Post exact weights of weight reduction you have done!
Old Dec 19, 2012 | 06:48 PM
  #1591
EvoDan2004's Avatar
Originally Posted by 03whitegsr
The engine harness is pretty straight forward to slim down. I wouldn't be too intimidated by it.
If you are pulling the A/C, AUX fan, disabling the clutch safety and ditching the fuel pump resistor and going high impedance injectors, you can clean things up nicely. There is a relay box attached to the side of the main fuse box. Off the top of my head, these are the relays in it:
A/C compressor
AUX Fan HI speed
AUX Fan LO speed
Clutch Safety Interlock
MFI Power
You can cut down that whole box to the one single MFI relay. The plate on the firewall with the heat shinks can be eliminated if you get away from the staged fuel pump control and use high impedance injectors.
There is a larger connector by the relay box that once you move things around, you can elimiante this connector as well. Do these fairly simple things and it will really clean up the engine harness. You can do this without getting into removing the dash as the engine harness can be completely removed from the car without removing the dash.
all my ABS wiring is gone. 100% of it. all my A/C wiring is 100% gone as well.
as for all that other stuff i have no clue what any of that is. LOL. so im guessing it is all still there.
Old Dec 19, 2012 | 08:15 PM
  #1592
EvoDan2004's Avatar
o and i messed something up somewhere because my key less entry clicker does not work. i thought the battery died but i replaced it and still it is not working. so i am guessing when i farted with the wires i removed one i shouldn't have. now i just have to remember to manually lock the car.
Old Dec 20, 2012 | 05:25 AM
  #1593
badev0's Avatar
Dan, maybe pull your harness, label each plug, then ship it to one of these fine gentlemen in this thread to do it for you lol.
Old Dec 20, 2012 | 10:50 AM
  #1594
EvoDan2004's Avatar
I wouldnt mind doing that.
Anyone??
Old Dec 20, 2012 | 04:56 PM
  #1595
Evo_AK's Avatar
Veteran: Air Force
Originally Posted by antilag_200
Engine side harness minimzed to this
Dan if you have not already done this, I would highly suggest it to you.
Awesome looking harness! If you don't mind me asking, where'd you run your charge harness and headlight harness through? I want to relocate everything behind my glove box, but can't decide the best route to run those two harnesses through the firewall.
Old Dec 20, 2012 | 05:40 PM
  #1596
Wheatley's Avatar
The headlight harness will run through the panel behind either one of the fenders like it does from the factory. You can run the charging harness separate or on a bulkhead post like I did.
Old Dec 20, 2012 | 06:02 PM
  #1597
Evo_AK's Avatar
Veteran: Air Force
Did you run it through the same bulkhead as your engine harness or a seperate one?
Old Dec 21, 2012 | 11:22 AM
  #1598
Wheatley's Avatar
For what, the charging? No I made a new hole. For the headlight stuff it already has giant holes behind the fenders.
Before I battery to the trunk I drilled a small hole in the factory plate for the factory charging harness, but when I moved the battery to the back I upgraded the wire size and wanted a true easy to remove engine and harness assembly so I installed a bulkhead connection for charging/starting.
Old Dec 24, 2012 | 03:52 AM
  #1599
Evo_AK's Avatar
Veteran: Air Force
What are you guys using for wire labels?
Old Dec 24, 2012 | 07:31 AM
  #1600
Wheatley's Avatar
If you want to label plug ends you can buy a printer that prints on heat shrink. My ****s not labeled because I think it defeats the purpose of a "tuck" harness and I know what connectors go where. Printers I think are around $50. I did run across a supply place that will print heat shrink labels for you but can't recall the name.
Old Dec 24, 2012 | 07:36 AM
  #1601
badev0's Avatar
I weighed my car the other day, it is 2720 with me in it in street mode (seats in and OEM enkei's on). Yes the scale is accurate, I weighed my stock Evo daily driver and was well over 3400lbs with me in it lol. Race mode would be without the front passenger seat, rear seats out, and 15" slip streams on which is another 130lbs off the car.
Car has all luxuries with power everything including oem sunroof minus A/C. Has 100% full interior panels also
Old Dec 24, 2012 | 08:12 AM
  #1602
LGshow19's Avatar
Nice weight!
Old Dec 24, 2012 | 08:20 AM
  #1603
AreSTG's Avatar
i'm jealous. even if you weigh 120lbs, that's a light car.
Old Dec 24, 2012 | 08:23 AM
  #1604
badev0's Avatar
Thanks guys. I weigh 140 on the dot.
Old Dec 24, 2012 | 08:35 AM
  #1605
06MREvo's Avatar
So with you, in race mode, your car is around 2600lbs+/- ...Impressive sir! Looks like I have a lot of work to do over the winter!
