side mount subs?
Old Aug 6, 2006 | 12:40 PM
Soon 2 B EVIL's Avatar
side mount subs?
i was looking thur some mags noticed that some people put there 10in sub on the side of the trunk. Like where people put the Akly kits in the left side of the trunk.
Is there any cons in doing that? like sound wise or anything?
Old Aug 6, 2006 | 12:49 PM
dbdude's Avatar
Its only gonna sound as loud as a bazzoka woofer no matter the brand or power you throw at it. Plus its probably expensive to make or buy since its probably made of fiberglass.
Old Aug 6, 2006 | 07:50 PM
GPTourer's Avatar
I don't see how it would matter. This is how stock SSL systems are mounted.
Old Aug 7, 2006 | 06:39 PM
is it really? ive never seen a SSL system up close so i have no clue. so the sub is in left side of the trunk?
Old Aug 7, 2006 | 07:31 PM
aznxdragon30's Avatar
all depends on the sub you buy and if the enclosure for the subs meets it specs for the speaker to produce Bass.... that will determine the sound you will get
Old Aug 7, 2006 | 07:36 PM
here are some pix of an evo with subs on the side
https://www.evolutionm.net/forums/sh...t=trunk+system
Old Aug 7, 2006 | 07:55 PM
yeha something like that but not that far out.
Old Aug 8, 2006 | 04:45 AM
GPTourer's Avatar
Right side.
Old Aug 8, 2006 | 04:59 AM
SaOrlando's Avatar
the ssl sub is on the right toward the shock tower not in the very back.
subs DO sound great in those locations, the box has to be made correctly. if you want something that sounds even better, you can fire the sub toward the rear tail light and at a 30 degree angle toward the floor. if you are willing to give up another inch.
we charge around 400(more for box i was describing) to do what you want to do.
Old Aug 8, 2006 | 05:03 AM
GPTourer's Avatar
How much further back could it be?
I am going to replace my sub with a custom box. I just need to come up with something that maximizes trunk space but will allow me to use a rear strut bar. I am only going to use one ten. Here is the stock sub.
kidneythief13
12
Jan 30, 2008 06:29 PM
Andrew LB
Mar 19, 2006 07:36 PM
hawaiievo
Dec 19, 2005 07:05 AM
SilverCOEvo
Apr 11, 2005 12:20 PM
Sentinal
48
Jan 17, 2005 02:39 PM
