Minimum IPW
Old Mar 31, 2013 | 07:45 AM
  #196
MercenaryX2's Avatar
4908, 4908 and 4900
Old Mar 31, 2013 | 07:50 AM
  #197
Broke4speed's Avatar
Darn...that's all I know, boo.
Old Mar 31, 2013 | 07:59 AM
  #198
Well I just tried switching to the 9417 v7 rom and it fired up for about 5 seconds, then died. Now it won't start again. It tries to but won't.
Old Jul 27, 2013 | 10:40 PM
  #199
samadam's Avatar
Same issue here. Just installed fic 2150cc injectors and its running 11.5afr at idle but i cant get the patch to work Im running the 95630706 v7 rom. This is my daily and would like to get the patch to work so i can sort it out. Is there a speacial place to input the code in rom data?
Old Jul 31, 2013 | 01:21 AM
  #200
Insert the patch into the 96530706 XML at the bottom before </rom> and it should work. Change all 3 patches to 0009 and change the minimum IPW to 1.088 (seems to work pretty well for me but i may be wrong).
Old Jul 31, 2013 | 10:39 PM
  #201
samadam's Avatar
I had to put the patch in the base 95630006 rom and in the v7 95630706 rom for it to read. It worked. Now im still having problems with start up and idling.
Old Dec 27, 2014 | 03:05 PM
  #202
SkyNight's Avatar
Thumbs up
88570008:
Code:
	<table name="Minimum IPW #1 SHLL8->NOP (0x4908 -> 0x0009)" category="Misc" address="26d92" type="1D" scaling="Hex16"/>
	<table name="Minimum IPW #2 SHLR2->NOP (0x4908 -> 0x0009)" category="Misc" address="26d94" type="1D" scaling="Hex16"/>
	<table name="Minimum IPW #3 SHLL->NOP (0x4900 -> 0x0009)" category="Misc" address="26d96" type="1D" scaling="Hex16"/>
        <scaling name="IPW16:SHLL0" units="ms" toexpr="x*8/1000" frexpr="x*1000/8" format="%.3f" min="0" max="65" inc="0.008" storagetype="uint16" endian="big"/>
	<table name="Minimum IPW SHLL0" category="Misc" address="1102" type="1D" scaling="IPW16:SHLL0"/>
Old Apr 9, 2015 | 02:24 PM
  #203
SiriusEvo's Avatar
Veteran: Army
Originally Posted by tephra
Hi DOodz!
90550001:
Code:
<table name="Minimum IPW #1 SHLL8->NOP (0x4818 -> 0x0009)" category="Misc" address="227b8" type="1D" scaling="Hex16"/>
<table name="Minimum IPW #2 SHLR2->NOP (0x4809 -> 0x0009)" category="Misc" address="227ba" type="1D" scaling="Hex16"/>
<scaling name="IPW16:SHLL0" units="ms" toexpr="x*4/1000" frexpr="x*1000/4" format="%.3f" min="0" max="65" inc="0.004" storagetype="uint16" endian="big"/>
<table name="Minimum IPW SHLL0" category="Misc" address="1502" type="1D" scaling="IPW16:SHLL0"/>
After doing the code changes (top 3) you will then need to use the "new" Minimum IPW SHLL0 table to set your Minimum IPW - you will need to replace what the stock value is with ~1.1 or whatever you want. Feel free to use +/- keys to increment/decrement
Cheers
D.
Hey guys,
I tried the Patch above on an Evo7 ECU 90550701 and what it does is strange, first I only see two entries vs three for every other rom, and secondly whenever the Min IPW is touched, the Maf filtering low is changed as well.
Doesn't seem right. Can anybody help? I need to get some fic2150 going on pump gas and this patch would really help.
Attachment of pic for reference
Old Apr 17, 2015 | 06:59 PM
  #204
2winscroll's Avatar
2150's you will need too mess with other start settings as well. Here is what I have with e85 but it should still start just rich.
Attachment 241478
Old Jun 12, 2015 | 11:42 AM
  #205
snooopy365's Avatar
I can't get the patch to work with my 96532706 Tephra V7 rom.
I did insert the patch but the min ipw seems to be set at 0.04ms (have not changed anything yet).
If I insert the values like you should do and set it to 1.028 or even 0.7ms it will still run pig rich.
Is there anything I'm doing wrong? Can't figure out what.
Injectors are 2150 FIC.
Old Aug 21, 2015 | 01:00 PM
  #206
surferjeff's Avatar
Is it just me or did the forum coding screw up this entire thread including the information in the original post?
Old Sep 7, 2015 | 07:29 AM
  #207
pisyakot's Avatar
Hi guys. What min IPW for ID1000?
Old Sep 7, 2015 | 09:22 AM
  #208
mrfred's Avatar
Does not need to be changed for ID1000.
Old Sep 7, 2015 | 12:22 PM
  #209
pisyakot's Avatar
thank you, sir
Old Sep 21, 2015 | 04:58 PM
  #210
Ksay3's Avatar
dose any one happen to have the code for 88590715 rom ? it seems the forums are bugged and cant see any codes.
