Electrical Gremlins - symptoms and how to fix
Old Mar 3, 2019 | 10:52 PM
  #256
patric78's Avatar
Originally Posted by lolscotttt
the problem i'm having is that i don't know which wire goes to which. i couldn't find a wire diagram that showed which colored wire or wires go to which. i'm apparently missing one wire because my front blinkers do not work at all.
You can dowload the manuals here, they also include the diagrams of each plug (numbered).
Old Mar 7, 2019 | 12:02 PM
  #257
WelDun1's Avatar
You can download the manual like ^^^Patric said, but honestly it shouldn't be that difficult to figure out which wires connect bcuz they connect the same way they do in the "Connector"
You are best off by cutting every single wire in those 3 connectors 1 by 1 & either soldering them or using good heat shrinking waterproof connectors and eliminate those OEM connectors all together. This will save you many headaches, trust me!
Also, as EvoGuy mentioned above:
Originally Posted by Evoguy!123
What i did was cut off the connector and solder the wires directly. Had this problem last year, now i got zero issues, but put silicon around the grommet its behind the fender, to avoid water going in.
This is the source of all the electrical problems. Water seeps through then travels down the wires and pools up where those 3 connectors are mounted.
Hope you figure it out!
Old Nov 26, 2019 | 08:06 PM
  #258
ScubaStevo's Avatar
Bumping this, very useful information here. Any chance this corrosion could cause issues connecting to the obd port to read codes/flash the ecu?
Old Jan 12, 2021 | 08:58 AM
  #259
Paul Antosy-Ott's Avatar
Hey, I wanted to confirm whether or not the wires for all 4 connectors can be hard soldered? Ideally, I want to remove the junction box/bracket just to make things look a little cleaner and give myself more room to work with.
I popped the two smaller connectors up top off the bracket and am going to tape them up out of the way.
I'm about to be tackling this in the next couple of days on my 03. Car was from PA/NJ originally, but these issues (SRS light, intermittent starting issues, intercooler sprayer non functional) started cropping up when I moved to AZ.
My friends here in the desert had never seen anything like this. Probably due to the distinct lack of rain here
Also wanted to say thank you for this write up.
Old Feb 3, 2021 | 06:27 AM
  #260
gsrboi80's Avatar
Yes sir you can absolutely, only way to fix it correctly with no chance of reoccurring issues IMO. The SRS light will need to be reset with a unit that can talk to the SRS, ABS, etc... Not just a simple OBDII scanner
Old Feb 3, 2021 | 08:28 AM
  #261
Thank you so much for the response. I went ahead and cut/ soldered all the wires in C-129 (25 pin connector) and C-134 (11 pin connector).
C-129 is all good, however, I have an extra wire from C-134.
On the black side of the connector there is a light green wire and a green wire, but on the white side there is a light green, green, and a Red/White wire that doesn’t seem to connect to anything.
I’ve been combing (the copy of the manual I have doesn’t have an index) through the wiring diagrams I downloaded from EvoScan, but I can not find any mention of this Red/White wire and what it connects to since there is nothing obvious. Right now I have the wire capped off and not connected to anything. I tried grounding the wire and nothing happened (not smart, I know)
How do you have this wire soldered on your car?
Also, the Mitsubishi dealership tried telling me the SRS light would go off on its own with no intervention if the issue was fixed. They had very little credibility with me before, but even less now 😂
I’m unsure of what this wire does. Tried tracing back to source, but it quickly runs to somewhere inaccessible.
Wires going to Pin 1 and 5 on black side
On the white side, there was a wire going in to Pin 4 that completely corroded and fell out of the connector
Old Dec 2, 2024 | 05:21 PM
  #262
mykep83's Avatar
THANK YOU TO EVERYONE THAT HAS COMMENTED. I know this is an old thread but It helped me out a ALOT.
I have one gremlin remaining from this, wondering if anyone has any input.
when I turn the ignition on my rear driver tailight turns on, when I flip the light switch on it remains on and the passenger side then turns on. braking seems to dim but is still working. THOUGHTS?????
Old Mar 3, 2025 | 03:43 PM
  #263
Black Coffee's Avatar
would be super sick if you posted the fix.. i have the same issue
Old Mar 3, 2025 | 03:45 PM
  #264
Originally Posted by scopy
i was ****ing around trying to wire in my new head unit... ( i hate working with wires and should have known better lol) but something happened and im pretty sure i blew a fuse because when i turn my headlights on, the "dimmer" whatever doesn't switch over, like my HVAC panel lights (temp, radio, blah blah) dont come on, and my gauges (afr and boost) dont switch to the dimmer color, as well as my passenger tailight not coming on, but the brake lights and blinkers are fine. (replaced the bulbs to make sure)
someone help, i havn't had time to get out and pop through the fuses to check because of my work schedule. will do it today when i get the chance, but just wanted a second thought on whether it could just be a fuse.(hopefully)
EDIT: Searched through the forum a bit harder and found my answer, sorry for wasting space here>
Avirex
02-03 Lancer Show / Shine
311
Aug 6, 2014 11:15 AM
fostytou
10
Feb 28, 2012 09:34 PM
Serbj
May 10, 2011 11:38 AM
Koroshiya
May 17, 2009 07:29 AM
Blacksheepdj
Lancer How Tos / Installations
Dec 3, 2007 03:48 PM
