Post exact weights of weight reduction you have done!
Old Jul 18, 2012 | 08:57 PM
  #1396
dtrackstar's Avatar
My hybrid exhaust that I put together: SS 02 eliminator downpipe, SS test pipe, aluminum mid-section (about 4-5 feet long), and mild-steel rear to Magnaflow muffler/tip.
Car: IX SSL
Ultimate goal: Keep: full interior, AC, PS, ABS, factory stereo. (It's my DD during the summer)
Waiting to be installed/completed:
AWD DS
BR Rear Diff support
TS EGR Delete and evap delete
Rear crash-bar delete
Bracket under steering column
Shield above DS delete
Possibly sound deadening under seats and carpets
Already done:
Non-ACD TC conversion
BR cross-member
Front crash-bar delete
Removal of tire, jack, and tools
DC titanium front strut bar
Spoolin up cop (it's good for like 2 grams lighter than stock haha)
Exedy Twin
Swift Springs
Muse battery tray with Odyssey mini
Intake bracket removed
Things I have in mind later down the road:
BR moustache bar
Godspeed front sway bar
Hotchikss rear sway bar
AWD d2
Baer Rotors
Seat lowering bracket
Trans bracket
Firewall sound deadening delete
Replace mild-steel portion of exhaust with aluminum
aluminum IC piping
Suggestions are welcomed!!! (preferably on any of the lesser expensive upgrades/ easy removal stuff I may have missed)
Old Jul 19, 2012 | 05:15 AM
  #1397
B.J.@ToxicFab's Avatar
^^^Looking good man! I need to get on an aluminum exhaust damn it!
Old Jul 19, 2012 | 08:00 AM
  #1398
Blue91lx's Avatar
I don't know if yah'll will answer or not, however, before I start ripping **** out that I'd rather keep, what's the easiest/fastest way to get to 3,000lbs with a full interior?
Since I just finished my build I want to start focusing on weight reduction now. EGR stuff is already deleted.
Old Jul 19, 2012 | 08:20 AM
  #1399
Below is a post I made in this thread from last Nov. My car should be slightly under 3000lbs without me. I plan on going through the car & removing another 10-15lbs of random junk soon. I just can't get myself to remove AC & whatnot yet. Once I finally do my 5 spd swap & ACD delete the car will be put on the scales...
Originally Posted by B.J.@ToxicFab
My car still has full interior, AC, PS, radio, power windows, locks, etc....
No spoiler
Spare tire, jack & tools removed
All floor mats & misc. stuff in glove box & center console removed
98% of the tar sound deadener removed & some of the mat behind the dash cut away
DC Sports Ti front & rear strut tower bars
BC coilovers
RPF1s & Hankook tires (4 lbs lighter each then my stock BBS rims & Nitto tires)
Girodisc 2 piece rotors all around
Fortune Auto Ti Lug Nuts
NRG Front seats with BR lowering brackets & no sliders
Rear wiper delete
PS Cooler tube/hardline delete
Custom Mini Battery tray with 11.5 lb Brallie Battery
Minor wire tuck done & a lot of misc. brackets & whatnot removed from engine bay
Torque Solutions Trans & Passenger side mounts
AWD Motorsports 2 piece driveshaft
BR side rear diff supports with poly bushings
Kamispeed Driveshaft solid bushings
Shep built Non-ACD T-case installed & ALL ACD stuff removed
Front & Rear crash beams removed
All EGR crap removed including hardline
Rear 02 sensor deleted
Driveshaft tunnel heat shield removed
Exedy Twin clutch with STM clutch fork stopper & STM full SST clutch line
Shep Built 5 spd (5 spd swap)
I think that is it...might be some more stuff but that is all off the top of my head...
Old Jul 19, 2012 | 08:43 AM
  #1400
Blue91lx's Avatar
BJ, that was a huge help! Come to think of it, I have quite a few of those items down already, which is surely exciting! That really gives me a good idea on what parts to buy next .
