FP Zero/Zephyr Dyno Results Thread
Old Feb 27, 2015 | 08:06 AM
  #166
06MREvo's Avatar
Michael @ FP, when you get a chance, could you answer the below question??
Originally Posted by mchuang
Fair enough, hopefully results are promising. Do you anticipate the Zephyr to spool faster than the Black since the compressor wheel is smaller, even though the turbine is larger, while making more power?
As previously mentioned in this thread, going off the below link with a car TPG tuned, the car looks super laggy. I know every car is different & there isn't much info besides, it being an Evo 9, 93 oct & 28psi. I would assume/hope that the below results may have been on a 2.0...
https://www.facebook.com/12162768460...type=3&theater
Specs from the FP Black & FP Zephyr...(Correct me if I'm wrong on anything)...
FP Black--------FP Zephyr
82HTZ----------79HTZ
67/59mm------68/62mm
68LB------------70LB
I will be buying a turbo for my 2.3 build within the next month or so. Unfortunately I will have to run 93 oct. Car will be around 2800lbs +/- & also have a 4.11 FD. Obviously the FP Black is a proven turbo but I'm very interested in the FP Zephyr since it flows 2lbs more than the Black. I am trying to build the car as well rounded as possible, as it will be driven on the street also but also autocrossed, 1/4 mile & a little road course duty.
With having to run the car on 93 oct., I would imagine it would end up being tuned for around 28psi +/-. I am trying to put together a build with the least amount of lag possible but still easily make 500whp+. I was HOPING the Zephyr would spool the same as the Black but make a little more power up top but TPG's results above don't show that.
Since it is getting closer to spring I am hoping we will see more Zephry results popping up.
Old Feb 28, 2015 | 04:17 AM
  #167
J_Heath's Avatar
What I can tell you from experience, my buddy with his FP Black (stock bottomend 2.0L) lag is minimal slightly more than a stock turbo. My other buddy (Des or whatever his screenname on here lol) has the zero on a fully built 2.4L and the lag is the same or less. Both Evo's spool quick and have zero issues spinning tires.
The one on the black makes 565awhp & 450ft lbs on 93 octane with water meth
The one on the zero made 650+awhp on 93 and 808awhp & 600+ ft lbs on E85.
The car on the black was at 31-32psi and the car on the zero was at 40-42psi making 800awhp.
If you're wanting to autocross the car and make 500awhp i'd suggest a red for the quickest spoolup on a 2.0L but with the 2.3L i'm sure you'd have no problem with a black and it would be a blast to drive.
Just be sure you have all supporting mods, cams that don't rob your mid-low range power, or go overboard on an intake manifold (like a huge plenum manifold).
Old Feb 28, 2015 | 05:40 AM
  #168
06MREvo's Avatar
I appreciate your feedback. At this point the Zero is too big for my wants & needs. So that is why I am trying to decide between the Black & Zephyr.
I was heavy into autox with my '06 MR 6+ yrs ago but that was on stock turbo, a bunch of bolt-ons, suspension, r compounds, etc. So I know that an FP Black or Zephyr isn't that best turbo choice for being competitive in an autox class. However, since I now have an '06 RS that will be under 2800lbs, with a 2.3 setup & 4.11 FD I don't think I will do too bad, haha. I don't plan on attending autox events that often, maybe once every (2) months or so. When I used to autox with my MR it was pretty much full weight.
I had an FP Red 5 yrs ago on stock block & S2 cams. Fun turbo till it blew & I had to send it back to FP. From there I went to a BBK Full then BBK-B. So at this point I'm not interested in going back to an FP Red.
Curt Brown did my shortblock & head. I will be using R2 cams & I also have an FP Cast Manifold that Curt ported as well. In regards to the intake manifold, I have a MAP Rev3 with Milspec TB.
Old Feb 28, 2015 | 03:33 PM
  #169
Sikilla's Avatar
A 2.0 made 803hp and 644tq on a Zero today at Ag Autosports in south fl tuned by Crispeed.
Dyno sheet is on Ag Autosports Instagram.
This is the only shop I would ever let touch my evo in south fl.
Check these Guys out, Anthony the owner goes above and beyond for his customers
Old Feb 28, 2015 | 04:21 PM
  #170
silver03evo1's Avatar
^^ this was also on small cams and a non ported head. Should still have more left in it for sure.
Old Feb 28, 2015 | 05:43 PM
  #171
most wanted's Avatar
Originally Posted by batty200
Can you take pictures of it all installed? I have a friend who has a Black who needs a down pipe solution. If this is already on and working I will recommend it to him.
I chopped off the Vband flange and welded my old downpipe onto the Atp downpipe
Tial 38mm with dump tube
Old Mar 1, 2015 | 07:55 AM
  #172
batty200's Avatar
So it definitely needs a lot of custom work. It looks like a good solution if you can have someone or can do the fabric work you self. It is probably similar in cost to the FP solution. Good work.
Old Mar 1, 2015 | 10:28 AM
  #173
d-bo's Avatar
Really the best bet is to probably have a custom one built. It probably won't cost much more than a new off the shelf piece and then you can sell your old setup. Or just modify it.
Old Mar 5, 2015 | 04:31 PM
  #174
ZanarkO's Avatar
god, just make an o2 housing that will bolt up to a 2 flange 3 inch factory style downpipe.
  #175
ZanarkO's Avatar
and where the **** are all the dyno results? This thread fails
Old Mar 10, 2015 | 04:28 AM
  #176
pls1968's Avatar
I will be starting a thread very soon. My FP ZERO made 803HP/644TQ.
Old Mar 10, 2015 | 09:21 AM
  #177
d-bo's Avatar
Hopefully we see some track times too. I don't really care what the dyno numbers are. They don't mean much
Old Mar 10, 2015 | 11:23 AM
  #178
TheBoz's Avatar
I agree.
I love FP products, but I am just not sure what the appeal of the stock frame is anymore. What I would love to see is the Green stuffed into a tial vband hotside housing. That would be gangster.
Old Mar 13, 2015 | 07:40 AM
  #179
06MREvo's Avatar
Bumper for a possible reply from Michael @ FP.....
Old Mar 15, 2015 | 08:52 AM
  #180
Bump any new track times or dyno numbers
