Electrical Gremlins - symptoms and how to fix
Old Jul 31, 2009 | 03:19 PM
  #61
revvin9k's Avatar
Originally Posted by asplodzor
I'm sorry, I should have clarified: I'm fairly experienced at soldering, but I don't know how to strip the shielding back from a wire without cutting the wire.
The question I was asking pertained to silicone sealant which I have no experience with.
Info about both would be appreciated.
Honestly, I just used a mini butane torch and just heated the end of the shielding, and pulled back as I needed.
Your fingers will hurt a bit when you are doing this. Pay no mind, they will numb.
I just gooped the silicone on, don't be shy with it. I used a small flat edge to make it look "neat".
Old Jul 31, 2009 | 03:24 PM
  #62
Junkyard's Avatar
Thanks fer da fix.
Old Oct 21, 2009 | 06:12 PM
  #63
gsrboi80's Avatar
Yup once you cut the wires to the connector front and back there was def a good amount of slack in the wires to hard solder them together easily. I used wire strippers to strip shielding off and expose the uncorroded wire.
Glad this sticky has help so many so far any ? guys PM us that have done it. PITA yes but once it's fixed no worries ever again.
Frigging Mitsubishi's
Old Nov 21, 2009 | 07:43 PM
  #64
C130flyer's Avatar
This thread just saved me and my friend.
100X to the OP
Old Nov 25, 2009 | 05:30 AM
  #65
gsrboi80's Avatar
100X to the OP
Thanks I like beer
Old Dec 31, 2009 | 04:30 PM
  #66
Nasty Evolution's Avatar
Originally Posted by gsrboi80
Thanks I like beer
Ha well if you're ever in the WI area let me know I'll be sure and buy you a beer!
Old Jan 2, 2010 | 11:12 PM
  #67
Ok so I've got a little something to add to this thread. Even after I sealed up the grommet water was still getting down in my harness. How can this be? Well I'll show you. I don't actually think the water was ever getting in my gommet or most anyone elses for that matter. I will show you where it's most likely coming from though.
As you can see Mitsu never even bothered to finish wrapping up the wires in the harness, water gets in here and runs right down inside, using the part that is wrapped up as a perfect slide if you will.
Here is where the wires are uncovered. This is in top of the fender or wheel well (on top of the fender liner) There is a plastic box over the wires but NOTHING to seal the water out from running right inside here and down to your harness plugs.
Here is where I have wrapped up the wires fully with electrial tape, now water won't be getting inside here.
Lastly here is the whole thing, notice I also sealed up the gommet just to be sure.
If someone can copy my pics and rehost them that would be great. I don't have a ton of bandwith.
Old Jan 3, 2010 | 08:14 AM
  #68
gsrboi80's Avatar
Good find man. I never follwed the wiring back that far as I could def see the water coming through the grommit as well (squirting water at it from the outside).
But agreed having bare wire there is stupid and I will go back and address it. Even though all my connections are hard soldered now
Old Jan 3, 2010 | 09:49 AM
  #69
Aman's Avatar
holy **** .. that is fired.... i am gone have to take mine apart to..
Old Jan 10, 2010 | 10:28 AM
  #70
ohEVO18's Avatar
issues here as well...Wipers not shutting off and operating on their own, horn blaring on its own, indicator lights on dash not going off, and (the best one) the car not starting at all....
Im about to tackle this with the help of this thread (thanks guys). I will try to get some pics as well...
Old Jan 10, 2010 | 01:15 PM
  #71
revvin9k's Avatar
Don't look into it too much. Just dis connect the battery and cut a couple of wires. This way you have to do it.
This is how I start off all my electrical adventures, this way I know I can't turn back.
Old Jan 10, 2010 | 02:47 PM
  #72
ohEVO18's Avatar
...I'm still trying to get all of the connectors out of the "big white box"...
Got em unplugged but cant get the back part of the plug out so that I can start cutting...
FML
Old Jan 10, 2010 | 03:01 PM
  #73
ohEVO18's Avatar
This is where I am currently at:
I will update this post with more pics as I continue through the "project"
Any info on how to get the plugs that are in that white junction block would be GREATLY appreciated lol
Sorry for the crappy BlackBerry pics...
Old Jan 10, 2010 | 03:22 PM
  #74
revvin9k's Avatar
Since I ran mine direct, I found no use of that specific "connector bracket", so I just cut it with side cutters and slid the connector through.
My wires still run through there, less the connector.
Old Jan 10, 2010 | 03:34 PM
  #75
ohEVO18's Avatar
hmmmm good idea...didnt think of that....when I get frustrated I dont see obvious solutions lmao
