Why you need to do an EGR delete
Old Aug 22, 2014 | 04:38 PM
rich3389's Avatar
You guys act like this is something new...
Old Aug 23, 2014 | 04:35 AM
egis's Avatar
Some new guys on forum don't know.plus I personally didn't know that I can gain power with this simple trick.
Old Aug 23, 2014 | 06:30 AM
wreckleford's Avatar
Its not new, but I think this is the first time the power loss has been documented.
It should be noted that this power loss would not occur with a properly functioning EGR system.
Old Aug 23, 2014 | 07:42 AM
Blue91lx's Avatar
What you fellers need to do is be a man and drill/tap the EGR port on your head so the superheated gases don't still heat up your IM and thus your air charge .
Old Aug 23, 2014 | 10:14 PM
khmerpimpin's Avatar
Is this with removing/blocking egr valve only or also with blocking the gas recirc from the head?
Old Aug 24, 2014 | 06:36 AM
egis's Avatar
I left the head alone.I blocked just im side. gas coming from the head can't enter the im anyway.
Old Aug 24, 2014 | 09:51 AM
Grimgrak's Avatar
Am I reading that dyno wrong or is egr spooling way the f faster!
Old Aug 24, 2014 | 01:02 PM
Faisalm's Avatar
I think you're confused lol... look at the boost curve on the graph. It's identical with or without the EGR delete.
Old Aug 24, 2014 | 01:45 PM
Bhsj13's Avatar
so, will i need a tune? can i put the block off there and leave the rest on for visual purposes? what does this do immediately for the car?
Old Aug 24, 2014 | 10:05 PM
ZanarkO's Avatar
no you dont need a "tune" when removing EGR unless your on Speed density (My opinion) your maf will compensate for the difference in air flow. But you will need to a tune to remove all the CELs associated with the EGR removal. The purpose of the EGR is to recirculate Exhaust Gas back into the intake to reduce the formation of Nitrogen Oxides (For the Enviroment, Emissions etc.) The negative side of this is of course all that soot going back into your intake causing it to get VERY hot and there for lowering Air Density effecting power. Also in high boost scenarios that rubber line can pop off and cause a vacum leak. Removing all that crap helps keep temps down in the intake and also removes chances of a random vacum leak.
Old Aug 25, 2014 | 08:29 AM
Bhsj13's Avatar
so just simply sandwiching the plate will throw a CEL?
Old Aug 25, 2014 | 10:37 AM
JohnBradley's Avatar
Originally Posted by mdsevo06
Have you noticed any increase in vacuum after removing the EGR? I've noticed my BOV slightly opening under very light throttle after the removal, without changing springs.
Havent really thought to look for it, but if yours was bad like this then yes since its a vacuum leak.
Originally Posted by e_kobz
Take my money will definitely be ordering this.
Originally Posted by mchuang
Nice information. Thanks, gonna get one also.
These will be up on the store today and I will link it
Originally Posted by slowsrt4:(
you guys have to change some things in the tune with the EGR delete or we will get a check engine light right?
Yeah easy change in the periphery
Originally Posted by Go_Lancer_Go
I posted this question in the vendor announcements however this is more of the discussion thread.
I was wondering if this is just the block off plate I ordered from you guys or is this something else.
Same thing you have already ordered.
Old Aug 25, 2014 | 10:39 AM
Properly functioning is less likely with higher mileage which is what I have noticed...it also leads to idle issues as it starts to gunk up the IAC and TB. Worst case is like the DSMs and it will eventually destroy the IAC once its started leaking 100% of the time.
Yes but this is far easier to do in an afternoon
No, it is spooling faster with the EGR delete. BLue is Deleted.
Old Aug 26, 2014 | 01:48 AM
94AWDcoupe's Avatar
these results will certainly sell some block off plates. lol
I have seen dyno results show just the opposite on dsm forums. this is an emissions device that recirculates exhaust gases back through the intake. "why would you do that?" for a more complete burn! cleaner emissions. results will vary on how rich or lean the tune is on the car.
Old Aug 26, 2014 | 07:36 AM
mkcolgan's Avatar
Just picked a block off plate up, Can't wait to rip all that crap out along with the EVAP, less hoses = less opportunity for all my boost's to leak all over right?
