General non-information about factory ALS
Old Oct 18, 2012 | 09:05 AM
  #526
211Ratsbud's Avatar
I will, I have to hire a good welder to weld my very nice STM uicp.
Going to the baby doctor today to see if I'm having a race car bed or a Barbie bed! So ill be another day on getting things sorted. The 3.6 psi spring is very soft and probably not the last spring ill but for this.
Old Oct 19, 2012 | 04:58 PM
  #527
211Ratsbud's Avatar
Assembly begins tomorrow. The machine shop misread my dimensions so they upsized my feed tubes to 3/4. No biggie and I think that will be a benefit anyways. Just have to order the #16 to 3/4 jic fitting which will be a few more days. Pics of the pieces tonight.
Also going to replace my brake master tomorrow with 2006 lancer drum brake non abs model
Old Oct 19, 2012 | 09:19 PM
  #528
211Ratsbud's Avatar
-16 bung fits right in the flange , the other flange is for the exhaust feed tubes.
Old Oct 20, 2012 | 09:40 AM
  #529
211Ratsbud's Avatar
Old Oct 20, 2012 | 09:44 AM
  #530
211Ratsbud's Avatar
How the outlet flange fits on the wastegate
Dropped the aluminum stuff off to get welded today
Old Oct 20, 2012 | 09:58 AM
  #531
dolphin888's Avatar
Looks much better than stock SAS!
Old Oct 20, 2012 | 11:18 AM
  #532
211Ratsbud's Avatar
I'm impressed how small throttle changes close the valve quickly
Old Oct 21, 2012 | 09:10 AM
  #533
211Ratsbud's Avatar
How I want to to the throttle body switch for the anti lag mapping. Easy enough to switch to alt maps this way!
Attached Thumbnails General non-information about factory ALS-5902328087_e5378caf16_o.jpg
Old Oct 22, 2012 | 06:11 PM
  #534
211Ratsbud's Avatar
Flanges for cold side are welded looks good
Old Oct 22, 2012 | 08:02 PM
  #535
211Ratsbud's Avatar
Old Oct 23, 2012 | 05:41 PM
  #536
211Ratsbud's Avatar
http://www.speedwaymotors.com/Male-S...-AN,34465.html
bought fittings like this to weld to the exhaust manifold in place of the damned banjo fittings.
eliminates the small hole required to flow thru a 16mm bolt, and a copper crush washer.
Old Oct 23, 2012 | 06:04 PM
  #537
JohnBradley's Avatar
AN isnt going to work...needs to be tube for the heat dissipation. Try to make it look as much like factory stuff as possible.
Old Oct 23, 2012 | 07:03 PM
  #538
211Ratsbud's Avatar
I use aluminum an on the cold side of the valve. steel jic on the hot side. jic=an
the piping I made prevously is 1/2 od, technically smaller than stock because its real hydraulic hardline which is thick. Ive been looking for .060" ish tubing but I have to stay to local resources for most of this to cut costs/time.
I am running no BOV at all with this new set. The -16 line bolts to my greddy flange with a greddy flange. the -16 other flange bolts to the dumptube side of a tial f38. The figure 8 looking flange splits two 3/4" tubes to the factory bosses. Steel hardline on the exhaust mani.
http://i696.photobucket.com/albums/v...-20-18_357.jpg
my current set up^
I have factory stuff. but the valve failed in a short time.
I am aiming to recreate the flow that is alluded to in the gr a pictures. granted 4 pipes feed each runner
u know i hhope this works! im in it til it does
Old Oct 24, 2012 | 05:42 PM
  #539
211Ratsbud's Avatar
http://www.sxoc.com/vbb/showthread.p...-Lag-Solutions
Old Oct 26, 2012 | 08:00 PM
  #540
211Ratsbud's Avatar
Alrighty, 90* fitting came in for the damned cold side supply line. So I am merely waiting on a local hydraulic shop that is willing to help fab OEM looking hardlines, to infact help. They do OEM stuff for bobcat/skidsteer applications so its gonna look snazzzy
