FP Zero/Zephyr Dyno Results Thread
Here are pics of engine bay downpipe and the Virtual Dyno graph. This is an FP Black but it does have the SS turbine housing and the FP O2 housing so it has some relavance. When asked if I had results I forgot this was the Zero/Zephyr thread.
I have some preliminary results. At 22psi on 93 octane the car made 440/332 on Virtual Dyno. On Friday we are going to the drag strip to run it. The owner says he won't be launching the car because he has stock trans and transfer case with the open front diff. We are hoping it traps over 120 at 22psi.
The mods are as follows:
Stock head intake manifold, throttle body
Built 2.0
Wiseco 1400 HD low compression pistons
Manley Turbo Tuff Rods
GSC S3 Billet cams
GSC High Rev Springs
Kiggly HLA
ARP L19 head studs
OEM clearances and bearings
OEM crank
FP Black JB SS Housing
FP Race Manifold
Buschur Racing Exhaust modified to fit
ETS 3.5" FMIC and pipes
FP Silicone Intake pipe
FIC 1800cc injectors
Buschur Racing Double Pumper
ACT XTSS with Street lite flywheel
Car is fun so far and when it is time we will crank up the boost to make some big power. I will update after the track Friday. I'll post the VD chart when I get on my laptop.
Built 2.0
GSC S3 Billet cams
Kiggly HLA
ARP L19 head studs
OEM crank
FP Race Manifold
Compression piston and be on e85.
I hope to break 700hp with mine, also running the new ss back housing and race manifold tuned on the new Haltec Elite ecu
