Virtual Dyno - Standalone Software
Old Jun 29, 2010 | 09:21 PM
  #136
Evoryder's Avatar
No bump. Actually almost all my runs have an amazing spike using the VD.
Old Jun 29, 2010 | 09:33 PM
  #137
3gEclipseTurbo's Avatar
it could be that your logging to many things and slowing down evoscan.
Old Jun 29, 2010 | 09:39 PM
  #138
tscompusa2's Avatar
what does it show with DLL? http://www.dataloglab.com/
Old Jun 29, 2010 | 09:40 PM
  #139
tscompusa2's Avatar
this is probably right.. i noticed when i log certain things it kills the logging rate of the program.
Old Jun 30, 2010 | 04:10 AM
  #140
Mellon Racing's Avatar
Originally Posted by Evoryder
Whats up with the torque spikes?
VD vs VDR Same settings weight etc ...only difference is the Smoothing only goes to 10 and i'm using 16 on VDR
^^^ there's your answer. VDR is allowing you so much smoothing that you can completely cover up that spike. I've never met a car that needed 16 smoothing, I think you're masking a problem and VD is showing it to you because it's not smoothing as much.
Old Jun 30, 2010 | 05:04 AM
  #141
Evoryder's Avatar
Well I lowered the smoothing to 5 and 10 to compare 2 logs using the VDR. Not covering anything. Here's the result.
What I log using my zeitronix during runs = RPM,OMNI psi, LOAd, TPS, IAT and knock. My zeitronix logs; A/F,egt,psi,rpm
Old Jun 30, 2010 | 05:10 AM
  #142
tscompusa2's Avatar
that is not a normal graph for 5 smoothing. maybe your tactrix cable is crapping out or something. - post your log file here
Old Jun 30, 2010 | 05:11 AM
  #143
what I've noticed is that VDR's smoothing is more powerful than VD. What I mean is that if you do 5 smoothing in VDR, you probably need 10 or more in VD and 10 is the max it allows. Brad is going to bump that upper limit up to 20. I like this because it'll allow more finite control over smoothing.
Old Jun 30, 2010 | 05:13 AM
  #144
I agree, 5 smoothing in VDR shouldn't look like that, it should be smooth unless you have a problem. The fact that you were using 16 was alarming, again, i've never needed more than 5-10 in VDR.
Old Jun 30, 2010 | 05:59 AM
  #145
Evoryder's Avatar
Here's my log. I'm going to do another log today with only rpm boost and tps.
File Type: zip
Old Jun 30, 2010 | 06:06 AM
  #146
I glanced at the log and there's multiple samples of the same RPM which is unusually fast and may be why it looks strange.
Old Jun 30, 2010 | 06:40 AM
  #147
Evoryder's Avatar
Double
Old Jun 30, 2010 | 06:47 AM
  #148
Evoryder's Avatar
One rpm is from tactrix the other is my zeitronix.
I did a log with just what I mentioned before and it gave me a spike at the end. 1400whp spike.
Old Jun 30, 2010 | 07:03 AM
  #149
if you're getting a spike trim some of the last rows by deleting them and saving the file. Run it through again, it may take a few tries to clip off the spike on the end. Brad is working on adding a slider to adjust this without having to do it manually.
Old Jun 30, 2010 | 12:03 PM
  #150
Boosted Tuning's Avatar
yes, sometimes 10 isn't enough
