Boosting too low
Old Mar 5, 2005 | 10:24 PM
jose_leema's Avatar
Boosting too low
Hey guys. Well Im pretty much a newbie when it comes to performance turbo cars. But not NA performance cars. I've owned an 02 NSX cpe man. & prior to that a Mugened-out 97 Integra Type-R . (220 whp )
Anyhow, I just recently purchased myself an 05 Evo MR. Now being new to turbos I have a problem that I could use some help with. And yes, I've searched.
Now I added an MBC. Hallman Pro to be exact. Car was flashed @ 21 psi w/ stock exhaust. It was boosting fine for weeks. Now its about the 5th week or so & I've finally checked it again. (BTW I've checked the boost about 3x in between). Now its peaks at 1.2-1.24 bar or 17.41-17.6 -ish psi. Am I having some kind of leak? Stock BOV? Now as I stated Im totally new to this turbo stuff. I checked the boost controller and turned it up all the way until it couldnt turn anymore...pretty much the same results..So just to be safe I turned it down a turn and some more...
Should I just get it checked out at a perf. shop? Or should I also get an aftermarket BOV in case. I was told the HKS ssq?? Might be wrong on that...I've told it was great & Im going the HKS route anyhow.
Thanks & any help would be greatly appreciated!
Welcome me to the club too!!!
Old Mar 5, 2005 | 10:32 PM
Curt@MrLed's Avatar
Former Vendor
buy an electronic b/c... im sorry its to coincidental, all these people with the same prob all running a manual b/c.. posted not to long ago...
https://www.evolutionm.net/forums/sh...28#post1724428
Old Mar 5, 2005 | 10:33 PM
Mercenary3's Avatar
Most likely you have a leak somewhere. You could have more serious problems but a leak is by far the most probable.
Old Mar 6, 2005 | 01:38 AM
turbolarry's Avatar
Are the boost or vacuum lines to the boost control solinoid conected to the MBC? If they are, they are not suppost to be.
Old Mar 6, 2005 | 08:48 AM
jose_leema's Avatar
Hmm..That's something I'll definitely keep in mind. It just that I've heard of lots of guys running this mbc & have had no problems so I got this one.
Thanks
Old Mar 6, 2005 | 09:08 AM
jose_leema's Avatar
Serious problems?? You're scaring me here bro. Hopefully it is just a leak somewhere...
Old Mar 6, 2005 | 09:24 AM
95GSXtoEVO8's Avatar
My hallman MBC works perfect, many of them do. You probably have a boost leak somewhere. Many of us have found the clamps on the IC piping to be not as tight as they should be from the factory. I suggest tightening all of them first, before you go out and spend money on other parts like an ebc or bov.
Old Mar 6, 2005 | 09:27 AM
jose_leema's Avatar
Thanks for the info man . Im checking it out right now as I type.
ARNAK
Oct 28, 2016 05:49 PM
sobo
13
Oct 2, 2010 10:38 AM
Nasty Evolution
13
Feb 19, 2010 07:27 PM
voidhawk
Apr 4, 2008 01:13 PM
SIMSSEGA
Lancer Aftermarket Forced Induction Tech
57
Nov 12, 2006 08:01 PM
