Evo 8 MR + FP red + 27-28psi + 93oct
Old May 7, 2011 | 09:54 PM
  #46
BEISSEN's Avatar
Originally Posted by Hardware
You should check my results. Being told cams are holding me back.
https://www.evolutionm.net/forums/ev...ur-racing.HTML
Or
http://tinyurl.com/3mvkk2o
-Brian
I saw this one before, I remember it when I was looking and I did almost 400 in 3rd gear in a Load Bearing Dyno Jet that reads pretty low set to uncorrected so it was not adding much if anything. Did you since change your cams? I did not want to go through a million pages lol. Have you made any other changes to the car since then may I say honestly fo some of the limiting factor like the BOV and all as you will be amazed as the BOV can cause some issues after 25psi crushed or not. A good one if you want to stay with a Recirculated is the Forge RS it has a hold of 36psi I think and you just have to adjust it in per you boost by tuning the knob on it.
Old May 8, 2011 | 01:56 AM
  #47
OsirisFool's Avatar
looking pretty sick
Old May 8, 2011 | 04:25 AM
  #48
BEISSEN's Avatar
Originally Posted by OsirisFool
looking pretty sick
Thanks. Where in va do you live?
Old May 8, 2011 | 09:10 AM
  #49
Hardware's Avatar
I didn't change anything since. Thinking of doing Kelford 272 or GSC S2's , Synapse DV, Perrin air filter and maybe jm fab mani. I made a mistake last year by buying parts based off of 5 year old test info. Hoping to correct it and be done with it. Thanks for the info.
-Brian
boostedmkiii
Apr 20, 2013 07:20 PM
tscompusa2
Jul 31, 2012 07:50 PM
tscompusa2
May 28, 2011 01:51 PM
tscompusa2
May 20, 2011 10:37 PM
tscompusa2
Apr 18, 2011 09:01 PM
