TephraMod V7
Old Nov 16, 2020 | 11:14 AM
  #3601
EvoXMad's Avatar
Spoiler
what about using the support email address that I put in the last post?
Old Nov 18, 2020 | 05:08 AM
  #3602
AntonySR20's Avatar
HI! Can anyone tell me where is can be download LIVE map?
Old Nov 18, 2020 | 10:12 PM
  #3603
EvoXMad's Avatar
you can download tephramod live map and sd roms from the evoscan website for evo7 evo8 evo9 and evo10
Old Dec 2, 2020 | 08:34 AM
  #3604
bsh's Avatar
bsh
Hi! I am trying to tune an Evo 8 JDM with rom id 97470001. I cannot open the stock .srf file to view or edit. What am I doing wrong? i see that the 97470001 xml are in the metadata folder, but it seems like it cant open because of to many errors.
I tried downloading the 96530706, but I think I do something wrong or have the wrong definition file? Maybe I should use the 96260009?
Are Rom the bin.file and XML-package is the definition/metadata? This is new for me
I have the 96530706 XML package copied to: C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
I can open the Tephra 96530706 bin, but not the stock srf file...
If everything is installed correctly and I have the correct defintion files, I can open the stock file to get the immobilizer and injector data and then open the Tephra .bin and transfer the immobilizer and injector data to get started?
Thanks
Old Dec 4, 2020 | 10:07 PM
  #3605
JDL218's Avatar
Rom grayed out options
Whats it mean when sum rom ootions are greyed out?
Old Dec 4, 2020 | 10:12 PM
  #3606
JDL218's Avatar
Thanks
rom is the bin and xml is def thats what i worked out im in the same boat bro just started trying too tune my car last week jdm 7 there is alot u need too know go too evoscan read the help page there for tuning if u have not done already
Old Dec 6, 2020 | 03:37 AM
  #3607
bsh's Avatar
bsh
The 97470001 XML I have are only 1kB, while other definitions are 11 kB and bigger... Is the 97470001 ROM a very little known/rare?
Thanks
Old Dec 6, 2020 | 11:18 AM
  #3608
CDrinkH2O's Avatar
Did you try this version? 97470001
Old Dec 7, 2020 | 01:46 AM
  #3609
Konst's Avatar
Evo 9
Hi guys))) why is it that I do not have enough MAF scaling card in version 88580714? Is there maf scaling Hz, maf compensation is there and maf scaling g/s is missing?
Does anyone have XML with maf scaling?
Old Dec 7, 2020 | 11:11 AM
  #3610
bsh's Avatar
bsh
Thanks, now I can open, but the rpm and load are totally off... See picture. Any ideas?
Old Dec 10, 2020 | 12:57 AM
  #3611
lurkerdan's Avatar
Guys, does anyone have a SD patch for 986400014 (MR560648)? Desperately in need. TIA
Old Dec 14, 2020 | 07:15 AM
  #3612
todd6027's Avatar
you have to use a 90550001 variant 90657701 works well
Old Dec 15, 2020 | 05:37 AM
  #3613
lurkerdan's Avatar
Thank you!
Old Dec 16, 2020 | 10:57 AM
  #3614
bsh's Avatar
bsh
Anyone?
Old Dec 16, 2020 | 11:50 AM
  #3615
Biggiesacks's Avatar
Anyone?
issues with the XML / bad inherits would be my guess. What errors were you getting before you swapped around the default XML?
