FP Zero/Zephyr Dyno Results Thread
You are referring to the oil feed line FP provides with the turbo, correct?
Since all the "new" turbos are ball bearing the oil feed line goes to the same spot on the head as the stock line did. To the left of the front cam angle sensor...
On the Journal bearing turbos the oil feed line came over the oil filter housing...
Nope, ball bearing turbos, oil feed line off the head.
Journal bearing turbos, oil feed line off the oil filter housing, for stock frame turbos at least. And make sure you pick the correct port on the filter housing, pretty sure (1) port is unfiltered oil & (1) is filtered oil.
Why would you run coolant lines to the wastegate? Unless you are doing constant hard driving like a 24 hr LeMans it's pointless. The every day driver and the weekend warrior don't need that.
Just a reinvention of the wheel. "Hey you have our old design wastegate and it works great for you?" "Well checkout our new designed wastegate, it does the exact samething but has coolant jackets now!" "You know you want/need it."
Should I change my set up now??
Coolant circulating through the top hat of a wastegate won't make much of a difference. Never caused an issue before on any car I know of before they came out with this new design.
The new wastegate has a much smaller head than the old One. Smaller means less thermal mass so damage can happen easier but with cooling it can equal or surpass the larger wastegate. That's the point.
I have run turbos for years with out water cooling. to simplify service. does that mean its a good idea and not needed? heck no. water circulation keeps the parts at lower temps. the parts will give longer service life hands down.
