Electrical Gremlins - symptoms and how to fix
Old Mar 5, 2009 | 05:21 AM
  #46
MitsoKid's Avatar
hey guys, I pulled the connectors apart and found alot of corrosion.. cut the harness, re-wired the entire junction area, no more problem..
Thanks alot
Old Mar 5, 2009 | 05:40 AM
  #47
detroit pistins's Avatar
Could someone post some more pictures of the issues with these connectors next time they change them. it would be highly appreciated by most of us.
Thanks
Old Mar 9, 2009 | 11:55 AM
  #48
gsrboi80's Avatar
Thanks alot
Old Mar 14, 2009 | 08:33 AM
  #49
SME's Avatar
SME
I had this same issue too. Re wired and sodered the wires together. Seems to be working now!
Old Apr 3, 2009 | 05:54 PM
  #50
bsander's Avatar
I had an encounter with the "Rain Gremlins" haha. Accept my BCM (body control module) shorted out. Dealer covered it for me though. Nice Thread
Old Apr 3, 2009 | 05:58 PM
  #51
on ur ix? i thought it was mainly a viii issue? where is that bcm btw? anypics? was it coroded?
Thanks
Old Jun 1, 2009 | 04:30 PM
  #52
tchouko's Avatar
thanks dude...
Old Jun 2, 2009 | 06:13 AM
  #53
gsrboi80's Avatar
Thanks
Ive actually seen just as many IX's have the issue as VIII's. The harness comes through the inner fender in the exact same spot so....
  #54
gsrboi80's Avatar
Originally Posted by tchouko
thanks dude...
Old Jul 21, 2009 | 12:32 PM
  #55
asplodzor's Avatar
Interesting thread... I want to seal my grommet up, but I'm not sure how to do it. I just made some huge slices into the top of it about a week ago to wire up my fog lights as well as some other stuff... six total small and big wires.
How does silicon sealant work? Do you just make sure that all surfaces are covered, and it dries that way? Also, what's the best option to direct wire the wiring harnesses? crimps, solder + electrical tape, or solder + heat shrink?
Thanks for the info!
Old Jul 29, 2009 | 10:19 AM
  #56
gsrboi80's Avatar
Yes silicone will dry like rubber and seal what your looking to. As for wire splicing I only ever solder and shrink tube things. Not a fan of connectors and such
Old Jul 29, 2009 | 02:06 PM
  #57
revvin9k's Avatar
Do it once and do it right.
Old Jul 30, 2009 | 01:33 PM
  #58
asplodzor's Avatar
So I just make sure to get a ton into all of the cracks and spaces between the wires, and I'm good?
Old Jul 30, 2009 | 02:55 PM
  #59
revvin9k's Avatar
Soldering is not hard at all, but I would highly suggest practicing on open wire outside of your car.
If you decide to tackle this yourself, put a blanket underneath so you do not spill hot solder on your carpet.
This is not a job you wanna do twice.
And for the harness that runs through the wheel well, I used Hondabond.
Old Jul 31, 2009 | 02:42 PM
  #60
asplodzor's Avatar
I'm sorry, I should have clarified: I'm fairly experienced at soldering, but I don't know how to strip the shielding back from a wire without cutting the wire.
The question I was asking pertained to silicone sealant which I have no experience with.
Info about both would be appreciated.
