Post exact weights of weight reduction you have done!
Old Jan 7, 2007 | 02:22 PM
  #46
9sec9's Avatar
Seibon Rear Doors save 14.8 lbs over stock doors.
Seibon Front Doors save 19.6 lbs over stock doors. (shell to shell)
Rear deck saves 9.8 lbs over stock deck. neither with wing.
Old Jan 7, 2007 | 05:36 PM
  #47
evilevo2006's Avatar
well does removing the door crash beams make the car flex more around turns and decrease the overall handling of the car???? and cuting your door apart like that also. does that reduse the overall car stiffness??????
Old Jan 7, 2007 | 05:41 PM
  #48
9sec9's Avatar
crash beams being removed in the door would have little effect on stiffness of the car, since the door is a separate piece to the body. Flex of it would occur at the hinges and striker post whether it has guts or not.
Old Jan 7, 2007 | 09:50 PM
  #49
evodan2008's Avatar
Originally Posted by EVOIX4me
I know this thread has been discussed alot but i thought it might be nice to make an official weight savings sticky ..
Please post the exact weights you saved over the stock component , and what exact product are you comparing too, thanks guys i will start it off .
This is from Buschur racing website *
60 lbs, the BR exhaust weighs in at 23 pounds.
Installation of Buschur Racing Mini Battery Kit: 20 lbs. The stock battery setup weighs 37lbs, the BR kit weighs in at 17 pounds.
Removal of Front Bumper Support: 13lbs.
Removal of Rear Bumper Support: 17 lbs.
Removal of Spare Tire, Jack, and Tool: 37 lbs.
Removal of Intake Bracket & EGR: 5lbs
Removal of FMIC Sprayer Bottle: 5.4lbs (empty) 11.5lbs.(full)
Installation of Buschur Racing Intake: 4.1 lbs.
Removal of Interior Sound Deadening & Padding: 17.5 lbs.
Replace Factory Rims w/ SSR Competiton 17" wheels: 6.4lbs (Weight loss using stock size/brand tires will be more, this is a total weight saved factory in the a larger tire (255/40/17).
Replace Factory Suspension w/ DMS Coilover Setup: 6.6 lbs. The DMS suspension weighs a total of 58 lbs. while stock is 64.6 lbs. OR You can use the HKS RS Suspension that has a total weight of 48 lbs. which will save you 10 more lbs.
Removal of AC Compressor & Condenser: 29.6 lbs.
Steering Column Plastic & Metal Insert: 1 lb.
Installation of Carbon Fiber Trunk w/ out wing: 10.6 lbs. The stock trunk weighs 22.5 lbs.with no wing.
Stop Tech 335 mm Front Brakes: 7.7 lbs.
DC Sports Front Strut Tower Brace: 4.9lbs.
Remove Brake Shield: 1.5 lbs.
A carbon fiber hood is HEAVIER than your stock hood. Our stock hood weighed 20.2 lbs. and the carbon fiber hood that we purchased but never installed was 21.6 lbs.
Removal of Interior Sound Deadening & Padding: 17.5 lbs. where do i find this stuff to pull it out???thanks.
Old Jan 7, 2007 | 10:34 PM
  #50
TrinaBabe's Avatar
The sound deadening is glued to the floor in many places... mainly under the feet and under the rear passenger seat. The whole firewall is also covered by a bunch of it as well. The engine side of the firewall also has some lighterweight stuff but its still weight.
Old Mar 10, 2007 | 08:24 AM
  #51
MR 600's Avatar
Just got my Ohlins/Works stage3 DFV coilover kit, weight:
13.56 lbs fronts each/ 9.24 lbs rear each
Total of 45.6 lbs, saving of about 19 lbs over stock.
Thats with the front camber plates and rear pellow ball mounts installed.
Each side mirror is 2.4 lbs, (4.8 lbs for both) if anyone has the weight of the APR side mirrors, please let us know, i dont feel like taking mine off.
My perrin IC should be here tomorrow + Koyo radiator, i will keep you guys updated.
Old Mar 14, 2007 | 03:15 AM
  #52
MR 600's Avatar
Perrin Intercooler 22.7 lbs
Old Apr 1, 2007 | 07:23 PM
  #53
oneguy's Avatar
how do we get to that steering column insert?
Old Apr 17, 2007 | 07:57 AM
  #54
EVOIX4me's Avatar
If you have a race car and are not concerned with heat and ac , remove the heater box from under the dash and also the fan box . 19.4 lbs
Old Apr 17, 2007 | 09:20 AM
  #55
dudical26's Avatar
Are there any AC components that you can remove from the dash and still retain heat?
I already know about all the AC stuff under the hood.
Old May 19, 2007 | 06:51 AM
  #56
4G63 T's Avatar
replace stock to mini battery
Old Jun 8, 2007 | 02:23 PM
  #57
evo82nv's Avatar
a
all that weight sure adds up quick. damn i lost alot...
Old Jul 4, 2007 | 02:11 PM
  #58
TrinaBabe's Avatar
All the wiring (Yes all of it) weighs just over 54.2 lbs. (I lost a little bit of it along the lines so I dont have an 'exact' quote).
Old Jul 4, 2007 | 06:15 PM
  #59
dudical26's Avatar
haha, thanks for the info. I doubt any one else will choose that as an area to remove weight, lol.
Old Jul 29, 2007 | 09:36 AM
  #60
Mojo Rising's Avatar
More info on this and stock weights, please.
