Stepping my IX up for 91/E85, looking for final preparation suggestions
Old Apr 20, 2018 | 04:34 PM
  #241
Don
That answers a couple of questions you had. Good work. The injectors will be flowing
Old Apr 20, 2018 | 08:49 PM
  #242
2006EvoIXer's Avatar
I can't figure out why RC only got 1400cc at 43 psi out of them. The marking on each is: 126 1650H
Maybe the filter RC used is more restrictive? Does anyone understand how to read this:
Old Apr 21, 2018 | 11:46 AM
  #243
Evo8cy's Avatar
These are good results, and these FIC ball and seat injectors seem to perform, are consistent and retain a pulse width which is easily tunable. The reason you are seeing 1400cc/m instead of 1650cc/m is the fact that these are tested at their 80% duty cycle with base pressure at 43,5psi, which indicates that at 100% of duty cycle they give out 1730cc/m. If they were at 1650cc/m they should've been at 1320cc/m at the specific base fuel pressure and 80% idc.
They should have also given you a dynamic flow test results besides the static one.
Marios
Old Apr 21, 2018 | 12:02 PM
  #244
Thanks Marios. This is the only sheet that was given with their cleaning.
Old Apr 21, 2018 | 12:16 PM
  #245
Evo8cy's Avatar
No worries, glad to help out. They could have included the dynamic flow results on the same result sheet, but nevertheless these are good results.
Some additional info, you are pushing approximately 134lbs/h through these at 80% duty cycle, which is good for 800-850 crank hp depending on the dyno on 93 oct gasoline, or around 600-650 crank hp on e85 as methanol being a highly oxygenated fuel requires more fuel per pound of air to yield the same afr. Always on a properly prepared setup.
Marios
Old May 15, 2018 | 09:52 AM
  #246
Update:
1:
2:
3:
4:
Old May 15, 2018 | 10:11 AM
  #247
Shop still needs to blend the cuts, knife edge the intake splitter, and mill head. Hopefully, I'll be picking this up this weekend!
Old May 15, 2018 | 10:22 AM
  #248
Don
So this ridges are from the oversize valve mill work? These ridges will get blended?
Old May 15, 2018 | 10:24 AM
  #249
Don
they will smooth out all the corners. Let me find a photo of a finished head.
Old May 15, 2018 | 10:32 AM
  #250
Here's one that was blended in combustion chamber. Not sure what happened to first picture, but I just added a photo of my bowl below.
Old May 15, 2018 | 10:34 AM
  #251
Don
those ridges help air flow. There's a nice curve to it.
Old May 17, 2018 | 02:55 PM
  #252
Few new photos!
Old May 17, 2018 | 07:10 PM
  #253
More photos!!!
Old May 17, 2018 | 07:37 PM
  #254
Old May 17, 2018 | 07:58 PM
  #255
Don
I see a lot of CFM going on $there$ (hope you dont mind a little levity on your thread=)
On a serious note, it all looks proper & on the higher level of what most guys have never done