Old Jul 19, 2012 | 11:26 AM
  #1401
No problem! Weight reduction wise I still have a ton of stuff I can do & keep AC & full interior. BUT I will either end up pulling some other stuff out of the car that I don't want to yet or end up spending a good amount of $$$ on other light weight parts. 2 things I forgot to add to my list...
Rear ashtray delete
Baby seat anchor delete
Old Jul 19, 2012 | 01:51 PM
  #1402
dtrackstar's Avatar
Whats thoughts on cutting the V "brace" in between back seats and the trunk??
Old Jul 19, 2012 | 06:27 PM
  #1403
EvoDan2004's Avatar
Car: IX SSL
AWD DS
Already done:
BR cross-member
Exedy Twin
Swift Springs
BR moustache bar
AWD d2
Baer Rotors
Trans bracket
aluminum IC piping
there is many things to be done here. the free mods is the best mods. remove all the sound deadening. it does nothing anyways and is in the 25+lbs range.
how crazy do you want to get under the dash? go back a few pages and go nuts with that. you can drop a ton of weight when removing the un needed crap behind the dash. behind the brake calipers there are dust shields. you can remove them as well. also under the hood use your creativeness and look at what brackets, clips, and BS you can mod or remove.
as for the god speed parts. i know there the lightest out there but IMO there quality is poor. go with the hotchicks rear and tanabe front. how about some Avid or TS motor mounts?
do not do that if you drive this car daily or on the roads. thats only for cut up drag cars. i bet it weighs less then 5lbs.
Old Jul 19, 2012 | 08:47 PM
  #1404
dtrackstar's Avatar
^ Thanks man I appreciate the suggestions. I'm going to look into it!
PS I just picked up hotchicks today...too bad it was used :/ haha
Old Aug 8, 2012 | 08:52 AM
  #1405
okevolutionVIII's Avatar
I'm not sure if anyone has a solid number on what the stock fuel tank weighs but I've had mine removed for a few weeks and will be weighing it tonight to see how much weight my fuel cell system dropped over factory.
My 16 gallon plastic cell with foam weighed 13lb 5oz and it's way lighter than the bare factory tank. I sold my fuel pump housing so I'll weigh it with what's left and with it bare/empty.
Old Aug 8, 2012 | 09:29 AM
  #1406
03whitegsr's Avatar
It's up near 50 pounds with the fuel pump. Another area you can make a killing on weight with the gas tank is capacity. The stock tank is 16-17 gallons, but because of it's design, you can only use about 12 gallons before starvation becomes a real concern. Drop that 4-5 gallons of fuel with a smaller cell and you are looking at 25-30 pounds without any loss of range.
Old Aug 8, 2012 | 02:26 PM
  #1407
Wheatley's Avatar
I really want an aftermarket tank that fits in half of the factorylocation and can use the stock pump housing. Anything being made yet?
Old Aug 8, 2012 | 04:30 PM
  #1408
AreSTG's Avatar
Originally Posted by 03whitegsr
The stock tank is 16-17 gallons.
holy ****! for real? If i get 13.0gal in there at the pump I'm proud and think i rolled in on fumes. I'm on E with multiple warning lights, and still only get 12.5gal.
Old Aug 10, 2012 | 10:57 AM
  #1409
I got a rough bathroom scale weight of 36.5lbs on the stock tank with everything but the pump housing.
Old Aug 10, 2012 | 11:13 AM
  #1410
03whitegsr's Avatar
Hell yeah, I was thinking about that a while back and I think you could get a good 8-10 gallons doing it that way. Maybe I'll go have a look at the gas tank and see how feasible it would be.
Although, I think the filler neck is like 7-8 pounds as well and it would be nice if you could cut that out too. Or get it down to 1-2 pounds while still being able to fill up like a normal car.
I don't think it would be legal for most racing classes either without a rubber bladder.
