Test pipe vs. Hi-flow
Old Oct 30, 2004 | 08:12 PM
lil'evil_evo's Avatar
The winner is test pipe. I had a random tech hi-flow for a few months now. I just had my new UR test pipe installed and I like it much more. I didn;t think I would be able to realize the power difference, but I could. The sound is a lot depper as well. No cel as of now. So overall very happy as others with this test pipe also seem to be. I give it a perfect 10
Old Oct 31, 2004 | 02:11 AM
Evil EV0's Avatar
LOL, good to see you got it on. Did you just pull the wiires for the 02? I am also very happy with mine and so far about 6-700 miles and no CEL.
Old Oct 31, 2004 | 02:36 AM
Sentinal's Avatar
of course a test pipe is going to be a little better than high flow cat your going from a small amount of resistance to basically none.
Old Oct 31, 2004 | 11:31 AM
evo81's Avatar
about time you made the switch
Old Oct 31, 2004 | 11:34 AM
BuLocal's Avatar
I wonder if anybody has done any dyno testing.
Old Oct 31, 2004 | 12:01 PM
Ted B's Avatar
On cars around the ~350whp level on a DJ that have been tuned before and after, the difference appears to be 10-15hp.
On cars without the benefit of dyno tuning, the difference may be less (depending on the present A/F), and somewhat less of a power difference should be expected for cars at lower power levels.
Old Oct 31, 2004 | 01:13 PM
Fourdoor's Avatar
I can confirm from personal experiance a 10 HP drop (at the same boost pressure) going from a test pipe to a high flow cat on a Dyno Dynamics dynometer. The A/F ratio's didn't change at all, but I did lose 1 psi of boost until I adjusted the boost contoler up a bit.
Keith
Old Oct 31, 2004 | 01:19 PM
boostfed's Avatar
well I wasn't so lucky. I installe my BR 3" downpipe, testpipe, and catback and after about 20 miles of driving I got a check engine light. I guess I'm gonna have to install the 02 simulator.
-Chad-
Old Oct 31, 2004 | 06:29 PM
We used the wires to extend them. evo81 extended his with the Helix test pipe and the wires melted because they were so close.
Old Oct 31, 2004 | 06:30 PM
It's not even basically none it is 100% none
Old Oct 31, 2004 | 06:36 PM
SiCKlEyWiKeD's Avatar
glad you're happy with it casey
Old Oct 31, 2004 | 06:37 PM
WildRice's Avatar
Actually there is resistance in the form of friction so it isn't none..however you would have a difficult time measuring it.
Old Oct 31, 2004 | 07:21 PM
Now your getting to technical
fareastkorean
May 13, 2006 07:58 AM
ohthree
Automotosports - Illinois
10
Apr 11, 2006 04:32 PM
johny719
26
May 18, 2005 07:38 PM
Scotty2Hottie
Lancer Engine Tech
15
Dec 29, 2003 03:32 AM
Justin1933
19
Oct 30, 2003 01:54 PM
