The DTC Disable thread (P1235, P1241, P1238, etc)
Old Mar 7, 2010 | 11:08 PM
  #361
Fourdoor's Avatar
Originally Posted by xPRimNT
Haha, if it bothers you that much, hook up your Wideband into the Rear O2. The fix works for P0139!
I did this, and was told by tephra that I had to disable the rear O2 sensor in the code.... so I now throw the p0139 code.
If I re-enable the rear O2 sensor will it get ride of this f'ing code? Or is there some other way to get ride of it for rom id 55590006?
Thanks,
Keith
Old Mar 8, 2010 | 05:45 AM
  #362
xPRimNT's Avatar
Thanks,
Keith
There is a disable for P0139 for the North American X ROMIDs, but the address might be different for your RA. Hopefully Tephra can chime in and let you know what the equivalent address will be for your car. Then you can live code free
Old Mar 8, 2010 | 07:59 AM
  #363
REVOlution86's Avatar
i have a couple codes that im bothered about like P0000 AND B3013 AND P2125 . . . .these keep poping up but the new one now is p2125 then again it only came up after we swapped the stock turbo
Old Mar 8, 2010 | 07:17 PM
  #364
criptballer's Avatar
ok so my tags are up in april and i'm pretty sure i'm not going to pass emissions with and SES light. whenever i turn the bit off from ecu options 2 i still get p0140. but when i turn it on i get p0037 instead. i have removed the stock o2 completely too. i need some major help guys or i won't be able to register my car
oh yeah, i've also tried running the white wire into the yellow wire of the stock connector with no results. is there a P0037/P0038 fix out there?
Old Mar 9, 2010 | 12:31 PM
  #365
Fourdoor's Avatar
Hey Tephra,
Should I re-enable my rear O2 sensor (I have a wide band on that pin) to possibly clear my p0139 code... or is there some other way to disable the P0139 in the 2010 Ralliart with ROM ID 55590006?
Thanks,
Keith
Old Mar 9, 2010 | 12:38 PM
  #366
HR2L's Avatar
Originally Posted by criptballer
if i had one wish, it would be to get rid of P0140 from the entire world. matter fact, i would make it so the combination of letters and numbers of P0140 could not ever be used in this world for anything in any sequence.
Agreed...sick of seeing P0140 every 30-40 miles...even a mechanical fix has not helped.
Any word on when we might get a fix for this?
Old Mar 17, 2010 | 06:03 AM
  #367
Piper747's Avatar
I was hoping to do the p0140 disable for ROM 53600010. I have disabled the sensor via the options bit and have a wideband hooked in and now this code pops up. Can anyone help with the disable def?
Old Mar 19, 2010 | 09:35 AM
  #368
stokEd's Avatar
Found it! It was just buried... from Post #51
Originally Posted by SiC
Code:
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="63210" type="1D" scaling="Hex16"/>
<table name="DTC P1241 Disable 0x03E8 -> 0xFFFF" category="Misc" address="63206" type="1D" scaling="Hex16"/>
<table name="DTC P1235 Disable 0x0026 -> 0xFFFF" category="Misc" address="549d4" type="1D" scaling="Hex16"/>
<table name="DTC P1233 Disable 0x0028 -> 0xFFFF" category="Misc" address="549d0" type="1D" scaling="Hex16"/>
<table name="DTC P1234 Disable 0x0028 -> 0xFFFF" category="Misc" address="549d2" type="1D" scaling="Hex16"/>
Old Mar 19, 2010 | 09:43 AM
  #369
stokEd's Avatar
Bah, just realized those are just the airflow disables. Maybe send SiC a PM and see if can help with the P0139/140 disable as well.
Old Mar 21, 2010 | 11:30 PM
  #370
Piper747's Avatar
Thanks for checking. I appreciate the assistance
I wonder what is the cause of this code. It said something like inactive sensor bank I think. Maybe the voltage my WB is generating to imitate a NB sensor is off. I believe it swings from 0.1 to 1V.
Or...that has nothing to do with it and the fact that it is disabled via the option bit is causing conflict in some subroutine
Old Apr 24, 2010 | 11:10 AM
  #371
MiVecJohn's Avatar
hey guys..
could i get this for rom
53220004
52700006
thats for the regular lancer.. but i think is the same principle... im trying to boost the car up w/ a faily large turbo, and im tripping all those codes...
any help is appreciated
Old Apr 25, 2010 | 03:47 AM
  #372
vboy425's Avatar
need definition for 2010 evo X mr touring 55580006. thanks
Old Apr 25, 2010 | 05:56 PM
  #373
MiVecJohn's Avatar
Originally Posted by MiVecJohn
hey guys..
53220004
52700006
anyone? im in dire need of this
Old May 3, 2010 | 07:01 AM
  #374
Riced's Avatar
I've got a "52690019" that inherits "52680015 "
The one line for "<table name="DTC P0247 Disable 0xF9DF -> 0xF1DF" category="Misc" address="9356a" type="1D" scaling="Hex16"/>" does not match up. mine shows "0xd12e"
the rest match up .
Any idea's ?
Old May 3, 2010 | 07:05 AM
  #375
tephra's Avatar
yeah its wrong...
do you need it?
