763whp/595tq STOCK ECU, SpeedDensity, E85 by TTP!
Old Nov 9, 2009 | 09:47 AM
  #286
Chele's Avatar
I know there is alot of favoritism/nutswingage/bandwagon jumpers on this site. I try to ignore it. I just wonder what happened to taking it to the track and fighting it out? Let's get all these shat talkers out in their cars and start running each other. (preferably at the same track at the same time)
Old Nov 9, 2009 | 09:48 AM
  #287
SloRice's Avatar
I'm down...let's go to the track! But TTP makes 100whp more than I do, so I should get the hit and some car lengths right....
Old Nov 9, 2009 | 09:49 AM
  #288
norcalSRTrida's Avatar
Originally Posted by Celica2EVO
Maybe the new thing should be no correction factor? If its ONLY a tuning tool, then why **** with the correction factors?
Correction factor is what is making these numbers so outlandish. Also, Nicks car is FULL weight with a roll bar and safety equipment on 18" wheels.
So how about from now on, TTP DOESNT use correction factors and then their numbers might correlate with others?
i concur, for comparison's sake and even playing field.
Old Nov 9, 2009 | 09:50 AM
  #289
Celica2EVO's Avatar
lol, guess we were both thinking the same thing! haha
Its fine to give your customers the sheet with correction factor to show off to their budies, or to compare it to older sheets/set-ups.
But for the sake of the community and other vendors, use UNCORRECTED and im willing to bet you wont get ridiculed so bad for the numbers you put out.
  #290
Mellon Racing's Avatar
Originally Posted by TTP Engineering
For the same reason that BR claimed a E.T. Record stock ECU and that Mellon claimed the MPH record and it went uncontested for months is the same reason we get the witch hunt.
POLITICS.
Mellon did not get crap because he uses a BR engine. You have to really take a close look at all these usernames and the politics behind them. Most of them use a part or engine from BR which gives them forum immunity from the witch hunters.
Since we do not use ANY parts from them, we get the worst of it.
I don't know about that scott, I get contested quite a bit with regards to DLL numbers, I'm not immune because I run BR parts. If people think something is fishy, they'll call me out in a heartbeat as they should.
WCF in the heat of summer can read higher than uncorrected MD, but lower than DJ.
WCF in the winter will read lower than an uncorrected MD.
Uncorrected for this car is 708-713whp.
I don't understand how this answers my earlier questions.
Originally Posted by norcalSRTrida
im copy/pasting my post from DB's new thread into here because it fits, and i have to beg a question...
look at the results here people.
both dyno'd w/in 10hp (w/ TTP's uncorrected #'s, not his 763), and both ET'd w/in .1, and trapped very similarly to eachother...within 4mph
that is a direct comparison from TTP's dyno to DB's dyno.
with that said, can we all say that TTP's MD isnt as far off as previously stated, and is because of which factors he uses (corrected vs uncorrected)?
you can't compare mph without comparing race weight.
Old Nov 9, 2009 | 09:51 AM
  #291
Celica2EVO's Avatar
And Im game for the track! Bad tranny and all, let me know when and where! lol
Old Nov 9, 2009 | 09:53 AM
  #292
SloRice's Avatar
DB just had a 705hp car on his dyno and guess what? it runs through the 1/4 at 10.0@147
compared to
TTP's 715hp UNCORRECTED w/ 10.1@143 (w/ bogging and 1st time out to the track w/ the setup)
TTP, for the sake of this community, stick w/ uncorrected.
TTP's car has the stock final drive. The car DB just posted making 705hp had the 3.73 final drive when it ran 147. Its now has a 4.11 final drive.....I think that 147MPH is going to go up a bit.
Old Nov 9, 2009 | 10:01 AM
  #293
TTP Engineering's Avatar
You get contested because the Vendors with real $65,000-$125,000.00 dynamometers do not want to be discounted by a free program which has proven to be flawed like when a stock turbo MR at 18psi can make 400whp+ on pump.
That is taking about others cars, not yours.
When it comes to your car, we do not see any contests by the witch hunters.
Old Nov 9, 2009 | 10:02 AM
  #294
and who's to say TTP's car wont go through the traps a few mph faster once he irons out his driver mod at the track?
im not taking any sides.
im just noting that hp #'s and et/trap comparisons between those 2 cars are Very similar once we look at TTP's car w/ uncorrected #s.
TTP's et's and traps make more sense now after seeing them in uncorrected form and comparing it to a car of similar weight and power.
nothing more, nothing less.
Old Nov 9, 2009 | 10:08 AM
  #295
Better yet. Maybe just let Ryu take a crack at it. The TaeKwonDoe kid weighs about 40lbs less than me as it stands and I am rusty.
Old Nov 9, 2009 | 10:24 AM
  #296
batty200's Avatar
It doesnt matter where it started. You think every single horse in existence make 1hp? Well technically it does but they arent all the same. Also since that initial fudge we have developed everything around that to calculate and compare things using a standard. So DJ hp is the standard by which all are judged. When the #'s make sense using the reference for a control then we are able to fairly compare the #'s. A car that does xxxwhp on a DJ then does a certain trap speed/weight then conforms to the specs and can be compared to other cars using the same calculations. Who cares if we call it a mulepower or a bird power. 1 ft was the random benchmark chosen to describe distance because it was the size of some kings foot. From there we make calculations and comparisons. Now if someone else comes around with a new "foot" it will cause lots of issues.
batty200 - feel free to read this article before you start making claims that Dynojet numbers are the end-all, be-all.
http://www.hotrod.com/thehistoryof/1..._creation.html
Dynojet's read flywheel horsepower, not wheel horsepower. Right there in black and white straight from the inventor of the Dynojet Dynamometer.
Old Nov 9, 2009 | 10:26 AM
  #297
shunderwunder's Avatar
^ Thats another good point. The track times were not with a "ringer" driver
Old Nov 9, 2009 | 10:53 AM
  #298
I have some theory on why that is
Old Nov 9, 2009 | 10:54 AM
  #299
R/TErnie's Avatar
Originally Posted by gsrboi80
This is your formula no tricks ok. Again its math can't really fudge it
MPH= the cube root of (HP/WEIGHT) x 234
MPH= (HP/weight)^.333)*234
GSRBOI,
How did you come up with MPH is cube root of HP/Weight times the constant 234?
Please... derive your equations from worldwide accepted constants and equations.
You have not shown me anything related to physics yet. You solved a middle school level mathematics equation.
Old Nov 9, 2009 | 11:39 AM
  #300
batty200's Avatar
Originally Posted by R/TErnie
GSRBOI,
In order to setup those equations requires a lot more math than anyone on this site could do in any appreciable amount of time but you can simply search online and see any # of thousands of websites that will tell you this is the formula. Just as you would be unable to produe a proof for the F=MA formula in any way doesnt mean it is not right.
