old Feb 2, 2010 | 01:28 AM
  #305
bandit09's Avatar
- Bryan
Hi,
thanks for your helpful response. Do you happen to know what I can do to prevent this? I'm kinda of a newbie but I know how to edit tables and stuff with ecuflash and also I can do some datalogging with evoscan.
Thanks.
Old Feb 2, 2010 | 01:30 AM
  #306
tephra's Avatar
Boost Limit in the Turbo category...
<insert usual disclaimer about logging AFR etc etc when making changes>
Old Feb 2, 2010 | 02:08 PM
  #307
bandit09's Avatar
Thanks, I'll give that a try.
I don't know if it matters at all but my ECU no longer controls the boost, I have an AEM truboost that does that so I'm not sure if that matters but I'll try raising the boost limit. I remember reading something about airflow check / torque check tables but I haven't messed with those yet.
Old Feb 2, 2010 | 02:21 PM
  #308
SiC's Avatar
SiC
That table has nothing to do with controlling your boost, it sets the limit for the current error you are getting.
  #309
Whitewind's Avatar
You should think about letting ECU control your boost. Goes off of load. You will see in the map boost limit table RPM/Load so If your hitting 280 load/RPM range and boost limit set at 280 load it will shut your *** down.
DON'T EVER RAISE IT TO MAX THOUGH! It nice to have a safety net.
Attached Thumbnails The DTC Disable thread (P1235, P1241, P1238, etc)-limit.jpg
Old Feb 3, 2010 | 05:47 AM
  #310
KOTT's Avatar
Tephra, on 08 EDM with SST some numbers dont much numbers in table for 53040007
I must change them to same or maybe you will see the rom and change adresses?
Old Feb 3, 2010 | 10:42 AM
  #311
20valves20lbs's Avatar
2010 USDM MR rom
Hey guys,
Came across a 2010 USDM MR with ROM ID 55580005 this past weekend. Any way I can send this to Tephra, Sic etc.... to get a XML, Mode 23 and the CEL fixes worked out? Thanx
Old Feb 3, 2010 | 10:45 AM
  #312
Magnumpsi's Avatar
Tephra,
Did it on another car yesterday worked flawless.
Thanks!
Mitch M
Old Feb 3, 2010 | 10:49 AM
  #313
Originally Posted by 20valves20lbs
Hey guys,
I would imagine it's the same as 55570005 for all the basic tables although the SST, etc might be different.
Send it my way. PM me for email addy
- Bryan
Old Feb 3, 2010 | 03:49 PM
  #314
Huge's Avatar
I thought I was in the clear, three days without the light and bam it turned on this after noon.
What could it be I'm missing to do?
[IMG][/IMG]
Oh and the code is P0140
Old Feb 3, 2010 | 03:53 PM
  #315
tephra's Avatar
thats weird.
you sure you flashed the right ROM?
