MAP EF-series Turbochargers results thread
Old Jan 29, 2012 | 12:38 PM
  #511
EnjoyDriving's Avatar
Hey, my friend. As far as I know, quite a few of my evo buddies have just ordered the EF turbos from MAP too, including myself, getting an EF2 - ported and coated I also picked up a set of S2 cams and MAP beehive springs from them too!!
My ordering process has been real smooth and great, as usual, MAP provides an exceptional customer service. I believe it should be ready for pick up in a week or so, and then I will be posting some pics and comment!!
Originally Posted by pure_evo
This thread has not had any activity lately. Are there no more EF turbos floating around? I have to tip my hat to MAPerformance family for helping me through the process to step up to the EF4. Thanks fellahs.
Old Jan 29, 2012 | 02:26 PM
  #512
Svendiesel's Avatar
Heres my virtual dyno sheet, real dynojet sheet will be coming soon. 43psi on E85, BR LR 2.4L with Stage 3 Head and GSC S3 cams.
675/606
Old Jan 29, 2012 | 02:47 PM
  #513
Jeff_Jeske's Avatar
^^^ HOLY ***K! That is a dream machine.
Full mod list please!
Old Jan 29, 2012 | 05:04 PM
  #514
Levar's Avatar
Veteran: Army
Originally Posted by Kracka
I'll have more details soon, but I was able to squeeze a little more power out of my setup. Let's see, what else do I know...oh, my buddy will be upgrading his 2.3L IX from the EF3 to the EF4 sometime this spring.
I, too, have made some slight changes to the parts sitting in my garage. The first of which is swapping the EF3 for the EF4. The second is that I got rid of my Injen downpipe in place for the MAP O2 eliminator dump set up. And lastly, I will be making an order for the MAP Stage 1 2.3L engine in about two weeks so that the engine is waiting for me when I get home from Afghanistan in early March. The only thing I am on the wall about is whether or not to pick up a Stage 3 head while I am at it.
That is fantastic, my friend. I know you were battling back and forth with the decision and I am glad you finally decided. Keep everyone posted.
Old Jan 30, 2012 | 03:01 AM
  #515
burnzy's Avatar
Now I think I have a cracked wastegate flap or something along those lines. My ef4 is way too laggy on my 2.4 and today tried with no hose attached to the wastegate line, max
It hit was 31psi. I'm pretty sure freeboosting it should be way above that?
Old Jan 30, 2012 | 06:54 AM
  #516
CurseDSM's Avatar
I had something similar with mine. It was preload on the turbo. Did you get your new wg put on the car? If so make sure you have proper preload. Take the line from your boost guage and put it on the wga and find out where the thing is opening. That will let you know what is going on. Either that or you have a nasty *** boost leak.
Old Jan 30, 2012 | 04:16 PM
  #517
burnzy's Avatar
Yes the new gate is preloaded, no I don't have a boost leak nor any exhaust leaks or a clogged cat nor a dodgy tune. IMO only thing left in the turbo itself or the wastegate flapper
Old Jan 30, 2012 | 04:36 PM
  #518
CurseDSM's Avatar
How much preload? I ask this because I did have a similar situation with mine and sure as **** not enough preload. I have on my car right now about a quarter eye lid of preload which is about 25 psi. This is all the boost I am running at the moment being it is only the wg pressure. I don't mean to beat the preload to death but i wasn't sure until I found where the wg was completely closed and worked my way backwards from there. My graphs were UGLY needless to say, but sure enough as soon as I found where it was completely closed I backed it off to where it is now and made a world of difference.
Old Jan 30, 2012 | 06:57 PM
  #519
burnzy's Avatar
anywhere from 1/2 hole to a full hole, over 3 different actuators. it's running more preload than i've ever had to run on any other turbo. i can probably etch a tiny bit more preload in there but at that point the wastegate would have almost 0 movement available to it. wierd thing is going from 1/2 hole to full hole of preload isn't affect the spoolup at all. I know where you're coming from, first thing that came to my mind was preload or dodgy actuator too.
Old Jan 30, 2012 | 07:20 PM
  #520
CurseDSM's Avatar
Well that is good info. I hate to say it but like you have been saying, maybe time to take the turbo off and look at the wg hole.
Old Jan 30, 2012 | 07:36 PM
  #521
Kracka's Avatar
I know another member who went EF4X tonight
Old Jan 30, 2012 | 07:44 PM
  #522
murlo26's Avatar
Oh really, another person joining the dark side of big stock frame goodness huh?
Old Jan 30, 2012 | 07:51 PM
  #523
burnzy's Avatar
cursedsm, was your rear turbine wheel clipped this much?
Old Jan 31, 2012 | 08:40 AM
  #524
ChrisCarey's Avatar
I believe Brian was one of our Beta testers, the turbine wheel clipping was implemented after that when in house testing revealed subtle improvements in both spool and power output, I assure you that is not the issue at hand here. Do you have any pictures of the wastegate flapper, is it seating properly?
Old Jan 31, 2012 | 05:34 PM
  #525
burnzy's Avatar
I was actually looking for that also chris, unfortunately I took pics of every part of the turbo except the flapper lol!
