94170715 V7 Issues
Old Apr 15, 2010 | 01:22 AM
  #166
ace33joe's Avatar
Originally Posted by tephra
I thought Roadspike was talking about AFR closed loop control? Not boost/load error control?
If he is talking about periphery FAA bit 4 setting to be 1, it is already set to 1 at my rom.
Can you please describe Roadspike's fix in detail if it is related to the boost error problem?
Old Apr 15, 2010 | 02:01 AM
  #167
tephra's Avatar
Well if RS's fix didn't work (or is already set for you - as per u say) - then you will need to log the variable I said...
Old Apr 15, 2010 | 02:51 AM
  #168
ace33joe's Avatar
Ok, I will log the variable tonight.
Roadspike:
If there is something I miss about the closed loop control setting, please share the fix with us.
Thanks!
Old Apr 15, 2010 | 06:51 AM
  #169
ace33joe's Avatar
Ok, I sent the log file to tephra.
Boost error is still stuck at the minimum.
I also found my injectors are maxed out and I get leaner after 6500rpm than I want. I guess it's time for bigger injectors.
Old Apr 15, 2010 | 05:56 PM
  #170
RoadSpike's Avatar
Log with the boost control working for me at least
Old Apr 15, 2010 | 06:23 PM
  #171
Appauldd's Avatar
DANG....E85 loves timing. I wish I could run 8 degrees at peak....impressive. Looks like everything is working properly now.
I wonder if the issue is EvoScan related.
Old Apr 15, 2010 | 06:26 PM
  #172
RoadSpike's Avatar
hehe only at low boost bro at 30psi it wont take that kind of timing.
The main problem i had was setting up the blasted boost Error and desired boost table to take into account that its psiA which is NOT psi.
So i had to add 14.5 psi to my base adder to directly control boost as needed.
Old Apr 15, 2010 | 06:46 PM
  #173
Appauldd's Avatar
Spool seems to come on a little late though. Might want to re-work the fuel and timing a bit to get some more spool out of it.
Sorry for being off topic.
Old Apr 15, 2010 | 06:53 PM
  #174
RoadSpike's Avatar
Yeah thats 2nd gear for ya I suppose i could probably get it to come up earlier not totally sure how to do it though. Been concentrating getting this romid speed density fully worked out before beating on the car too much for optimum spool up
Old Apr 15, 2010 | 07:21 PM
  #175
ace33joe's Avatar
I think I found the problem !!!
Roadspike gave me a hint about the boost adder.
I checked my boost adder scaling, and it was set to PSIa8 OMNI4 barMAP !!!
It is supped to be a 16 bit value not 8 bit value.
So if I change that 14.7 PSIa in 8 bit value to 16 bit value, I get 3766.9 PSIa !!!
No wonder why boost error was stuck at mininum, I can never reach the target boost which is the addition of boost adder and boost desired engine 'psi' value.
Ah, I am so sorry for causing extra work to tephra and other members here.
I will test this out tonight see if it is solved.
Thanks for the help !!!
Old Apr 15, 2010 | 07:49 PM
  #176
tephra's Avatar
yeah look at your BCLO - it's totally ****ed...
Old Apr 15, 2010 | 11:14 PM
  #177
Raceghost's Avatar
Darn scalings. Hope this works. That does ask another question... Should the Desired Boost and Wastegate Duty tables also be in 16 bit scaling?
Thanks again Tephra.
Old Apr 15, 2010 | 11:22 PM
  #178
tephra's Avatar
nah 8 bit
Old Apr 16, 2010 | 01:22 PM
  #179
Raceghost's Avatar
Ok, one more quick question about the gear based boost. Say I want my 1-3rd gear to boost higher than 4-5. I would utilize the low gear range to represent 1-3rd, utilizing the low WGDC correction range? High gear would be the opposite? I was assuming this was the theory behind the gear based boost?
Old Apr 16, 2010 | 01:52 PM
  #180
RoadSpike's Avatar
Borrowing some pictures from myself
I'm assuming you setup the boost error tables correctly to handle changes in boost.
Now when you have the boost error correctly set you can setup the wategate duty and max boost in the right hand table here to be lower for gears 4 and 5 than the first three.
My example image shows a constant 30 dropping to 27ish psi but you don't have to follow that at all :P
