Minimum IPW
Old Sep 22, 2015 | 03:52 AM
  #211
pisyakot's Avatar
HTML Code:
<table name="minimum ipw #1 shll2-nop (0x4908 - 0x0009)" category="misc" address="2af7a" type="1d" scaling="hex16"/>
<table name="minimum ipw #2 shll2-nop (0x4908 - 0x0009)" category="misc" address="2af7c" type="1d" scaling="hex16"/>
<table name="minimum ipw #3 shll-nop (0x4900 - 0x0009)" category="misc" address="2af7e" type="1d" scaling="hex16"/>
<table name="minimum ipw shll0" category="misc" address="1102" type="1d" scaling="ipw16:shll0"/>
Old Sep 22, 2015 | 05:56 PM
  #212
Ksay3's Avatar
I don't seem to have scaling="ipw16:shll0 i have InjectorLatency and IPW mcsec under scaling.
Originally Posted by pisyakot
HTML Code:
Old Mar 7, 2016 | 11:46 AM
  #213
BiFfMaN's Avatar
The code for 88590715 rom above, Can anyone confirm that is the correct Code?
Does not seem to work for me, Keeps giving error on loading Rom.
Old Mar 7, 2016 | 09:52 PM
  #214
BiFfMaN's Avatar
Never mind, i was able to find it by Viewing the page source code, nice option in Chrome.
Old Apr 17, 2016 | 08:59 PM
  #215
bostonhatcher's Avatar
Yea the source code in post 211 and 212 do not work for me. Using 88591715 and inserted patch into 88590715 xml file and i can't view anything in ecuflash when the tune opens.
Old Apr 24, 2016 | 09:48 AM
  #216
mrfred's Avatar
Its probably not what you want to hear, but the minimum IPW patch is totally unnecessary if the injectors are tuned properly. In fact the minumum IPW is a complete kluge for when we had no idea about partial opening injector response. See my thread on 2150 settings.
Old May 23, 2016 | 10:48 AM
  #217
wreckleford's Avatar
I read through that thread a while ago but didn't get the above understanding. Are you saying that with the latency value added to the pulsewidth adder added to the commanded pulsewidth the value will be above the standard minimum IPW?
Old May 23, 2016 | 12:02 PM
  #218
mrfred's Avatar
The best way I can explain it is that the minimum pulsewidth trick is being used as a hack way to represent the partial opening non-linear flow response of these injectors. However, it only works at one specific condition, namely at idle. The pulsewidth linearization table covers the entire offboost driving range.
Old May 23, 2016 | 04:00 PM
  #219
tephra's Avatar
so... really the MinIPW patch is meant to help people with their stock rom setup with 1.280... obviously people that have 1.024 as their stock value wont see much value from this patch...
Old Feb 11, 2020 | 07:24 AM
  #220
92LaserRs's Avatar
Having issues with 96530706. 1650s on pump. Evoscan logs no less than 1.28ms, Have applied the patch my xml, tables show up in rom. Change Min to less than 1.28 and never see less than that in evoscan, Idle AFR in the 13's. Anyone able to shoot me a tested/working rom and their 9653 xml to see what my issue is? Email is hernandez.954@gmail.com
Old Feb 11, 2020 | 08:18 AM
  #221
Biggiesacks's Avatar
a couple of things your going to want to look at:
Your injector voltage latency table. Because its a hard coded value that is added to every fuel calc.
Injector flow rate linearization table: https://www.evolutionm.net/forums/ec...ion-table.html
Hope that info helps.
Old Feb 13, 2020 | 10:19 AM
  #222
92LaserRs's Avatar
Ive played with the Latencies, the scaling and the flow rate table, still minimum is 1.28ms. Fuel trims pegged negative.
Old Feb 15, 2020 | 08:21 AM
  #223
240Z TwinTurbo's Avatar
I run the FIC 1650's on pump with no problem using a different rom for a IX, but idle is ~1.1ms. Injector linearization tables won't affect your problem because they don't apply until below ~0.6ms. You got something restricting the lower limit of the injector pulsewidth so make sure you added the correct XML for MIPW. If you have maxed out your trims and your latency is around what I have below then you probably need to increase your injector scalar. Here are my values...
Minimum IPW = 0.024
Injector Size Scaling = 1392
Injector Latency = 0.936@14.06V
Old Mar 25, 2020 | 10:22 PM
  #224
2winscroll's Avatar
Logging raw PW you need too subtract the latencys so he is into the linearization table for sure. I agree the min IPW patch probably isn’t working properly.
Old Apr 5, 2021 | 01:55 AM
  #225
Lancer_Evo_8's Avatar
Its possibile that when i change the OEM MAP with OEM Injectors to 0x0009 that the car will not start?
Whats the description for SHLL2 and NOP? I don't understand them
