FP Zero/Zephyr Dyno Results Thread
Took the car to the track at 663 WHP 35psi and pretty low timing yet.
It smokes a bit, working on a solution. Car went 10.3 @ 140. I weighed 3220 on the scales. I'm fat. 1.6X 60 ft
Gonna turn it up and add some timing in up top. Raise the limiter and see how she does at shootout.
https://www.facebook.com/beachfuzz/videos/10207608139265265/?pnref=story
Nice work!
Such a huge shame that the FP-cored turbos all seem to be so plagued by oil issues - assuming that this is the likely cause of the smoking on yours? I really want to love their turbos, especially the new Xona Rotors but if this is yet another smoky FP unit then it's not looking good. Please put me right if I'm wrong on this, and I'll edit out that comment.
i run just the old buschur catch can, with the stock pcv valve and ports.. i have an fp red pushing 633 on c16... zero blow by, zero smoke. only thing i have different then most is the ER oil gear.
zona center section on the red? plain bearing? what pistons are you running?
do the numbers on it tell you anything?
Weiso 1400HD 9:1 comp
I made 815whp on the FP ZERO in 3rd. This turbo should be able to make 840-850whp on a maxed out setup, or more. Hell, I could have made that in 4th and it wasn't even falling off at 8500. It was a power house. However, Robert forced me to run a few restrictive parts when I tested the FP ZERO for him so I wasn't able to max it out. Actually, the new FP SS hotside design was a better copy of what I was running on my FP Black since 2010 when I made 748whp on the Black. It wasn't Robert's design however, Robert liked it and built it for the ZERO in SS. My hotside was ported out to be a single scroll 10.5. Sadly the ZERO I tested, didn't survive the weekend but was a riot. I had the first FP ZERO back in Nov 2012 and many people saw the results and never new it was a ZERO
https://www.evolutionm.net/forums/ev...rd-815whp.html
Here is my single scroll FP black if anyone wants to see what that SS housing does to an FP Black. https://www.evolutionm.net/forums/ev...ck-748whp.html
Miss the community, I need to get another evo and come back. lol
Mikey
Mikey
I seen the car at the shootout and it was very impressive! We spoke to Robert (fp) about it as well. Congratulations on the win!
What weight reduction mods have you done? Motor specs?
Thanks,
Jeremy
