New 3D VE Maps SD Rom
Old Jan 31, 2011 | 01:20 PM
  #76
Spec-Ops1's Avatar
anything for the 8859 roms ?
Old Jan 31, 2011 | 01:21 PM
  #77
RoadSpike's Avatar
Waiting for these to be tested before moving onto any new roms.
Old Jan 31, 2011 | 01:22 PM
  #78
Spec-Ops1's Avatar
If you can modify an 8859 with this, i can test that for you if needed. I just happen to have a IX on SD sitting in the shop
Old Jan 31, 2011 | 01:24 PM
  #79
RoadSpike's Avatar
That will have to wait until i'm off work at the very least. Probably tomarrow if i can't get any testers *sigh*
Old Jan 31, 2011 | 01:25 PM
  #80
Spec-Ops1's Avatar
Do you still need testers for the VIII Roms ? I can probably get one of those also if i can throw up the bat signal to a couple customer cars that we have on SD. I'll get back to you.
Old Jan 31, 2011 | 01:28 PM
  #81
RoadSpike's Avatar
Would be nice to have a pro test it out rather than the average joe. I really need to ensure doing the VE table this way wont make the load drift in some direction. If it does I'll have to use uncompensated load.
I also plan on getting a patch together to do like an auto Baro compensation for startups.
Old Jan 31, 2011 | 01:35 PM
  #82
Spec-Ops1's Avatar
Honestly... the first few SD cars I tuned, including mine, i made a 3D table like the one you are using. Load technically should not drift and this is one of the things we were hoping would come out. There are definitely a few out there a lot better than me with this, but i'd be happy to do some testing if i can get the cars back to the shop.
Old Jan 31, 2011 | 01:39 PM
  #83
RoadSpike's Avatar
Works for me i'll better explain the fear i got looming in my head.
Say the map sensor says the car is running 40kpa and that translates to 80 VE. Since the table is compensated its going to stray of its initial value by 80% since VE will have been that amount.
Theoretically it could bounce around some load a bit but i'm hoping its not going to be as bad as i'm imagining. If its unacceptable I think it should trivial for me to come up with my own axis instead of 2byte load for the scaling and make everyone's life a bit easier.
Old Jan 31, 2011 | 04:12 PM
  #84
evoredy's Avatar
Dude, you've done more windows troubleshooting than rom troubleshooting. Lots of patience in here. If I had an IAT, I would test this for you right away.
Are you leaning towards truncating/2difying the fuel map and tuning your 3d VE map? Is that how tuners do SD? Forgive me as I don't tune much.
Old Jan 31, 2011 | 04:17 PM
  #85
RoadSpike's Avatar
Nope i'll just leave the tables for fuel as they are just gives two places for people to tune off of. One will be like a global fuel management table and the other as a fine adjustment one i suppose.
Old Jan 31, 2011 | 04:20 PM
  #86
3gEclipseTurbo's Avatar
Im just waiting for my dp to finish baking then Ima go try this. Ceramic Coating FTW.
Old Jan 31, 2011 | 04:55 PM
  #87
Jack_of_Trades's Avatar
Nice job! I have a SD Evo VIII getting dropped off at the shop next week. I will toss it on the Mustang dyno and build a nice 3D VE table and try it out :-) We already do that with the DSMlink 3d VE tables so it shouldn't take too long.
Old Jan 31, 2011 | 06:13 PM
  #88
RoadSpike's Avatar
Sweet I'm going to get started on the possible issue that rom may have and figure a way to get uncompensated load as the axis point into it.
Gotta make a 9 rom now too both ways o.o;
Old Jan 31, 2011 | 07:26 PM
  #89
gear head's Avatar
Originally Posted by And
are there any plans to add this to the DMA rom?
+1
Roadspike, once you get some positive feedback, It would be great if there was a DMA ROM...SD was so much easier to set up without having to kill the car every time you make an adjustment.
Old Jan 31, 2011 | 09:12 PM
  #90
RoadSpike's Avatar
Originally Posted by gear head
+1
I'll do it for any prepatched rom just don't expect me to patch in DMA for it alongside of this mod
