Map built evo 8 2.4l fp black e85
Old Feb 22, 2011 | 08:39 PM
  #76
goodhart's Avatar
I vote for the Injen LICP and intake and the MBC. Just my opinion.
Old Mar 1, 2011 | 07:15 AM
  #77
navysandsquid's Avatar
I just talk to Forge and asked him his opinion. He said that either I have the soft spring in my MBC or WGA isn't adjusted properly. I don't have the hard spring. Does anyone know where i can get one?
Old Mar 1, 2011 | 11:13 AM
  #78
ChrisCarey's Avatar
Finally found some time to test some theories, this is a simple swap to a Hallman MBC. There was no appreciable peak HP gain (we didn't take the time to perfectly match the boost levels) but spool was significantly improved upon as well as whp and torque at lower RPM levels.
Old Mar 1, 2011 | 11:16 AM
  #79
ChrisCarey's Avatar
Now for the fun part, most people looking at a list of mods wouldn't assume there would be a significant difference between a standard aftermarket O2 housing / downpipe combination and our O2 Eliminator...they would be wrong +23.55whp and +41.17ft/lbs is pretty significant in my book! Spool improved even moreso as well.
Old Mar 1, 2011 | 11:19 AM
  #80
Magnumpsi's Avatar
I mean that looks to me like the valve springs are too weak. I know there was some problems with Supertechs before.
Just a thought.
Good Luck.
Mitch
Old Mar 1, 2011 | 11:36 AM
  #81
Originally Posted by ChrisCarey
Now for the fun part, most people looking at a list of mods wouldn't assume there would be a significant difference between a stand aftermarket O2 housing / downpipe combination and our O2 Eliminator...they would be wrong +23.55whp and +41.17ft/lbs is pretty significant in my book! Spool improved even moreso as well.
WOW! nice that clears things up thanks! That not only clears things up for me but says alot about your product. You can use that on your site. Thanks for taken the Extra time to do that. What can I do to make the curve more linear instead of going up and dipping and going down.? Also I was curious on the correction on the Pulls?
Old Mar 1, 2011 | 11:37 AM
  #82
ChrisCarey's Avatar
Replace your Injen licp with ours It's still a bit wavy but the big dip at 6500 all but disappeared. Couple that with an 8whp peak gain and I'm pretty happy with the results considering it was aftermarket vs aftermarket.
STD correction, smoothing 5.
Old Mar 1, 2011 | 11:52 AM
  #83
ChrisCarey's Avatar
Overall gains from swapping the following:
Forge MBC (Soft Spring) to Hallman Pro MBC
MAP Standard O2 Housing / Unknown 3" Downpipe to MAP 3" O2 Eliminator
Injen LICP to MAP LICP
+32.21whp
+44.2 ft/lbs
Old Mar 1, 2011 | 12:54 PM
  #84
VRSF Tiago's Avatar
It's amazing what the right part configuration will do for you
Old Mar 1, 2011 | 03:53 PM
  #85
Fast_Freddie's Avatar
Veteran: Navy
That is more like the graph should look like, great job with just swapping a few parts out!
Old Mar 1, 2011 | 04:17 PM
  #86
Boltz.'s Avatar
FCOTM Winner
Three things just don't add up here....
FP Black, Kelford 272 and peak power at 5600rpm. I think there has to be something holding the car back and the first thing I was thinking about was valve float, but what do I know.
How does the graph look uncorrected or at a more reasonable correction factor?
If you guys think it is the TB and IM holding the car back, why was the LICP, MBC and downpipe swapped instead? Not trying to sound hostile in any manner, just some constructive criticism.
-Justin
Old Mar 1, 2011 | 04:40 PM
  #87
-Justin
They are currently swapping manifold and throttle body the exhaust manifold
Old Mar 1, 2011 | 07:02 PM
  #88
norcalSRTrida's Avatar
+32.21whp
+44.2 ft/lbs
very impressive gains just from switching a few basic mods. good job MAP.
as a few others mentioned...looks like there may be some valve float issues up top that may need to be addressed though.
Old Mar 1, 2011 | 08:25 PM
  #89
ChrisCarey's Avatar
Steve,
I can't recall were the springs new or did you pick them up used? If used, do you have any background?
Old Mar 1, 2011 | 11:33 PM
  #90
evoyrrah's Avatar
i love this car...what headgasket and studs u guys using?
