launch maps
Old Jul 20, 2010 | 12:53 AM
  #121
drinky84's Avatar
Veteran: Army
Originally Posted by D-VO
??? Eh? It says "EVO 8 Tephra v7 Launch Map Test" as a title. Are you sure a bout that?
Yea i believe he is using a dynatek arc-2 cdi box, which has a 2 step build in
Old Jul 20, 2010 | 02:30 AM
  #122
1slowassevo's Avatar
Wrong he's using just the v7 mod it has around -15 * with lots of fuel I had mi e sound the same and act just like it but it was messing with my other maps all together also it was flooding my motor after 2 stepping it plus hated the way it sounded it was like a banana stick in the tail pipe...your gonna have to play with it To adjust properly took me around 10 times...you don't want to have knock doing this mod cause the car can Bog..
Old Jul 20, 2010 | 06:04 AM
  #123
charlie.tunah's Avatar
He's using an aftermarket inginition box so that it is an iginition cut based system, instead of the stock fuel cut based system. he's using the V7 launch maps to set it up, but using the cdi box for the 2 step with his factory 2 step rpm setting very high so he never hits it. Since the factory 2 step is fuel cut, its pretty hard to get the desired results when the extra fuel isnt there. A good 2 step system has low timing, extra fuel and cuts ignition for the 2 step.
Old Jul 20, 2010 | 10:31 AM
  #124
D-VO's Avatar
Oh I see. Thanks for clearing that up.
Old Jul 20, 2010 | 11:41 PM
  #125
drinky84's Avatar
Veteran: Army
Yep my thoughts exactly...Im glad to see someone know the whole story
Old Nov 1, 2010 | 04:29 PM
  #126
widge's Avatar
Can someone post some maps please, i cant stop the car from bogging of the line
Old Nov 15, 2010 | 08:24 PM
  #127
Chameleon@NLM's Avatar
same here
Old Feb 21, 2011 | 05:52 AM
  #128
MercenaryX2's Avatar
Originally Posted by Chameleon@NLM
same here
No offense, but you should really make your own map. No one's setup is the same so you should make your own according to your own logs.
Originally Posted by Appauldd
It is actually pretty simple to set up your own....
Set your stationary rev limit to your desired launch rpm....in my case 5500
Get the car warmed up and then log you bouncing off of the stationary limit.
Look at your log to determine where you need to add fuel and remove timing.
The ECU clips timing at -10 so it is pointless to enter less. (although some may desire less)
In the same area you remove timing, add fuel....and lots of it as the moments between rpm bounces will go lean.
Make sure you have smooth transitions in and out of the hole
Log again and make adjustments as necessary.
Old Feb 22, 2011 | 11:13 AM
  #129
raasfaas's Avatar
+1 on this...
I gave a friend of mine my launch map settings (got me 13psi at the line with consistent 1.6 60ft) as a beginner map for him to work off of...he was only able to build 8psi and bogged flat on his face on the launch.
The little writeup that Appauld did is a very good tutorial on how to get started.
Old Apr 4, 2011 | 03:03 AM
  #130
gialla's Avatar
Is it possible to use the launch map for the NLTS? I have a doubt concerning the rev limiter used when gear changing...
Old Jun 22, 2011 | 05:16 PM
  #131
jonmorera's Avatar
From: Costa Rica with business addres in Miami FL 33166
Hi guys!!! really good thread, I tell my tests, as always at the end I have some problems.
ok my launch control was working well it cuts to 6000 rpm but after three launchs now not want to work, my evo holds the lauchs maps for a few seconds but after a few seconds it passed to the normal maps and the rpm cut is removed, would happening here guys??
these are my lauch maps:
I made a video of my tests, when my launch worked well, now I have problems, my evo not want hold the rpm cut at 6000 just for a few seconds.
Video: http://www.youtube.com/watch?v=YASuuu7cPcc
appreciate any help guys.
Old Jun 22, 2011 | 05:48 PM
  #132
nightwalker's Avatar
Here is my launch map.
Works awesome for me. Basically the deep recessed areas are where my launch rpm is set. The rest of the map is my regular map.
The key is logging a bunch of launches and integrating the maps. You will have to watch your logs and see what your car is trying to do when you launch it. I will two step it, hold it for about 3-5 seconds, then launch, run through the first 3 gears and shut down.
To arrive at the recessed areas, I had to play with the fuel and timing in those areas to get the boost I wanted and then continued toying with it until it wasn't knocking anymore. You'll get some knock here and there, but if you get a significant amount back to back, the car will bog. I can sit on the two-step for almost 10 seconds and it will still give me a clean launch. I don't really recommend holding it too long, because really bad things can happen...
Old Jun 22, 2011 | 11:01 PM
  #133
project_skyline's Avatar
Jon what are your TPS activation limits set at and what is your VSS turn off?
Check your clutch switch.
Old Jun 23, 2011 | 04:41 AM
  #134
jonmorera's Avatar
TPS activation limits?? the value ""Launch-map TPS threshold"" says 40% is this the value?? , I log data and the max value in tps position is 90%
VSS?? I don't know what is this??? can you explain me
The Evo VI JDM not have clutch switch, the speed limit has always worked, I do not understand because it not wants to works now, I have had many problems with the development of this tephramod V7 on my Evo VI, I hope in God that this is the last problem to solve
thanks for help me
Old Jun 23, 2011 | 06:41 AM
  #135
jonmorera's Avatar
Ok VSS is Vehicle speed sensor, the "launch-map vehicle speed threshold" is set to 8 km/h is this correct??
maybe I need the clutch switch
